Question about Tablets & eReaders
My digiland android tablet keeps forceclosiNg all apps I've factory reset it slowly reinstalled apps one at a time even wiped sd card how do I get it to stop this I've tried virus and malware apps
  • 274 Answers
SOURCE: my pandigital keep makeing me forceclose evrythingand i cant do nothing
It may the processor problem. or reinstall it and see.
Another method is to contact the supplier for help if you could not fix it.
Android 4.0 Tablet PC
Posted on Feb 08, 2012
  • 82 Answers
SOURCE: Freelander android PD 20-3G 7"
try replace the battery or the charger
Posted on Jun 05, 2013
  • 21 Answers
SOURCE: Hi I just got a tablet online and it doesn't have
Just make sure with the play store settings, whether you have sign in with your G mail account or not. If no just sign in and try else register as a new user and try. If found still there were an error. Just try to restore the tablet. If you again found the same error then, shutdown the tablet and press power + volume up button up to 15 seconds, so that you will get restore option there and restore through that. Definitely it will work for you.
Posted on Aug 01, 2013
  • 22 Answers
SOURCE: have an android tablet but have lost an inside SD
Well their is plently of websites out their that you can download "flashes" like the software, http://www.redmondpie.com/download-and-install-android-2.3.6-gingerbread-grk39f-on-nexus-one-how-to-tutorial/ this is a good website for getting the software depending on what version of android you have and then tells you how to do it incase you dont know.
Thanks
Posted on Aug 06, 2013
De Engineer
  • 247 Answers
SOURCE: how do i fix my pioneer tablet after reset that left it saying 0.00 space & 0.00 available & wont let me reinstall apps?
Remove apps & clean out memory space. Then download and reinstall. Or you may be able to add a larger external memory card.
Posted on Jun 05, 2014
How can i remove a virus from my tablet
When you reset, make sure your SD card is not in the slot. Take it out and look for any apps on your SD card using a windows computer and a SD hub. Using windows explorer delete anything you don't recognize using windows. Then reset your tablet again, using a USB cord and SD hub to connect your tablet to windows. When you see the little windows pop up at the bottom left, click on it again to see what's on your tablet. In fact, I would do this before you reset and see what apps are there and delete ones you think are bad.
May 11, 2016 | ZEEPAD 7DRK Dual Core 4.2 Green Android...
I forgot my password for my trio stealth g5 7 can u help me reset it or something?
I Forgot My Password To Unlock To My Tablet? Factory Data Reset - Factory Data Reset can be accessed through your Settings which can be found either on your main screen or in your Apps/Widgets (tap on 6 squares in upper right hand corner) menu. From Settings, on the left hand column, tap on Backup and Reset. On the right hand side tap on Factory Data Reset. This will take you to a screen that will give you the option to check the Erase SD Card option which, when checked, will ensure that your pictures and any other personal information on this device will delete during the reset. Last, tap on Reset Tablet and Erase Everything.
  1. Tap on Settings.
  2. Tap on Backup and Reset on the left hand column.
  3. Tap on Factory Data Reset on right hand side.
  4. Tap on Erase SD Card. (optional)
  5. Tap on Reset Tablet and Erase Everything.
Or
Hard Reset G2 - In the case of password lockouts or freezing, doing a hard reset on your android device could help you get back to the factory defaults. First you need to make sure your tablet is powered off. Hold down on the Volume + button and hold down the Power button at the same time. As soon as the tablet's screen turns on let go of the Power button but keep the Volume + button held down until you see a large Android in the center of the screen. At this point you will see a screen with boot options. Use the Volume - button to go down to Wipe Data Factory Reset and tap the Power button to select this option. On the next screen use the Volume - button again to go down to Yes and use the Power button to select. At this point it will be going through the wiping and resetting process. When it's done you will see the first screen you came to when you first started the setup. Just tap the Power button to select Reboot System Now.
  1. Make sure tablet is powered off.
  2. Hold down Volume + button and Power button at same time.
  3. When screen comes on let go of Power button.
  4. When the large Android shows on screen let go of Volume + button.
  5. Use Volume - button to scroll to Wipe Data/ Factory Reset
  6. Tap Power button to select.
  7. Use Volume - button to scroll to Yes.
  8. Tap Power button to select.
  9. Tap Power button to select Reboot System Now.
Jan 04, 2016 | Tablets & eReaders
Digiland dl801w. How do I reset?
How to hard reset digiland dl801w? - Ask Me Fast
www.askmefast.com > Consumer Electronics > Other - Electronics > Reset
source: How do i reset my digiland dl701q tablet when forgot pattern? ... up button but it doesn`t take me to a menu to do a ยท Hard reset tablet digiland dl801w.
How To Factory Reset Windows Computer Tablet ... - YouTube
? 2:02
https://www.youtube.com/watch?v=bfzSp3rxb18
May 14, 2015 - Uploaded by JrTech
How To Factory Reset Windows Computer Tablet ' Windows 8 Tutorial Wipe Data & Memory Hey techies ...
Digiland DL700D Hard Reset - YouTube
Jun 08, 2015 | Tablets & eReaders
How to reset a factory fasttouch 7inch tablet
Hard reset or factory wipe is a method of formatting any Android device ( tablet or mobile). By doing hard reset all the apps and files that are installed or created by the user will deleted. Even the memory card will get formatted. So before going for hard reset or factory swipe, it is suggested to remove the memory card if you do not want data to be erased
For simple factory reset the process is follows:
Sponsored
  • Goto settings -> Back & reset -> factory data reset
After factory reset, only pre installed apps and files that came with the device will remain on it.
Feb 19, 2015 | Android 7 inch Tablet
How do set the trio stealth to use an external SD card
I show you one of the many links about using an SD card on an Android tablet or phone:
How to install Android apps to your SD card by default fixedByVonnie
Jan 11, 2015 | Tablets & eReaders
Why does digiland tablet keeps going back to the main screen when I'm on Facebook or YouTube or listening to music
Maybe try factory resetting the tablet. Then reinstalling each app one at a time.
Dec 26, 2014 | Tablets & eReaders
Proscan 8 inch tablet with android 4.1 jelly bean
Sorry, I have no solution to offer. I am in the same situation and resets aren't working. Wondering if OS is deleted and if so, how to reinstall. So frustrating!
Feb 28, 2014 | Proscan 8 4GB Android 4.1 Tablet
My apps on my android tablet have disappeared
Has somebody accidently held the 'Volume Up' key at the same time as switching it on? This can start a system reset wiping all your apps. Were your apps stored on an SD card that somebody has removed? It's also possible that certain malware has been/or still is active on it. Today an ever growing percentage of malware is being targeted at Android, because of it's increasing popularity.
Mar 10, 2013 | Tablets & eReaders
Forgot my password to get into my android table MID M729 the pattern on the top of the tablet
Normally, with Android devices, if you enter the wrong pattern five times in a row, the device will give you an option to enter your Google account information (e-mail address and password). Once you have done this, it will let you reset your security pattern.
If this doesn't work, the next best thing to try would be a firemware The firmware update process will wipe the root of the device (but leave your SD card and books intact), basically resetting it to factory settings, before you even set a security pattern.
Should this fail to work, contact Velocity Micro Support by calling +94756523353
Dec 28, 2012 | mid Archos M729B Android Tablet
Tablets & eReaders Logo
91 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
