Question about Dryers
I need a part number for the belt on a kenmire dryer c1108580290
  • Dryers Master
  • 16,987 Answers
Are you sure about that model number?
Posted on Apr 19, 2015
  • Becky Busbridge
    Becky Busbridge Apr 19, 2015
    Yes that is right off of the sticker inside the dryer door.
2 Suggested Answers
machinetech7
  • 1344 Answers
SOURCE: Kenmire 80 series dryer drum doesn't turn
The way to visually see if the belt has broken or not is to 1) unplug the dryer. 2) Remove the lint screen on the top of the dryer. 3) take the two phillips head screws out where the lint trap is. 4) with a flat head screwdriver pop the top of the dryer up by sliding the driver inbetween the top and front of the dryer and pry upwards a little. 5) You'll now see the drum, if the belt is not around it its broken, and if it's visible try to lift it. If it taught, its good. IF THE BELT IS BROKEN OR LOOSE CONTINUE TO NEXT STEPS 6) on the left and right upper inner sides of the dryer you will find two screws, one on each side, remove these and the front should be easlily remove. 7) once off you'll be able to easily see the motor, the belts idler pulley, and everything else.
If the dryer is a DUET or HE2 or HE3 style, (dryers that match the front loader) then the way you take the top off is a little different. For these machines, there are 3 to 4 screws located on the top back side you'll need to remove, and then the dryer top can be slid back and removed
Posted on Jun 05, 2012
Frigidaire gallery heavy duty dryer
Good Afternoon Friend, thank you for your question!
I understand you are seeking a replacement dryer belt for your Frigidaire laundry center, GLET1031FS. The replacement dryer belt part number that you would need to order is 137292700.Most parts can be purchased directly from the manufacturer or through a parts distributor in your area (part numbers may vary based on distributor). Hope this helps! - Z
May 19, 2014 | Washing Machines
Need diagram belt repairclinic
WE12X10009 belt part number and it's around 45 dollars
May 10, 2013 | Hotpoint NVL333EY Electric Dryer
May 05, 2012 | Kenmore Dryers
Hey there i got a broken belt from old kenmore dryer model i dont see what model is it but i found a piece of paper with a part no. i dont know i u can gimme a good awnser also i find the paten number
You're really going to need the model number of the dryer to determine if the piece of paper has the part number for the belt that your dryer needs. If you find the model number info - you can go to Sears Parts Direct to check for a replacement (or go to the store).
You may get some help by bringing the belt to a Sears or Kmart store to compare to other belts that they have in stock. The length of the belt isn't super critical as the tension-er pulley can make up for small differences between your old belt and one that is "close".
I hope this helps!
Sep 14, 2010 | Dryers
Frigidaire dryer - tub will not tumble/turn....what to do? Can read all of the model numbers....the label has a crease it in.
If the machine sounds like it is running but the drum is not turning then you most likely have a broken or unseated belt. Just open up the top of the dryer and have a look at the belt on the rear of the drum usually. Most appliance parts stores should carry belts but you would need the model number to know which belt you need. See if you can find the manual for the machine. Otherwise you'll need to have a pro come and figure out your model number.
Dec 13, 2009 | Frigidaire Electric Dryer
I need to replace a dryer belt on a Kenmore gas dryer model number 110.73032102. The belt part number is 2925.
Not sure where you got that part number but the true part number for the belt on your dryer is 3387610
The service manual detailing the disassembly and repair of your dryer can be downloaded at link below. Be sure to unplug dryer before proceeding to disassemble::
http://www.mediafire.com/?5gmg0jyji4t
Nov 05, 2009 | Kenmore Dryers
I am replacing belt on kenmore dryer but the new one from lowes seems to small are there multiple size belts for kenmore?
You need to match the belt to the specific make and model of dryer. There are several online appliance repair parts suppliers that can provide great assistance, and in some cases, the OEM part number for the belt. With the latter, appliance outlets like Lowes should be able to verify that the belt purchased is the part needed. In addition, check your owner's manual for a specific part number for the drive belt.
Oct 04, 2009 | Kenmore 63942 Dryer
Need model number or part number for whilpool dryer
The model number for your dryer is usually located on a plate or sticker inside the door on the body of the dryer hidden by the closed door.
The most common (but not the only) belt number for Whirlpool dryers is 341241 and the idler arm for that common dryer has tabs that fit into the floor beneath the motor drive pulley. Take a loop of the belt with ribs inside the loop and pass it through the opening below the roller and loop it around the motor pulley. If it's the most common unit the end result should look like the image below for Whirlpool:
Belt Configuration
Good Luck
Sep 07, 2009 | Whirlpool Dryers
Kenmore dryer
The belt you will need for that unit is part # 341241. These belts will fit almost all Whirlpool and Kenmore models except for the DOTT (Dryer Of Tomorrow, Today) dryers. A DOTT dryer is a Kenmore model only, and has a front kick plate and the lint filter in the door.
Jan 27, 2008 | Dryers
Dryers Logo
61 people viewed this question
Top Dryers Experts
