Question about Adobe Computers & Internet
Adobe photoshop 7.0 instal a window 7 setup a reqire password
  • Adobe Master
  • 3,957 Answers
The password code is provided with the software. Look in your package for a sticker with the code on it.
Posted on Apr 19, 2015
Diamond E
  • 57 Answers
SOURCE: adobe photoshop 7
yes 1 choose the filter mosiac from the filter menu. 2 choose any options form your window 3 choose "ok" in your special filters you will find the following Pixelate: Color Halftone, Crystallise, Facet, Fragment, Mezzotint, Mosaic,Pointillize. of course you will choose Mosiac. you may want to down sample your photo to 300 dpi then adjust your brightness and contrast to your desired likeness. You can also change the grayscale doing this.
Posted on Sep 14, 2007
pankaj_dic
  • 1250 Answers
SOURCE: Photoshop's Primary Scratch & Windows primary paging file on the same volume
this is not a hardware error actually photoshop writes temporary files, for which it uses hard drive, its alway a better to have scratch disk other then the drive where its installed, you can change this, by going to edit, preferences, then check plug ins-scratch disk, check your first scratch disk other than c, say the drive which has the maximum space, then select any drive
how do you like the solution please rate it i will appreciate your comments
Posted on Oct 28, 2008
akillz
  • 10 Answers
SOURCE: photoshop 7 serial
1045-1209-6738-4668-7696-2783 OR 1045-1423-6436-0168-7941-1739 OR 1045-1716-9174-2622-9063-1777
Posted on Jul 28, 2009
  • 1738 Answers
SOURCE: serial number for photoshop elements 7
Try calling the company and tell them you bought the program and the serial no. doesn't work. If that doesn't work do a your favorite search engine serial for photoshop elements 7. Warning, do this can cause harm to your computer, with adware, mailware.
Posted on Aug 09, 2009
acsess
  • 40 Answers
SOURCE: '' Please install Adobe Fireworks CS4 using Setup.exe '
Hi. The setup.exe is usually found inside the Adobe folder or can be found at the root folder of the installation disc if your using one of those "Premium" Adobe software compilations.
Posted on Aug 28, 2009
Folder Corrupt and Trying to Install Adobe Photoshop Elements 9
First variant you may use if your .psd file was seriously damaged
https://www.repairtoolbox.com/photoshoprepair.html Photoshop Repair Toolbox
Second solutions are showed as knowledge bases about Adobe Photoshop
http://www.techrepublic.com/forums/questions/repairing-damaged-adobe-photoshop-psd-files/
https://forums.adobe.com/message/6698481
Third one is a guide from Adobe
·Open "My Computer." In Windows XP, the icon is on the desktop. In Windows Vista or Windows 7, you must access this via the "Computer" option in the Start menu.
·Double-click the "C" drive, followed by the "Windows" folder inside. Locate the temporary Photoshop folder, which will look similar to this: "Photoshop Temp6382948398." Double-click the folder when you find it.
·Locate the file inside the temporary folder that matches the name of the corrupted file. Double-click it to open it in Photoshop.
· Click "Save As" in the "File" portion of the main menu bar. Save it in a different location and under a different name
Sep 16, 2015 | Adobe Photoshop CS for PC
Photoshop 7 using windows 7
using the program photoshop cs 7 in Windows 7 is easy, you just install and follow the instructions until the installation process selesai.dan photoshop software you are ready to use.
Jul 22, 2011 | Adobe Photoshop 7.0 for PC
When i installing adobe photoshop cs2 , there is error 1311 so how can i solve this
Your CD might be damaged in someway.
You can try this to solve it.
1. Copy the content from the CD over to you computer.
2. Run the setup you just copied to your computer. (if you have Windows 7 or Windows Vista you will have to run the setup as administrator.)
That should fix your problem.
Mar 07, 2011 | Adobe Photoshop CS2 for PC
Hi i want to buy adobe photo shop element 5.0 .. is it still available and how much does it cost.. I have Windows 7 is it made for Windows 7
I'm sorry to inform you that Adobe Photoshop Elements 5 is supported only upto Microsoft Windows Vista (32-bit versions only). You have to install the Adobe Photoshop Elements 5.0.2 update. The Adobe® Photoshop® Elements 5.0.2 update provides compatibility with Microsoft® Windows Vista™ (32-bit versions only). Refer the URL for more information:
http://www.adobe.com/support/downloads/detail.jsp?ftpID=3569
You may use the Photoshop Elements with Windows 7. Refer the URL for the comparison with various versions:
http://www.adobe.com/digitalimag/compare/
Refer the URL for System Requrments:
http://www.adobe.com/products/photoshopel/systemreqs/
Dec 12, 2010 | Computers & Internet
Install photoshop elements 6 for windows 7, it does not open at all after installation.
You have to wait for the information about the compatibility of the Adobe Photoshop Elements 6 and Adobe Photoshop Elements 7. You can upgrade to Adobe Photoshop 8 which is completely compatible with Windows 7. You can check the compatibility here. Check event viewer for the error message, for this click on start menu type Event Viewer and press Enter. It would be better to check with Adobe for what operating systems that Photoshop Element 6 would be supported. However you can try installing Adobe Photoshop Element 6 in a fresh installed Windows 7.
I hope this helps.
Apr 21, 2010 | Adobe Photoshop Elements 6: Windows
I have disinstalled Photoshop 7.0 and do not manage to re-install it using the original CD Rom. My Vaio is running Windows XP. When I click on 'install photoshop 7.0', the setup windows disappear and...
Bring up "My Computer" with disc loaded does it show on the menu window?
If it does, click on Photo 7 Menu look for "Setup" icon should run.
Rem you may only have purchsed one prog, need to contact supplier? usually very helpful!
Nov 03, 2009 | Adobe Acrobat 7.0 for PC
Photoshop elements 7 will not download onto my laptop
I think you have problem with  you setup package.if you tried to install through cd or dvd then first clean it with clean cloth and try to install . If this error again appears then contact adobe company with activation code or you details . Then they will provide new product
Nov 01, 2009 | Adobe PHOTOSHOP ELEMENTS 7 for PC
Adobe Photoshop Elements 7 Editor "stops working"
Even though this says Elements 6, it still works for 7. The only difference is the TWAIN file is at: C:\Program Files (x86)\Adobe\Photoshop Elements 7.0\Locales\en_US\Plug-Ins\Import-Export
http://kb2.adobe.com/cps/408/kb408846.html
Jul 15, 2009 | Adobe Photoshop 6.0 for PC
About photo shop
Yes, you can install Photoshop 7 in Windows XP.
Mar 24, 2008 | Adobe Photoshop 7.0 for PC
Computers & Internet Logo
55 people viewed this question
Top Adobe Computers & Internet Experts
lemesee
Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
