Question about Ariens 42 in. 19 HP Kohler Hydrostatic Riding Lawn Tractor
Won't start. In storageempty18 mths. Replaced oil,filter, fuel filter,spark plug, New battery. Fresh gas w/stblzr. Engine cranks but won't turn over.
Ariens 42 19 HP Kohler Hydrostatic #960460002 Twin Cam OHV. purchased '09
  • Kprime
    Kprime Apr 20, 2015
    Kohler SV590-0017 19 Hp, single cylinder, equipped with fuel pump.
  • Ariens Master
  • 1,169 Answers
Your Ariens mower model number is actually 936038 as the other number is the Husqvarna model number.
You should also remove the engine shroud and check for mouse bed and damage wiring.
Although it was stored empty of fuel the carburetor could have had some remaining fuel which could clogged the main jet.
Posted on Apr 20, 2015
    Sergeant:
  • Ariens Expert
  • 187 Answers
Won't start. In storage empty18 mths. Replaced oil, filter, fuel filter, spark plug, New battery. Fresh gas w/stblzr. Engine cranks but won't turn over.
Without the exact engine model, I am not sure which Kohler 19 HP you have. There are different models including single cylinder with fuel pump, single cylinder without fuel pump, and multiple versions of the twin cylinder. Therefore, some parts of this answer include generalizations which may or may not be applicable.
Sooo, with the new battery the starter motor does crank the engine; the engine turns over. This informs us that the engine/bearings, has or have, not frozen up while in storage. However, I believe you are indicating that the engine does not fire up and begin running; it won't start and it won't run.
We know the machine has been in storage 18 months. Was the machine completely emptied of fuel, tank and carburetor, prior to long term storage? That is the question of the day.
I am going to assume the machine was running fine the last time it was used; prior to parking it in storage. That means we are assuming there are no mechanical problems with the engine. I am going to assume, with the installation of new plugs, you checked for spark and all is good in that area. This really leaves us with a fuel system problem.
A mechanically functional (meaning all the internal parts are working, i.e. pistons, valves, etc) engine requires 3 things all at the right time, air under pressure (yes they call that compression), fuel, spark. So the quickest way to start your diagnostics is to remove the cover over the air filter and then remove the air filter. I do not recommend spraying Quick Start.
  1. remove air filter (set it aside for the rest of the diagnostics)
  2. put throttle on fast run (do not choke)
  3. pour an ounce or two (a shot glass, not ½ a beer) of fresh gas into the carburetor
  4. crank engine (15 to 20 seconds, rest to cool the starter, repeat 3-4 times if it does not fire at first).
Removing the air filter and placing the throttle at full speed, with no choke, eliminates the "air intake" question for now. Dumping in the fuel bypasses the fuel related question.
  • ·If the engine fires and runs a bit, then dies, you may have eliminated the spark question and you need to track down any fuel problems.
  • ·If the engine does not fire you likely must tract down a Spark problem.
I understand that you filled the tank with fresh fuel.That is step one, of 7-10 possible steps for getting fuel to the engine. Which brings us tooo..
  • Tracking down fuel problems.
  1. Make sure there is plenty of fresh fuel in tank. High Octane less than one month old. Water in the fuel system will often cause hard starting, low power, backfiring, surging or stalling. Was your tank clean and dry?
  2. Is there a cut off valve at the gas tank? If so check that it is open or working if it is electric.
  3. This step comes from repeated personal experience with JD gas tanks. Remove fuel line from filter and remove the filter, gas should pour out of the hose coming from the tank. (look at the filter before removing it, it should look ¾ full of fuel. If it's not that's a clue to fuel flow problems.) If gas does not pour out remove gas tank cap. If fuel flows now, you need to unclog the cap vent or replace the cap. The vent is that tinnnny little hole in the center of the cap. If the fuel still does not flow then blow air from the filter end of the hose back up through fuel line to blow out any blockage inside the gas tank.
    Do yourself a favor, leave the gas cap off and turn the outlet air on your compressor down below 20 psi. If the tank is nearly full you will blow gas out of the tank. Do this outside if possible; at the very least you need a well ventilated area. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger. Once you have a good fuel flow out the line to the filter, reinstall your FRESH FILTER. Try cranking the engine. If it still does not start move on to the fuel pump and carburetor
  4. Check the fuel pump. The fuel pump system on the twin Koehler and the Twin Briggs are almost identical. This includes most single cylinder engines with fuel pumps. Watch this excellent, eight minute, video to learn how to check the fuel system, including the pump, up to the carburetor. . https://www.youtube.com/watch?v=HAUZUPoopSI
  5. Note: My engine was starting hard and dying in the field this year (March 2015). While doing a valve adjustment, I found a hairline crack in the bend of the vacuum hose powering the fuel pump. It's the short hose running from the valve cover to the fuel pump. The fuel pump will not work if this hose is cracked.
  6. Note: If your engine has a vacuum operated fuel pump it requires crankcase vacuum to drive it. A Reed Valve creates this vacuum. If your reed valve is stuck, broken, or just worn out you will not have a functional fuel pump; even if you buy a new one. If your fuel pump is not working, you must verify crankcase vacuum before buying a new pump.
  7. Most, if not all, fuel systems now have a Fuel Shut Off Solenoid. This is a small cylinder on the bottom of the carburetor (with two wires running to it). The fuel shut off solenoid's main function is to stop fuel from flowing into the carburetor. It does this for various reasons
  • You turn the key off.
  • You put the mower in reverse while the blades are turning.
  • You blow the main fuse due to electrical malfunctions.
Diagnosing the Fuel Shut Off valve:
  • Assuming the battery is good and fully charged
  • Assuming the Key Switch is working.
When you sit in the seat and turn the key, one click from off to run, you will hear a faint click. That faint click is the fuel shut off valve under the carburetor. It is turning on and off when you cycle the key from off to run. If you hear this click your fuel solenoid is functioning electronically. It could still be experiencing issues inside the carburetor. Perhaps there is some varnish, silt or other trash keeping it from working. If this solenoid is not working, you will get no fuel into the carburetor, even if the pump is working. This will require a physical examination of the solenoid and perhaps the entire carburetor.
The following is an "out of carburetor" electrical check up.
  1. Remove the Solenoid.
  2. Connect one jumper wire from a terminal to the positive battery post.
  3. Connect a second wire from a terminal to the negative battery post. The solenoid should retract.
  4. Remove one jumper; the solenoid should spring back out.
If none of this solves your fuel problem you may have to remove and disassemble, clean, soak overnight in carb cleaner, or rebuild the carburetor at this point. You may have water, dried fuel (varnish) or trash in the carburetor bowl or jets. Before removing and disassembling the carburetor try draining the bowl. Or, take the bowl off, careful not to drop the small parts inside. Clean the bowl and replace. I often remove the bowl on small engines and find all kinds of built up gunk. This saves the hassle of a complete carb removal, sometimes.
What else could make the Fuel Cut Off malfunction??
Connect a volt meter across the two battery posts. If battery voltage drops below 9 volts when cranking or while the engine is running, the fuel cut off solenoid will not function. That means the engine will not start or will die soon after starting. So check your battery voltage before, during, and after cranking. If the battery voltage is good before but drops below 9 volts while cranking this is generally a sign the battery has one or more bad cells. Replace the battery. If the battery is in fact good, and the voltage is still dropping, you may have a bad starter motor which is drawing too much amperage.
If you find this fuel checkup does not solve the problem, repost your question with updated info (exact engine model) and I will walk you through the next step. Tracking down a spark problem; yes, your problem could involve the coil, coil wire and spark plug.
Small Engine Repair Checking Vacuum Fuel Pump Fuel System on Kohler Twin...
Testimonial: "Thank you for the quick response. That is a lot of info to digest. I will start on it asap. It is a twin cam engine model# SV590S."
  • Kprime
    Kprime Apr 20, 2015
    You are welcome. I looked up the service manual. You have a dual cam, single cylinder 19 HP. Nice engine. It has been discontinued. New models all the time. You do have both a fuel pump and a Fuel Shut Off Solenoid.
4 Suggested Answers
rwvanlue
  • 486 Answers
SOURCE: wont start
suggest you check compression, if it is less than 75 psi, you may have internal wear of rings
Posted on Nov 12, 2009
SOURCE: Mower wont start.
I have a 927 series rider and just put a new battery,and spark plug.Has spark and still wont start. What else can I try?
Posted on May 30, 2010
kevin_getz
  • 1031 Answers
SOURCE: 2 year old Ariens tractor won't start
It could be anything from a carb issue to a spark plug or bad fuel.
Posted on May 25, 2012
Craftsman YT 4000 Won't Start
Did you check for "spark" at the plug? Check fuel filter ( maybe plugged up ". How fresh is the gas?
Nov 10, 2013 | Craftsman YT 4000 42" Briggs Stratton 24...
My MTD Yard machines riding mower won't start.
Probably dead gas from sitting too long. Dump it out & put in fresh gas.Could have moisture in it. Pull out spark plug & crank it over several times after putting gas & let it sit a while to dry out or blow it out with compressed air. It should go.
Apr 04, 2012 | Mtd Garden
Cub cadet 53bb5bbp750 zero turn won't start
check the safety switches
Apr 03, 2012 | Garden
Why won't my 1997 Saturn SL start?
you have spark at the plugs ..thats something
spray stay you mug
into the throttle body see if the motor will cough
tank needs draining and have fresh fuel
fuel pump has a filter and fuel relay
crack the fuel line connection to the rail to see if there is fuel reaching the rail and correct pressure
if sitting 6 years.. not being run regularly
do a compression test
lifters may be stuck
rings may have lost tension
Apr 07, 2017 | 1997 Saturn SL
My mountaineer won't start. It sat for a little over a year because of transmission issues. When I finally got a trans for it, it wouldn't start. I replaced all spark plugs and replaced the...
If the engine is turning, but slow, she may need the battery terminals cleaned, if it has sat for over a year, yes, it may need a new battery. If the engine is turning over and she is not cranking up. Standard rules apply... does she have fuel? does she have spark, does she have compression? First thing is easy, get a can of starting fluid and give her a spray in the air filter area during cranking, if she pops off you have spark, which means no fuel. If it does not try to hit, that means no spark and more trouble shooting will need to be done. If it starts on starting fluid, you may have a bad fuel pump. AS gas turns to gunk as it dries up. And that may have gummed up the pump and filter. Hope this helps FixYa up.
Sep 12, 2011 | 2003 Mercury Mountaineer
190cc 675 sears push LM. Irene put it under water. Drained carb and crank. removed and cleaned filter. New gas. Won't start. Got a little pop with starter spray. No pop at all?
Did you drain fuel tank before refilling with fresh fuel? Drained carburator bowl good, drained crankcase and refilled with fresh oil good,removed air cleaner and dried out good. One question for you , did you remove spark plug and drain any water that may have gotten into your cylinder through an open valve? There could be water sloshing around in the cylinder, gas and water will not fire, and water on spark plug wont allow plug to spark. If you need any more help please get back to me , I believe this is the first under water problem I've encountered. GOOD LUCK.
Sep 07, 2011 | Briggs & Stratton 190cc 875 Series OHV...
Poulan 6.75 Lawn mower will not start
Remove spark plug, clean and dry. Replace plug. Remove air filter. Spray WD-40 into carb opening; one second blast. Turn over engine, (pull handle). Engine should start briefly and run for 3 seconds.  If not, you are not getting spark to spark plug. If engine starts, you have a dirty carb and you can buy a rebuild kit from manufacture.
May 02, 2009 | Poulan Pro " Pro" Self Propelled Mower
Ariens 42 in. 19 HP Kohler Hydrostatic Riding Lawn Tractor Logo
691 people viewed this question
Top Ariens Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Paul Sikkema
Paul Sikkema
Are you an Ariens Garden Expert? Answer questions, earn points and help others
