Question about Optics
When I Insert the SD card to update firmware, The Power lamp switch flashes and hand-controller Is blank! HElllppp
    Top Expert:
  • 6,702 Answers
I don't know what you want to update, but most of the time a device, made so it can update the firmware, needs a full operating computer. As soon as it does not work, you can't be sure the system can transfer the software to the correct place in the flash memory. You could be lucky (I don't think you are) You could try switching off the system, remove the SD card and switch on.
But I'm afraid something went wrong during the transfer of the data (could be just a power glitch) and now your memory has a part of the new program and a part of the old program, making it complete worthless.
I'm afraid you have to visit a certified repair shop. and ask them to flash the correct firmware. They have special tools and connectors to access the flash memory direct.
Just contact a service centre and explain what you experienced and ask them what to do. Don't forget to ask what it will cost, before bringing it in for repairs.
Next time, please add the device name, brand, model and OS in the question. Thanks
Posted on Apr 19, 2015
Richo afico 5002 code sc 878
1. Improper firmware update.
2. SD Card size greater than 2 GB used.
3. Multiple ROM data folders in SD Card.
4. Improper Java firmware update.
5. Power failure during firmware update.
6. Power line issues on the outlet.
Replacement of the Controller Board is necessary in case SC Code 878 occurs.
Apr 11, 2017 | Ricoh Aficio Office Equipment & Supplies
Firmware updade
Firmware can only be downloaded by someone with "My Ricoh" access. If you have the Firmware or you are able to get it, just create a "romdata" folder on a SD card and dump the .fwu file in the "romdata" folder. Switch your machine off and insert the SD card into slot 2 on the machine controller. Start machine up and select the firmware you want to update. Machine will reboot when its done. If it doesn't than switch the machine off and remove the SD card and power machine up again. Now you are done.
May 24, 2016 | Ricoh Aficio Office Equipment & Supplies
We have a Meade LS telescope. When power on ... no sound or instruction is heard ... the hand box only power on with red background led but nothing is appeared ... what the problem
Two possibilities- corrupted firmware and or a bad hand controller cable. Re-load the firmware; if that does not do it then get a new hand controller cable. Beyond that it will be bad electronics inside the scope and it will need to be sent back to Meade for repair.
Clear skies,
TelescopeMan
Feb 03, 2015 | Meade LS 8" ACF 08100310 Telescope
Why does kocaso scan my SD card and reset to factory settings every time I power it on?
You need to reload the firmware as it cannot find working android operating system. It also cannot find the firmware program on the SD card which needs to be blank, when you write the firmware load on a PC.
See instructions here. Support Firmware
Jan 12, 2015 | Kocaso M M9100 9-Inch 8 GB Tablet
How to reset Sylvania notebook synet07526
Download your version of CE for smartbooks at http://netbook.poodwaddle.com/ unzip to to blank FAT32 formatted SD card: in root (dont put in folder, just put it on card) unzip CE package and copy script folder contents to root (no folder) so when device looks at SD card, it sees contents of script folder first. Use power supply when flashing. insert card, then power on. You should see device reading and updating itself.
Jan 03, 2015 | Sylvania Computers & Internet
My Nikon Coolpix S220 camera getting problem. Upon the power switch press to ON the power-on lamp (green lamp)blink for few minutes but the LCD monitor never turn ON. After the green lamp OFF then the...
I cant detect my pics in my laptop from the sd cars. But I can see in my camera when I insert the same sd card. Is there any problem with sd card or any virus effected? How to upgrade the sd card. please help me out.
Feb 01, 2011 | Nikon Coolpix S220 - Aqua Green 2.5" LCD...
My Toshiba Model no. 65HM167 does not power up. The lamp light on front of t.v. flashes and thats about it. I replaced the lamp but still no go. Help.
CK the Lamp Fan if it stops running Lamp will not light and if thats ok Ballast Board it is what turns Lamp on!
Visit Encompass Parts Distrubtion for Parts List and numbers 1-800-638-3328
Mar 23, 2010 | Toshiba 65HM167 65" Projection Television
Tv will not turn on. lamp light is flashing 3 times. i put a new lamp in it and have the same problem
The boot data is corrupted. Download the firmware update from Toshiba and unzip the files and folders,copy the unzipped files & folders to a SD card (like a camera uses). Unplug the tv and insert the card into the slot hidden behind the cover above the HDMI inputs. Plug in the tv and watch the yellow blinking stop and a solid blue will light when done. Unplug the tv, remove the card,plug in the tv and all will be good. You could now install the update per it's instructions.
www.tacp.toshiba.com/customersupport/model_firmware.asp?model=65hm167
Feb 24, 2010 | Toshiba 65HM167 65" Projection Television
Power issues with panasonic tc32lx70
You need to go to Panasonic dot com search for TC-32LX70, go to software updates. Use a blank SD card and format it save the firmware file SDDL.SEC to it. Carefully open the "service panel" you may need to remove the entire back case? since it seems the frame is holding the service panel down. 1)power on the TV
2)insert the SDcard with firmware update into the rear(lx70) or the sdcard slot on the side(lx700)
3)follow the on-screen instructions.
4)when it's finished, remove the SD card.
turn off or unplug for 30+ seconds
then plug it back in.
5)power on.
6) perform the first time setup.
Mar 12, 2009 | Panasonic TC-32LX70 Television
System Error oeo1 on Casio Digital Camera QV-R40
Go to the following website:
http://www.oborona.net/stuff/qv-r40/eng/index.html
unfortunately it does not translate very well from its native Russian, but a potted version of what you need to do is as follows:
1. Download the Casio QV-R40 firmware to a safe place on your PC, unzip it, and put a copy of the unzipped binary file onto a blank or spare SD card.
2. Insert the SD card in the camera, and then hold the Menu button pressed in while pressing the On/Off button.
3. A menu will appear on the screen saying Program Update, Yes/No
4. Select Yes and press the SET button.
5. After a short while you should get a message to say the update is complete. Switch off the camera and remove the SD card, and put in another SD card.
6. Switch on the camera, and hopefully it will restart as new. You will need to enter time-zone, date, time etc.
It has worked for me!
Jul 19, 2008 | Casio QV-R40 Digital Camera
Optics Logo
239 people viewed this question
Top Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you an Optic Expert? Answer questions, earn points and help others
