What does E2 flashing mean. Just started flashing and now it does not work
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check door inter lock
Posted on Apr 21, 2015
The thermostat is flashing and E2 error code...what does that mean
It means the trailer is too warm for the thermostat to work - above 90 degrees inside. Take some ice and put in ziplock bag - place over thermostat and cool it down. Unit will start working when thermostat senses it is BELOW 90 degrees. FAULTY DESIGN.
Jul 06, 2011 | Dometic Rooftop RV Air Conditioner
Dryer will not start display works, when i push the start button it just beeps and does nothing, shows a E01 code.
Hi, this is what the error code means,
E1 or E2 Thermistor Failure The dryer will not operate if the exhaust temperature drops below 18 degrees F. or exceeds 250 degrees F.
When the thermistor circuit is open (>50K ohms), the error code E1 flashes in the display.
When the thermistor circuit is shorted (<500 ohms), the error code E2 flashes in the display.
Normal thermistor resistance values:
60 degrees F. - 15.3K ohms.
70 degrees F. - 11.9K ohms.
80 degrees F. - 9.2K ohms.
Hope it helps.
Jan 19, 2011 | Whirlpool GEW9250 Electric Dryer
What does an E2 code mean? I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and...
I have a Haier Dehumidifier that is about a year old, I emtied the bucket and put the bucket back into place and hit the start button and nothing happen I unplugged the unit and error code E2 keeps comming on
Jun 30, 2010 | Haier HD451E Dehumidifier
What does error code E2 mean? I have a Bosch Maxx Classic.
The e2 error is a generic error that the machine shows if it's been overloaded or if the load becomes unbalanced during a wash cycle.
to fix you must do a master reset of the washing machine.
1. Close the door and make sure the dial is pointing to the "OFF" function
2. Hold the Start/Pause button and turn the dial anti clockwise (to the left) to the "express 15 min" program at the same time.
3. Hold the Start/Pause button for a minute (the e2 message is meant to start flashing after a minute of holding the button down however with my washing machine this didn't happen)
4. Release the button and turn the dial back to the "Off" function.
5. Select any program and the message should not be appearing.
Nov 03, 2009 | Bosch Washing Machines
Have a Avanti 798SS Washer. Does not wash nor does it spin. I heard something with the motor as if it attempting to perform said task (wash) but in the end it beeps and E2 flashes. What does this mean?
Oct 21, 2009 | Avanti Top Load Washer W797
Carrier Comfort Zone 2 flashing E2
the e2 error on your thermostat is a problem with the return temp sensor on your system, the only thing you can really do is call a company and replace it, you can't bypass it or remove it cause the system wont run properly
Jun 29, 2009 | Carrier 38CKC060 Air Conditioner
Bosch Washing MAchine - E2 error message
Hi.
E2 means uneven balance.
The error code gets reset using the following procedure:
Ensure that the machine door is closed. Turn the dial in the OFF position.
Hold down Start/Pause button and turn the dial anti clockwise at the same time until its position is pointing at the Express (15mins) program.
Hold down Start/Pause button until the e2 message starts flashing (or keep holding for about one minute)
Release the button.
Turn the dial again to the OFF position.
The machine is reset. Select any program.
If the message comes back after selecting program, then there is still a balancing problem. Remove and redistribute load, check floor and ensure machine is at level.
Jan 31, 2009 | Bosch WFMC 3200 Front Load Washer
What does E2 mean when it appears on my PC720 Panasonic copier?
A E210 has to do with the scanner part of the copier. Is the lens moving OK on warm-up? Dose it move at all and what about the optic's do they move at all? I would need some more info on the problem.... I don't want to lead you on, that it is a easy fix... It is a fairly older copier.. It may not be worth repairing
Sep 09, 2008 | Office Equipment & Supplies
Diplomat dishwasher keeps flashing E2 anyone know what this means
dishwasher starts then goes to prewaash and beeps.When opened it flashes f2.
Dec 27, 2007 | Hotpoint 18 in. DC28 Slim-Line Built-in...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
