Question about Saws
Lumber wiring diagram
Need wiring diagram for lumber saw
  • 12,158 Answers
Lumber - a piece of wood , wiring diagram ! would you like to try again ? I know for a fact there is no lumber wiring diagram on a 1999 Cadillac Deville !!!!!!!!!
Posted on Apr 20, 2015
Wiring behind on off switch
What's the brand and model of your band saw machine? Check out the website of the manufacturer of your band saw , you might be able to ask a manual/ wiring diagram from them. I have once downloaded a wiring diagram from bandsawmanuals.com for my old band saw. Hope that helps.
Nov 28, 2013 | Saws
Replacing switch on 9" task force band saw & need wiring diagram
I couldn't find a manual or wiring diagram available online. A 9" Ryobi band saw looks like the Task Force saw. You may check for it. However, the two saws may have different instructions for the wiring layout. Your best option is call Lowes or see a electrician. They should be able to help you with that.
Sep 04, 2013 | RTO 7 X 12 1HP Turn Pro Band Saw
What is Quarter-Sawn Lumber?
Quarter-sawing is a method of milling trees into lumber. Quarter-sawn lumber is highly sought after, particularly in certain species such as oak or maple, where look of the grain in the wood is accentuated by the method of cutting the tree. While rip-sawing is the most efficient (and common) method of milling, quarter-sawing is more difficult to cut but yields much more stable lumber. Because it is more difficult to cut and there is more waste, quarter-sawn lumber is considerably more expensive than rip-sawn material.
(taken from http://woodworking.about.com)
Feb 27, 2013 | Crafts & Hobbies
I have a 10" Delta table saw. It was running rough
Check that the blade is not warped or binding. Don't use long extension cords. Check your home breakers. Also check if the table saw has a breaker. Don't force lumber into the blade too fast and don't jam the lumber between the guide and blade. Try a different outlet and check your wire for breaks. Good luck!
Oct 05, 2011 | Saws
My Ryobi P501 cordless saw is noisy, sounds like it may need bearings or gears.Are there any common problems with these units?
No but where did you buy it its a small saw mine works fine but its for limited use. You can't use it to cut frameing lumber but its handy.What have you done with it when was the last time you changed the blade ? Idon't know i have 5 or 6 differant skill saws differant blades differant uses its olny disigned to do so much
Dec 14, 2010 | Ryobi P501 18v Circular Saw Only
After the log is squared on my sawmill i saw the lumber and it becomes thicker on one end,than the other
You hit something on one side of the blade and now it wants to saw crooked...you either need to resharpen the blade or get a new blade...
heatman101
Aug 07, 2010 | Saws
When cutting softwood/ hardwood should the saw
The blade should only be on a slow speed, for intricate work.
(To make sure that whatever you're cutting, doesn't get too excited.)
Otherwise, it should generally be on the fastest setting.
Thats it, oh except, be carefull and mindfull of what this baby can do;)
Don't forget to rate, thanks
Aug 01, 2009 | Saws
I need a wiring diagram for a Delta xl-10 table saw.
Unfortunately, the manual for the XL-10 saw is no longer available online. Here is a link to the parts list and diagram.
If that is not helpful, please consult a qualified electrician, who should be able to guide you in the wiring of the switch and motor for that saw.
Without access to the schematic, I'm afraid the best solution to your wiring question is for some capable electrician to take a look at your saw in person.
Mar 28, 2009 | Saws
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Saws Logo
160 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
