Question about Weber 4521001 Spirit E-310 Natural Gas Grill, Black
Temperature control no longer works and grill is too hot
At low setting the temperature is 400F
  • 998 Answers
I would say that the thermocouple or thermostat has failed or the thermocouple may not be in the correct position. The thermocouple is the metal wire with a bulb on the end which usually sits in the cooing area, clipped to the sides or back.. This senses the heat and turns down or turns off the gas, to maintain which temperature you have selected.
Posted on Apr 19, 2015
Steam iron not steaming was working ok one min then no steam
If the temperature dial is not set high enough, or the thermostat is faulty and setting the cut-off temperature too low, some steam irons will fill up their steam chamber in their soleplates completely with water and stop steaming, until the temperature returns above what's needed to continously generate steam.
Nov 26, 2017 | Irons
This iron slip out of my hand and crashed onto the floor. now the light indicator didnt work. and the metal plate isnt hot enough.help. my mother will kill me.
I am very sorry, but you will have to tell your mom you broke the iron. There is no easy fix for it. If you were next door .....maybe I could look at it for you....but your not....so gotta fess up....and don't plug it back in.....you may get electrocuted. Give it to your dad or mom to evaluate it's worthiness of further use.
Apr 03, 2015 | Irons
Why does my iron contantly beep and no steam?
Hi Mary,
Check to see that your iron is set at a temperatures suitable for steam generation. Beeps are a usual signal to notify you that your iron is plugged and switched on but the temperature setting is low and cannot generate steam.
Oct 05, 2014 | Irons
Steam iron turns itself from hot temperature to cool
1) test the electronic control for defective and follow the next steps. God bless you
Clean an iron:
  1. Unplug the iron and make sure it is cool before cleaning.
  2. Use a toothpick or pipe cleaner to remove buildup in the steam vents, making sure the debris doesn't fall into the vents.
  3. Use a fine sewing needle to carefully clean the spray nozzle of mineral deposits.
  4. To flush sediment from a steam iron, pour 1/2 cup water and 1/2 cup vinegar into the water tank. Place the iron on a rack over a broiling pan and set the iron to steam until the tank runs dry. Repeat if necessary. Or follow the instructions for using a commercial iron cleaner.
Service the steam and spray mechanism:
  1. Unplug the iron.
  2. Use a fine sewing needle to unclog the steam valve assembly. Also, check the valve spring and replace it if it is broken or has lost tension.
  3. If the spray pump is accessible, remove it and check for leaks by placing the spray tube in water and squirting the pump. Clean or replace as needed.
Clean a metal soleplate:
  1. Unplug the iron.
  2. Use a sponge and commercial soleplate cleaner or baking soda and water to remove dirt buildup on the soleplate. Rinse well with water and dry. Don't use harsh abrasives or immerse an electric iron in water.
  3. Use very fine steel wool (0000) or an emery cloth to remove scratches and burns on the soleplate, then clean the soleplate.
Jun 11, 2013 | Irons
Iron producing lots of water
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
May 18, 2010 | Philips GC 8220 Iron
My Tefal iron stop steam GV 8150
Hello :
1: Make sure there's enough water in the tank if the iron won't steam. Fill the tank up .
2:Check that the iron is set to a steam setting. Some of the settings are dry and won't create steam.
3:Set the temperature dial to the shaded setting which represents steam. You'll see a little dark cloud-type icon with raindrops as opposed to a white cloud with a stripe through it. The dark cloud represents moisture (steam), and the white cloud with the stripe through it represents no steam.
4:Allow the iron to heat up for a while and to emit steam for a couple of minutes while pressing the extra-long burst button a few times. That should get rid of any impurities which can cause blockages. Try this if the iron hasn't been used for a while and steaming is intermittent.
5:Iron horizontally. Steam is only generated when the iron is horizontal.
6:Use the maximum steam setting when the iron is set to its maximum temperature setting.
7:Let the iron get to a high temperature before expecting steam. If the soleplate isn't hot enough, the water won't turn to steam and will in fact drip, spit or leak from the soleplate. Some Rowenta irons have an anti-drip system, which will turn off the steam when ironing at a low temperatures. Turn the temperature up, if needed.
PLEASE DON'T FORGET TO RATE !
Apr 21, 2010 | Tefal Irons
My iron will not stop flashing and will not go to green light -- it will not heat up
Hello :
Check the fuse first ! If the fuse is in good condition , then try this troubleshooting .
Apr 21, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
My iron rowenta leaks when before and after i!m iroeing
my iron is different to yours but i used to have leaks as well.
for me it was because i have a heat setting dial that indicates that the steam function is activated when set to a very high temperature.
i also have a push lever on the top of the iron that controls how much, if any, steam is produced by the iron.
the amount of steam is regulated by letting more or less water through to be vaporised by the heating element.
if the heat setting is low and the steam setting has not been switched off then water is being allowed through but the element is not hot enough to vaporise the water. the result is water pooling and either dribbling through onto the clothing you are ironing or running off when you sit the iron up.
maybe it will help if you turn the steam setting off while the iron is not in use.
Jan 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
The iron is heating up to temperature, but it is not producing any steam. please can you help?
1. Could be it's not getting hot enough?(Thermostat could be set too low)
2. The pipe into the tank is blocked? (try pouring a little boiling water CAREFULLY into the iron filler hole and try that)
3. The outlet jets could be totally blocked? (Buy a de-scaling kit from Wallmart or similar)
Failing that you may have to buy a new one. Wallmart or similar have cheap electrical appliances
Aug 05, 2009 | Irons
Weber 4521001 Spirit E-310 Natural Gas Grill, Black Logo
140 people viewed this question
Top Weber Irons Experts
Are you a Weber Iron Expert? Answer questions, earn points and help others
