I have picked this up secondhand without a manual and cannot work out how to re-tune it.I am unable to pick up any channels.
  • Shade Tree All Repair
    Are you using straight cable into the TV or HDMI from cable box to TV ?What year make and model is the TV this is important when asking any question on here Always Year, Make, Model ok
    Genius:
  • 2,486 Answers
Press menu or settings, set state or country. use up down keys to move to tuning, select analog or digital as the case may be , then press ok it will start to select stations.
Posted on Apr 19, 2015
Unable to tune channels
Hi Andrea
Try install attenna prior doing some auto programming.
Jan 27, 2014 | LG RH1999H DVD Recorder/HDD Recorder
Can't get tv to pick up any channels
Are you trying to still tune an old TV to pick up analog channels over the air? Analog OTA broadcasts no longer exist.
Jul 15, 2011 | Audiovox Televison & Video
Unable to pick up local ''free'' channels following digital change over. Using RCA DTA800 converter and Phillips 2750/27 antenna. Can pick up only one local channel, but signal loss is more often the...
first of all, make sure all your connections are secure and threaded all the way in. Next, go to the main menu and press 5 (configuration) and press 1 (search for channels) if this doesn't work, press 4(signal strength meter) and see how strong your signal is. You may just need to re-position your antennae. If all else fails try system reset(number 5) and repeat search for channels. I've had similiar experiences with mine but I have a 62% signal strength and still get 20-something channels. Hope this helps.
Oct 11, 2009 | Televison & Video
Cant figure out how to set TV to cable setting
The company's page for this set is here. There's a link toward the bottom to download the user's manual.
If I read the manual correctly, you're out of luck without an external tuner such as a cable box. This set was made for the European market and its tuning system isn't fully compatible with that used in the US. There's a "channel swap" function which lets you reassign the channels it finds to whatever channel number you want, and it's described in the manual. I assume that's to allow for the different frequency/channel number assignments in use in all the areas it tries to cover. The set's tuner just may not be able to pick up all the channels on your cable system. As long as it gets US channel 3 or 4 correctly, you can use the set with a cable box or video recorder that properly tunes the cable channels.
Apr 23, 2009 | Hitachi 46W500 46 in. TV/DVD Combo
TRutech 15" LCD does not pick up all channels
Check your TV settings and make sure your tuning is set for cable (may say "cable" or "CATV"). Right now you'll probably find it set for "air". If the TV is set to tune off-the-air, cable channels 2 through 13 work normally, but above that they aren't detected. Once you set the tuning mode to cable, rescan channels and you should have them all.
Apr 01, 2009 | TruTech PLV1615T 15 in. LCD Television
Problem with tuning digital channel
I would believe from what you said, you have solved your problem. You will need a UHF antenna to receive the signal. Walmart or Radio Shack has a great amplified antenna that will work for you.
Mike
Mar 22, 2009 | Televison & Video
How do I digitally tune my westinghouse TV SK32H24OS. Lost manua
The easiest way might be to unplug the power from the set for several minutes, plug it back in and then run through the setup procedure. You are specifically looking for the channel auto scan function.
Feb 25, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Digital TV not picking up all channels
TV is searching for over the air channels. Select in the main menu to go from over the air to cable channels and you should be fine.
Nov 19, 2008 | Televison & Video
Car radio cd player - DEH-405 unable to tune radio accurately
Check for proper ground on antenna also check radio's tuner I have seen some DEH-405's with crappy solder work on the tuners causing intermittent channel pick up
Oct 13, 2008 | Pioneer Car Audio & Video
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
