Question about Rocstor Storage EAGLEROC E9 1 TB FireWire 400 (1394a) Hard Drive
Blue light is off and back up fails - Rocstor Storage EAGLEROC E9 1 TB FireWire 400 (1394a) Hard Drive
    Genius:
  • 1,552 Answers
The power-supply to the ROCSTOR is failing -- no power results in no light, and no access to the disk-drive.
Posted on Apr 20, 2015
  • Nick Logan
    Nick Logan Apr 20, 2015
    Thanks Anon. It is still humming but I will try a new power cord and I have ordered a new FireWire incase it has deteriorated. Small change rather than replacing the whole thing. I repaired it with my Mac and it says there is nothing wrong with the HD.
JVC HD-56FN97 when turned on blue light is solid,red ligt blinks a few times and goes out. My picture is very dark despite adjustments I make in the menu, any help or feed back apreciated.
The set does use a lamp for a light source and average life is 2 years or 2000 hours---many lamps before they actually fail get to be darker.
Dec 04, 2012 | JVC HD-56FN97 56" Television
My wifi doesnt work
First unplug the power then plug back in it will restart. you should see the front lights flash as it resets if that fails read on... The blue to light will rotated blue led if wifi is working. double check your lan cord coming from your dsl,cable or sat box.
on the back there is a small hole use a pin to hard reset it. you have to hold the pin in for around 10 seconds. This will reset it factory default. You may have to log into it to enable wifi. usually after the reset. type 192.168.1.1 or http://www.routerlogin.net or http://www.routerlogin.com into your browser
a login screen should appear.
Username: admin
password: password or 1234
these are the normal default but may have been changed by someone setting up your router.
Router do fail often they just die out of the blue. this is an older wifi router failure may have occurred. if no lights flash or regain a solid status then it may have died.. good luck
Jul 07, 2012 | NetGear RangeMax WPN824 Wireless Router...
My tv screen when on turns yellow then after a while it will switch back to normal colors what can be wrong with it....
Televisions covered: all Projection with yellow picture, but not Projection TVs with a yellowish tint surrounding objects in a nearly normal picture.
Yellow = red + green
normal picture = red + blue + green (RGB). See illustration.
Fig. 1 Additive color mixing in an RGB monitor, or RGB Projection TV.
The circuitry powering your blue output, or the blue light engine itself is starting to fail.
Operating Theory:
The lamp module shines a bright light into the optical unit; there are a series of lens and baffles, and at the top of the light engine, a lens puts the picture into a mirror which is reflected onto the screen; All video and color is processed thru the light engine. Blue most commonly fails first, leaving a yellow picture.
Dec 26, 2011 | Mitsubishi WS-55805 55" Rear Projection...
Monitor will not come on, blue light just
Check for leaking/bulging caps in the power supply first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 02, 2010 | Samsung 204T 20" LCD Monitor
Tv lights blink, tv not turning on
HI, the fly back transformer has failed in your unit. this will occur if the dust level is high inside the set. the dust will settle on the cooper windings and, create an arch that will short out the entire power sector of this unit.
The fly back is usually the first to take the hit. replacing this will fix this issue.
Jul 11, 2009 | Televison & Video
Hitachi Plasma TV model P50H401
I think you have problems with the digital main PWB.
If the power PWB failed, turn off and change the pilot ligth to red.
Aug 31, 2008 | Hitachi P50H401 50 in. Plasma HDTV
Insignia NS-32LCD Backlight or Inverter bad???
If you've done the flash light test, it could be the inverter board became defective but it could also be that the power supply does not provide the +24VDC to the back light inverter board.
If you could do the +24VDC test using a voltmeter then we can say for sure that the back light inverter board is defective.
Let me know if you need further assistance.
Aug 21, 2008 | Insignia IS-LCDTV32 32 in. Television
Blinking standby light (6 times)
Sounds like the blue CRT is failing. You might be able to squeeze a little more life out of it by adjusting the blue screen control, but it will fail again very soon and the blue tube will need replaced.
Feb 13, 2008 | Sony KP-57WS500 57" Rear Projection...
Rocstor Storage EAGLEROC E9 1 TB FireWire 400 (1394a) Hard Drive Logo
145 people viewed this question
Top Rocstor Storage Computers & Internet Experts
David Payne
David Payne
Are you a Rocstor Storage Computer and Internet Expert? Answer questions, earn points and help others
