Question about Admiral Washing Machines
Admiral washer 8 years running good, now only drain water out won't work. took hoses off under neath not clogged
How do i figure if pump bad or switch?
    Genius:
  • Admiral Master
  • 1,585 Answers
See if pump is turning or use a bed side lamp put onto the two terminals and see if it lites when the mech is on emptly
Posted on Apr 19, 2015
Testimonial: "Thank you will try later on today to see. Wife says just buy new one...ha ha"
  • tom cassidy
    tom cassidy Apr 19, 2015
    see if pump is turning or use a bed side lamp put onto the two terminals and see if it lites when the mech is on emptly
  • tom cassidy
    i suppose u have to pay 4 it ?
Maytag Neptune MAH8700A tha detergent drawer is filling up with water and running out of the drawer onto the floor not going into the tub.
see this causes and fix it. God bless you
Belt, Water Pump If the washer won't drain the pump belt might have broken or might have worn out. Check the belt and replace if it shows signs of excessive wear.
Drain Pump If the washer won't drain water the drain pump might be defective. It's also common for a small sock or other article of clothing to get caught in the drain pump or in the drain hose. Check both for an obstruction before replacing the pump.
Clogged Pump or Hose If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Drive Belt If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all.
Lid Switch Assembly If the washer won't drain the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't drain the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Drain Hose If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions.
Coin Trap If the washer won't drain the coin trap may be clogged. This washer is equipped with a device near the water pump called a coin trap. The purpose of this device is to trap any foreign materials that make their way down the drain. Normally, the coin trap can be accessed through an access panel. It is designed with the homeowner in mind and is normally easy to clean out.
Oct 11, 2012 | Maytag Neptune MAH7500WH Front Load Washer
My indesit iwc6105 washing machine is not draining at all.
see this causes: and fix it. God bless you
Oct 11, 2012 | Washing Machines
CHANGE DRAIN PUMP WASHER
Oct 02, 2012 | Whirlpool GHW9300 Duet Washer
The washer broke filled with water and won't drain
Sep 28, 2012 | Kenmore Washing Machines
Lg wm2455h is not draining: i have taken out and cleaned pump filter and that did not correct the problem. I place the machine on the drain and spin cycle and i can hear the pump hum, but doesnt drain. ...
most likely you have a bad pump and it needs to be changed out or something is still stuck in the impellar,stick your finger into the pump and feel around the impellar,i've found under bra metal pieces stuck in there,elastics and string rapped around it and coins lodged in between the impellar and wall of the pump,if the pump is bad or something is stopping the impellar from spinning it will hum,power is going to the pump but the motor isn't spinning.
Nov 12, 2011 | Washing Machines
The washer will not complete the cycle. It will not drain and spin.
There could be two problems...The drain could be clogged, or the water pump could be bad. Or the belt that runs the pump is slipping or broken.
1 Fill washer with water and wait for the timer to get to the drain mode.
2 Unplug the washer from the electric outlet.
3 Open the case, and disconnect the water hose from the outlet of the water pump.
4 If you get water pouring out from the pump, then plug that up and check the hose to the sewer. If that is clogged, then you have found the problem.
5 Some washers have a self cleaning filter in that hose somewhere. Check that to be sure it is working properly.
6 Reassemble hose from step 3.
7 Plug washer back in. If it pumps out now, then you are done. If it doesn't, then the water pump is probably defective, so replace it.
8 Reassemble washing machine case...you're done...
Jun 16, 2011 | Washing Machines
My washer don't spin or drain the water
welcome to Fixya.
There are several reasons why a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Find some possible cause and how to solve the problem:
A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Good luck.
Apr 08, 2011 | Whirlpool Washing Machines
Admiral machine will agitate, but will not drain or spin
Agitating and Spinning are from one motor. Pumping is not controlled by the same motor. If the pump is bad, it won't pump. Pump can be checked by measure the resistance of its terminal, and its measurement should not be open. If pump is good then the problem is from the pump controller. If pump is bad, then you know what to do.
Sep 01, 2009 | Admiral AW22 Top Load Washer
GE WJSE3110A washer, won't drain
On a scale of 1 -10, I'd rate this about a 3.5 in difficulty.
Un plug machine.
Use a putty knife to push the clips in at the seam of the front panel and the washer's top, about two inches in from each side to allow you to pull the front panel forward and then lift it off the bottom pegs.
If you took off that drain hose, you shouldn't have any water left in the machine, so take the two squeeze hose clamps off the pump hoses, the electrical wires off the pump, and the two 3/8 size bolts holding the pump to the washer's base.
Now check to see if the pump is plugged or obstructed with an object. Replace pump with cleaned out or new pump as necessary.
Dec 10, 2008 | GE WJSE3110A Top Load Washer
Washing Machines Logo
44 people viewed this question
Top Admiral Washing Machines Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
