Question about Refrigerators
Suddenly not cold
Freezer all of a sudden warmed up to 42 degrees and the fridge side is 72 degrees! I turned the control on both to the coldest settings and still the same is this a fixable problem or is it on its way out?
    Genius:
  • Refrigerators Master
  • 2,432 Answers
More than likely it has lost its gas . Re gas it and check for leaks.
Posted on Apr 19, 2015
catriver
  • 878 Answers
SOURCE: freezer/fridge won't get cold enough
Madezmom, you have a defrost issue. If your model starts with 106 you more than likley have a bad defrost bi-metal, I will attach a picture of bad one. This sits on the evaporator in the freezer section behind the panel. You will have to remove the shelves and remove the back panel. Defrost the evaporator completely. The part number for the bi-metal is 2196155. See if yours is bulged like the one in the attached photo. If so, that's your problem..Catriver..post back.
Posted on Aug 28, 2006
  • 306 Answers
SOURCE: Fridge not keeping food cold.
When you open door to freezer do you hear a fan inside that compartment blowing? If you don't the fan motor is shot and will need to be replaced.
Posted on Nov 26, 2008
  • 2418 Answers
SOURCE: Inglis Fridge model# IRT184300, warm fridge, cold freezer
There is a fan in the top of the refrig that is not turning. Ck for that fan and pos. ice build up in between.
Posted on Mar 10, 2009
Sea Breeze
  • 4654 Answers
SOURCE: freezer is ice cold, fridge won't cool lower than 42*
Sounds like it's not defrosting, so unplug open freezer back panel and use a hair dryer to melt ice from evaporator coil. Your refrigerator has a defrost timer on bottom near floor, but if freezer is frozen we need to defrost it so we can make sure there is not some other problem. Let me know when you are ready, Sea Breeze
Posted on Apr 23, 2009
SOURCE: GE TFX26KRDA WW 2001 side by side refrig/freezer w warm fridge
Cleaned the condenser coils which were dusty but not severely so. Checked the evaporator coils which were NOT iced. Reset the fridge to coldest setting and freezer to #5 (mid range of temperature) and waited a full 36 hours. Fridge temp is 40 F and freezer is about 0F. Not sure what is different except coldest setting on fridge. Warm weather is here but not warm enough to require AC. Temps in late afternoon in house about 77-80F. Any thoughts are appreciated because I suspect this problem is not completely resolved.
Posted on Jun 21, 2009
True T-49 refrigerator/freezer temperature calibration
Contact the manufacture, it is most likely going to be covered under warranty. If the knob is not removable, (check for a set screw on the side of the knob it will take a small allen wrench) Then the thermostat (temp controller) will need to be replaced, if it isn't a style that you can calibrate.
Jan 30, 2014 | True Refrigeration True T-49 2 Door Bottom...
Maytag side by side model MSD2757AEB suddenly stopped working. The freezer is thawing and dripping fluid on the bottom left side of fridge. It is still running and is putting out cold air, but it doesn't...
Could be that you have a bad freezer (defrost) thermostat and it is not "shutting off" after a defrost. Do you feel heat (DON'T touch the panel) near the bottom rear panel inside the freezer? Also, could be a Adaptive Defrost control problem.
http://refrigeratorheaterrepair.blogspot.com/
Dec 28, 2010 | Refrigerators
Refrigerator too warm on coldest setting
The refrigerator coos from the bleed over from the freezer, See if the fan in the freezer is working properly and the crossover duct/vet is not obstructed or close.. Ck to make sure the control in the fridge is working,
Nov 21, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Refrigerator top rack is warm. Temperature shows 65 degrees
if your freezer can make ice and the ice is dry, the problem is simply air flow into the refig section. A very common cause for a service call that wasnt needed for reefers is the settings. One setting OFF 1-10 usually, operates the compressor. The remaining setting will say , for colder freezer or similar, It opens a little flapper door between the freezer and the fridge section. If you set that one to max or coldest freezer it will actually starve out the fridge section for air ,and you get a cold freezer and warmer box! It happens everytime someone has the problem , its too warm! they peg both controls to coldest! The compressor will coll the freezer sufficiently even if set to 1 and the fridge should be cool too if the setting isnt pegged to coldest setting thus closing down fridge air and making the freezer colder which isnt ever required!
Aug 25, 2009 | Jenn-Air JSD2695KES Side by Side...
Jun 20, 2009 | GE Hotpoint Top-Freezer Refrigerator
Freezer cold not frozen, fridge cool but not cold enough.
HI, simply replacing the thermostat and air diffuser assembly will fix this cold control issue you are experiencing.
May 24, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Freezer -5 Fridge 50
You have a defrost problem. Refrigerator gets cold via freezer. If blocked with frost, will restrict cold air into refrigerator.
Apr 26, 2009 | Refrigerators
Kenmore Side by Side Refrigerator too cold
On a fridge freezer only the fridge temperature is monitored. In a cold location the fridge might not even need cooling and the freezer would get too warm but the thing won't care.
If the fridge sensor sees it as too warm then it will keep the motor running and the first thing to get really cold is the freezer.
Remember the freezing part is not temperature controlled ion a fridgefreezer.
Apr 28, 2017 | Refrigerators
Fridge not working
I've had this happen to my Kenmore 73503 several times. The 1st time took me a few hours to figure out what the problem was.
Basically the fridge is cooled from the freezer, so when you say your freezer is -2 degrees, it's a big tip off to the problem.
If you look very close in the freezer compartment at the back, you'll notice an opening with a little door at the top of the freezer compartment. This opening extends up the inside of the back of the fridge to the top of the fridge area via a square plastic tube.
Basically what happens in my fridge is the family loads the freezer to high especially at the top/back. This restricts or closes off the opening for the cold air to the fridge portion of the appliance ....resulting in a warm fridge, but cold freezer. Just remove the articles at the back of the freezer to correct problem. (It will take a few hours for the cold air to cool the fridge down)
Note: the temperature control unit in the fridge area controls the little door at the top of the freezer compartment, so if you haven't blocked off the opening, the next place to look would be either at the mechanical parts of the little door or the temperature control unit itself in the fridge
Mar 22, 2008 | Kenmore 73503 Stainless Steel Bottom...
Burnt smell inside freezer.
Generally speaking it is the refrigerator control that controls the compressor operation. Refrigerator is cooled by air from the freezer. When the refrigerator gets down to its designed temperature it shuts off the compressor. The freezer control determines how much air is allowed to flow into the refrigerator section and there-by controls the freezer temperature.
Mar 18, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
54 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
