Question about Harman Kardon AVR 235 Receiver
No display but have sound
Sound working but no display on Main Information Display
    Habit-Forming:
    New Friend:
  • 91 Answers
HI
Try resetting the system . if this doesn't work.
"Service" is needed .
To clear the AVR's entire system memory including
tuner presets, output level settings, delay
times and speaker configuration data.
1: first put the unit in Standby by pressing the System
Power Control button
2. Next press and hold the Tone Mode button 8 for three seconds.
The unit will turn on automatically.
this will clear all the proccessor.
Note that
once you have cleared the memory in this manner,
it is necessary to re-establish all system configuration
settings and tuner presets.
Good luck
Kind Regards
Posted on Jun 18, 2016
2 Suggested Answers
smarthome2
  • 1114 Answers
SOURCE: no sound,no video,front panel display will display.harman kardon
Check your audio settings on the main menu of the receiver. The audio input should be set to "auto" Next, make sure you don't have the unit in "6 channel input" mode or "direct" mode. This is usually a small button on the front panel. If you check all this and you still have a problem, post a comment and I will help you troubleshoot some more. Hope this helps
Posted on Jul 01, 2009
My 2hp Panasonic is blinking when turn on and the compressor stop working while the outdoor fan will be blowing cool air.
1. Turn power on.
2. Press the CHECK button on the remote controller
continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote
controller. The code "H00" (no abnormality) will be
displayed and signal will be transmitted to the main
unit. The power LED lights up. If no abnormality is
stored in the memory, three beeps sound will be
heard.
5. Every press of the button (up or down) will increase
abnormality numbers and transmit abnormality code
signal to the main unit.
6. When the latest abnormality code on the main unit
and code transmitted from the remote controller are
matched, power LED will light up for 30 seconds and
a beep sound (continuously for 4 seconds) will be
heard. If no codes are matched, power LED will light
up for 0.5 seconds and no sound will be heard.
Jan 26, 2016 | Panasonic Heating & Cooling
Lg 50pc55 plasma- has sound but no display??
Quite possible-----replace all bad ones and also if possible the voltages coming out of that board need to be tested---to be honest other than the caps it sounds like a main board issue. The set may have been run too long with the bad caps.
Dec 08, 2012 | Televison & Video
I HAVE A SHARP LC20SH3U WITH SOUND BUT NO PICTURE
My best "guess" based on description is either the main board or the display panel itself is bad.
May 30, 2012 | Sharp LC-20SH3U 20 in. EDTV-Ready LCD...
I have a Yamaha RX-V467 receiver, and am wondering if there is something wrong. Before mounting the surrounds on the wall, but after using them for a few days (in both instances using the Rocketfish Rear...
It sounds like you digital assignments are either hosed or not working. Most AV receivers will TRY the digital path first and drop to an analog path if the bitstream is absent or corrupt. Upon restortation it might switch back automatically.
Treat it like a new installation and thumb through the manual and settings.
Mar 29, 2011 | Yamaha RXV467 Receiver
Refrigerator temperature control panel not lit. This happened last week but corrected itself....not sure how....but now display panel is off for good, it seems. Main Refrigerator lights are still working,...
Your Refrigerator Has a main controlboard located in the rear of the machine. This Controlboard sends power and reads the user information. if your user display (Temp Control panel) is not working it can only be 2 things The user display or the main controlboard.
As far a the refrigerator working without it, I would not trust it.
The clicking noise is a relay on the main control.
Usualy when I here this relay go on and off rapidly, there is a problem whith the main controlboard.
The big problem with this is why did the main control go out ? some other componet on the refrigerator could be the cause. A comon cause in the past has been the evaperator fan motor.
Jan 15, 2010 | Refrigerators
L322 reg02 radio display not workin no sound on tv or sat nav. visual display working on sat nav and tv but no sound. seems as if there is no power to left hand side of unit. righthand buttons working but...
solved the problem after speaking to the main dealers, disconnected battery for fifteen minutes then reconnected which rebooted system. Range rover say just like your home computer its got glitches so rebooting works, common problem in cold weather.
Jan 13, 2010 | Car Audio & Video
No sound,no video,front panel display will display.harman kardon
Jun 30, 2009 | Harman Kardon AVR 140 Receiver
BLANK DISPLAY AND CLICKING SOUND
This is the main control board failing. My symptoms were identical (intermittent display and clicking), and eventually the clicking didn't go away and the freezer got hot. I replaced the main board yesterday and all is well (display fixed and no clicking). I was able to find the correct part number using the GE website (entered refrigerator model PD22S1S and then selected PDS22S1SARSS from the drop-down list). My part number was WR55X10656. The GE price was shown as $157.50, but I bought mine from ApplianceZone.com for $101.68. Hope this helps.
Dec 01, 2008 | GE PDS22SIS Bottom Freezer Refrigerator
Sound problem on Technika LCD19-907
The retuning process is as follows:
  1. Press the [i+] or MENU button on the remote control to display the DIGITAL INFO menu.
  2. Press the BLUE button to display the MAIN MENU.
  3. Press the UP or DOWN buttons to highlight AUTO TUNING then press the OK button to display the AUTO TUNING MENU.
  4. Press the RED button to start the auto tuning process for all available digital channels.
  5. Wait for the process to complete.
If you wish to CANCEL the auto tuning process whilst it is processing then press the BLUE button at any time.
You may lose some channels when you retune the TV as the channels have been rearranged. To locate them look at the EPG although you may still find that some channels are no longer available on FREEVIEW. See the following link for additional information
http://www.freeview.co.uk/_retuneinfo/
If the above process does not work then check the link above for additional information and also visit the accompanying site links below to find more information for your model of TV / FREEVIEW box.
For troubleshooting the retune procedure visit http://tvretune.co.uk/troubleshooting/
For specific model information visit http://tvretune.co.uk/productmanuals/
Jun 19, 2008 | Sony KDF-E60A20 60 in. LCD HDTV
Harman Kardon AVR 235 Receiver Logo
114 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
