Question about Hardware & Accessories
I asked a question about a water sprinkler controller and it shows up on the PHONE page. Not sure how to get to the right area.
  • 744 Answers
What is the question about the sprinkler controller?
Posted on Apr 19, 2015
Testimonial: "Kwikdial KD4 Manual Stations not working. Any button I press, the water icon flashes on off on off. Pulled plug, still no luck."
  • 2 more comments
  •  Kaye Day
    Kaye Day Apr 19, 2015
    Connect “Reset” contact momentarily with the tip of a flat bladed screwdriver. The display will blink; controller is reset to default program. See pg 3
  •  Kaye Day
    microprocessor has stopped
  •  Kaye Day
    http://www.irritrol.com/manuals/manual_k...
  •  Kaye Day
    pg 20
I have Intermatic sprinkler model T8845pv. I want to set it for daily watering in only one of 8 zones. When I remove the gold pins in the main dial and locate the zone I want to water, it waters the...
Intermatic sprinkler timers are 24 hour repeat cycle, with day-skipper option.
The timer does not change zones. The timer just turns ON-and-OFF at scheduled times.
Each tripper represents 12-15 minutes of watering. And then the timer circuit turns OFF.
When timer circuit turns OFF, the sprinkler system is designed to advance to next zone each time.
So when the timer circuit turns OFF and then turns ON again, your sprinkler control starts watering the next zone. This is the way sprinkler systems are designed.
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#sprinkler
If you had a sprinkler system with 1 zone, or could change your sprinkler system to 1 zone on certain days, then the timer would turn that zone on-off each time.
Call a local sprinkler company and see if they have a dual control or some solution >> but sprinkler controls are outside my area of expertise. I am timer expert.
You could solve problem with two separate sprinkler systems, but that would require two timers. I have never seen a 2-channel sprinkler timer. There are electronic two-channel timers that can handle two different programming schedules with minimum 1 minute on-off, and these timers can cost a few hundred dollars up to thousands, PLUS cost of the dual sprinkler system. Add a comment and let me know if two-channel timers are something you want information on.
Apr 27, 2011 | Intermatic R8806P101C -...
I have misplaced my manual for the 24-hour timer, and I want to make sure I am using the "tripper" clips appropriately: do I place one in each slot that I want the sprinkler zone to run--and...
This device is simply a 24 hour timer. It has a special enclosure classified as "Rain Tight" that helps prevent rain from entering - as water from a hose directed at it would enter the enclosure causing damage to the timer.
It is NOT a timer designed to operate a traditional pop-up sprinkler system. Those timing devices allow water to flow into the lawn sprinkler system and spray out from a certain area of sprinklers for a predetermined amount of time, then switches this area or zone off and turns on the next. This continues until all zones have watered the area where sprinklers have been installed.
The device you are asking about simply switches power on and off to one load. It can not control multiple loads - or as in your case "zones". You would install ON trippers at the time of day on the yellow time disc when the load would be ON and install OFF tripper when the load should be turned OFF. If the load were a light, you could turn this light on and off many times a day - dependent only on how many ON and OFF trippers you installed on the yellow time disc.
A sprinkler timer must be selected instead. This will allow you to select the number of days between watering, will operate many zones, control of how long the water is to remain on to each zone, detect if it has recently rained or if it is currently raining, etc. One is pictured below:
I hope this helps. If you have additional questions or comments, please provide the manufacturer's name AND the exact model number of the timer you are talking about. Good luck. Please rate my reply. Thank you.
Apr 13, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
How do you wire, wires from sprinkler to unit and wire from power
You posted under R8806 Intermatic sprinkler timer:
http://www.intermatic.com/products/timers/mechanical%20time%20switches/sprinkler%20irrigation%20timers.aspx
To see image of timer:
http://www.drillspot.com/products/85291/Intermatic_R8806R101C_Irrigation_Sprinkler_Timer
If this is not your product, then add a comment
You did not say if timer is 120Volt or 240Volt.
This information is on the door.
R8806P101 is 240Volt timer has 4 terminals from left to right. 1-2-3-4
240V Hot wires from breaker connect to terminals 1 and 3
Wires going to pump connect to terminals 2 and 4
R88 series 120Volt timer has same terminals as above.
120V Black hot wire from breaker connect to terminal 1
White neutral wire from breaker box connects to terminal 3
Black wire going to pump connects to terminal 2
White wire going to pump connects to terminal 4
Fixya also offers live phone support for a price.
Fixya phone expert can answer your questions by asking which timer you have and what circuit you are trying to control.
Dec 18, 2010 | Intermatic R8806P101C -...
I have a Orbit 57161 Sprinkler System 6-Station Standard Indoor Mounted Control Timer with rainbird sprinklers the issue that I have is the sprinklers stay on and don;t turn off.what do i do?
Manual:
http://www.orbitonline.com/lib/media/57114-14%20rF_Eng.pdf
Website:
http://www.orbitonline.com/products/Timers/02/01/19/671/
Tech service 1-800-488-6156
Timer has 4 year warranty
The manual has troubleshooting
Looking through the manual I can see potential trouble areas:
-Water pressure too high > 60 psi is ordinary household pressure > order Brady BTG pressure gauge that connects to hose
-Overlapping times are 'stacked' by timer ... but 'more than one start time' is listed as cause of stations turning on when not supposed to >> reset and re-program timer, make chart of on-off times
-Weak or missing AA batteries >> clean terminal inside timer and replace batteries
-Hard water deposits or unfiltered water clogging water valve (water softeners frequently have this problem) >>> see if vinegar or CLR cleaner can help flush water valve >>> add sediment filter in front of timer
-Fuse blown
-Bad solenoid
-A combination of problems listed above with sediment -or- solenoid as main suspects
Oct 04, 2010 | Orbit Sprinkler System Power Source...
I have low water pressure on my rainbird sprinkler system. how can i adjust it?
There are several ways to adjust water pressure on sprinkler systems. First you have to determine if there is a problem with the sprinkler system itself. Things to look for:
1.) make sure that all valves including the main are all the way open.
2.) Inspect the sprinkler heads for clogging. Sediment and debris can also clog your sprinkler heads. Some debris removal may be required.
3.) You make have too many sprinklers operating by one valve. You may need to divide a zone and add another valve to increase water pressure.
4.) If all else fails. You can install a breather intake cap to allow air into your sprinkler system thus increasing GPM (gallon per minute)flow.
5.) one of the biggest mistakes that peopel make is that they undersize the water pipe size to save money. Typically you want to use 3/4" PVC pipe for your main runs and tee into 1/2" PVC for your sprinkler heads.
Good luck. I hope this helps.
Jul 20, 2010 | Rain Bird Hardware & Accessories
Brass Champion Sprinkler Valve
The lowest sprinkler head usually leaks until all the water is out of the system. The valve that controls the sprinkler system has a vaccum breaker valve on it. When there is no pressure from the water main the vaccum valve opens allowing the sprinklers to leak water so the house water won't get contaminated from the grass and dirt in your yard.
Jul 27, 2008 | Electrical Supplies
Hardware & Accessories Logo
106 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
