Nokia C3 mobile shows no sim card means: 1.Might be your sim card got corrupt 2.Sim card slot in your handset may be damaged 3.Sim IC got damaged these all are the reason for this problem soluion 1.Check your sim on other mobiles. 2.Change you Sim slot after checking it. 3.Lastly check your SIM IC if neccesary change it
your sim card may be corrupted check the sam sim in another mobile if it works on that mobile then your sim read ic may be corrupted so please contact your nearest sevice professional
There are two things causing this problem,either your phone is not registered to the Sim card's network or your Sim card is corrupt
To find out where the problem has come from,you should try another Sim with your phone, if the Sim does not work then the phone is registered to a particular network and no other Sim card will work on it.
If you try another Sim card and it works then your Sim card is corrupt and you should replace it.but to be double sure,test the Sim card on another phone to see if it works,if it does then your phone is not compatible with the Sim card's network but if it does not work then your Sim has to be changed
ONCE MEMORY CARD IS CORRUPTED THEN IT WILL NOT REPAIR, BUT U TRY TO FORMAT IT, IF IT WILL BE. AND FOR DUAL SIM, YOU CAN USE DOUBLE SIM PLATE, WILL BE PURCHASE FROM THE MARKET.
this is my phone, so i don't know when this started. but i took out the battery and sim card, reinserted it, restarted it. but only SIM error on screen.. would not go to home screen. is the sim card corrupted?
Kindly Suggest
