Question about Home
Blanket control started flashing E2. What does it mean? I have unplugged to reset it but it did not change.
2 Suggested Answers
  • 50 Answers
SOURCE: The 2 controls to our electric blanket are flashing "FF". What does that mean, plus there's no heat at all from it.
With the Sunbeam blankets that I have owned, FF meant that there was a bad connection somewhere. Have you tried the unplugging and replugging the Controller cord back into the blanket? Make sure it is plugged in GOOD AND TIGHT. If that part is connected as tightly as it can go, you may have a defective element.
Posted on Dec 18, 2014
Why does the light keep flashing red on my sunbeam electric blanket control remote? It just keeps flashing on high I try ed unplugging from the outline and the blanket nothing works. It started doing this...
There is a problem with the blanket. Since it started doing this just after washing (as per instructions), I suspect that somehow - running it thru the washer caused the problem.
Since it is an electrical device, if allowing to air dry thoroughly doesn't let it work as expected, you should stop powering it - and use it only as a non-powered blanket or discard and replace.
Feb 03, 2015 | Miscellaneous
Dec 18, 2014 | Sunbeam Pac 259 Dual Electric Blanket...
What does the light flashing on a sunbeam electric blamket controller mean and why wont the blanket heat up
The flashing red light is designed to notify you in the event that
a problem has been discovered by flashing the light on the base unit.
Before resetting the unit. First, check the blanket/mattress
pad for visual damage.
If no visual damage is found, unplug the system from wall outlet.
Check that the base unit is well connected to the module. Plug the power cord into the wall outlet. Set the base unit to "On." If the system still does not operate after two or three times trying to reset, disconnect the power cord and get it checked out by a specialist!
Nov 02, 2014 | Home
Winter's tale electric heating blanket flashing "F"
I\'m having the same problem as Jenn. Tried unplugging it and left it for a day. Both sides are now not working. How can I get it to work again? Husband is having a hissy. Please just tell me what to do. or tell me how to download the manual. Haven\'t had this for very long 2 months. if any help.Mary Ellen I did love this when it did work.
Nov 19, 2013 | Winter's Tale Microplush Electric Blanket...
I bought a queen dual control warming blanket . I barely used it the first time I bought it a year ago. I put it into my closet for storage after the first winter. I put it on the bed today getting ready...
The flashing lights usually means theres a problem and the blanket has shut itself off so it wont cause a problem...Like burn down your house.
I love electric blankets but I have had little luck with them. Its only a matter of time before they get like this. I have never gotten one to work again after it has started to blink.
If you still have the box maybe there is a warranty.
Sep 21, 2011 | Health & Beauty
My husband and i were just recently given the queen size, dual remote heating blanket from you guys. When we try to turn on either of our remotes, it flashes F2 consistently unless unplugged. Is there...
The first link has some info about the F2 code.Apparently it used to be seen as FF but was changed.It is a power problem.It is still the same problem,which is REALLY not good.The next couple of links are forums which people also have the same problem as you.I would seriously get rid of that blanket.I saw someone mention EMF.I know exactly what EMF is and it is not an issue with this blanket at all,and is present in many things.A microwave probably has more,and still is not an issue.Anything that plugs into a wall has some form of EMF present,so do not even worry about it.
http://wiki.answers.com/Q/What_does_the_flashing_code_F2_mean_on_the_Sunbeam_Dual_Electric_Blanket
http://www.consumeraffairs.com/homeowners/sunbeam.html
http://www.complaintsboard.com/complaints/sunbeam-westpointe-amp-jc-penny039s-electric-blanket-c40368.html
http://www.complaintsboard.com/complaints/sunbeam-heating-blanket-c134216.html
Nov 28, 2010 | Sunbeam Heating & Cooling
Dryer stops and flashes E2 failure
Try unpluging your dry for about 5 minutes. Sometimes it just needs to reset itself.
Jan 31, 2009 | Kenmore Dryers
Electric Blanket Control Blinks
mydual control sunbeam electric blanket blinks on one control
Dec 23, 2008 | Sunbeam 4237 / 4238 Iron with Auto...
CANNOT RESET E2 ERROR CODE TRYED UNPLUGGING DID NOT WORK
I have only worked on USA machines but I believe you have a control panel error.
Sep 27, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Electric blanket controller light blinking
i had the same problem , i believe it was caused by unplugging the blanket plug while it was in the on position , i unplugged it from the wall and it like reset itself , worked for me.
Sep 20, 2008 | Heating & Cooling
Home Logo
447 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
