Question about John Deere Garden
Our John deere ez trak z445 won't run right when blades engaged. It stall and dies when you drop the blades down. Any ideas?
    Scholar:
  • 35 Answers
One of my friends in college did tree removal for a living and he had problems like this a few times. I asked him how he fixed it once, and the answer was pretty complicated. I'd suggest getting a technician out to do the work for you unless you have experience with that kind of thing. At least that way you'll know that you're getting the repairs done right.
http://www.treecuttime.com/Tree_Service_Tips_Lakeland_FL.html
Posted on Aug 28, 2015
    Sergeant:
  • 462 Answers
Could be just a plugged air or fuel filter
Posted on Apr 23, 2015
  • 948 Answers
According to supportmtdproducts.com: "If the engine dies when the cutting deck is engaged, there is likely one of the following three possible scenarios:
  1. The riding mower is in a reverse gear. If the mowing deck is engaged and the unit is in reverse, the mower will shut down as part of a safety feature.
  2. An object or obstruction (such as an ant hill, clump of matted grass clippings or large tree branch) is jammed underneath the cutting deck or in the cutting deck drive system preventing the moving parts from engaging properly. Inspect for obstructions and carefully remove if necessary.
  3. The electrical system may be experiencing a short or improper ground somewhere throughout the length of the wire harness. This could be sending a false signal to the safety interlock system. This false signal may be sensing that the operator is up out of the seat or the unit is mowing in reverse even though that may not be the case. For this situation a thorough inspection of the electrical system and possible repair of the wire harness is needed. Please use our Authorized Service Center Directory to make arrangements for local service and repairs.
    NOTE: Individuals with previous experience diagnosing electrical system failure techniques, and are equipped with the special diagnostic tools used, may wish to consult the Professional Shop Manual. These service manuals have additional Electrical Troubleshooting information and electrical diagrams."
I hope this helps! :)
I h
  • 18 Answers
SOURCE: blades will not ingage
is it electronic engage or manually?
Posted on Sep 03, 2008
  • 10865 Answers
SOURCE: John Deere LA110 mower blades got disengaged
yes. your mower has a blade engagement cable attached to the drive sheve. i am providing a link to the manual which shows this.
http://manuals.deere.com/cceomview/OMGX22464_C8/Output/Index.html?tM=HO
Posted on Jun 25, 2009
mickey813
  • 472 Answers
SOURCE: John Deere 160 riding mower. When I try to engage
CK THE SEAT SWICH OR THE BRAKE SWICH ONE OFEM IS BAD
Posted on Oct 02, 2009
nova2nv
  • 197 Answers
SOURCE: Fuse blows when engage blade
The electro-magnetic coil side of your PTO is shorted out.On the 318 it is very easy to replace,just under front screen.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: john deere gt 235 electric blade engagment but
One of two possible causes;either the PTO switch is defective or the switch for the reverse peddle is out of adjustment .The only other thing i have seen cause the PTO to shut down is a lack of battery power due to the machine not charging.
Posted on Mar 21, 2010
John Deere Z840A Z-Trak mower. Why does engine die when PTO is engaged?
A possible cause is an open seat switch (operator presence). Locate the switch under the seat & unplug the switch from the harness. Place a small jumper wire into the female socket leads to the wire harness. If the PTO engages without engine shutting down, replace the seat switch.
Check to see if the mower deck is plugged or a piece of wood/debris is wedged between the deck and a blade, or some wire/rope is wrapped around a spindle. If the blades don't turn by hand, it'll stall your engine when the electric PTO clutch is energized.
Lastly, a discharged battery will cause an engine shut down if there's not enough reserve when the PTO is engaged. Measure the battery voltage with a meter. If the voltage is below 11.5 volts, you may have to replace the battery.
Oct 23, 2015 | John Deere Garden
Murry 12.5 40in mower wont engage
Could be the seat switch, the on/off switch, or the electromagnetic clutch. I would check them in that order.
Jul 05, 2010 | John Deere 48 in. EZ Trak Power Flow...
John deere 17hp kohler
Make sure your electronic ignition (modular, coil, or whatever you want to call it) is not the problem. Check this by replacing old plug with new (I'm sure you already did this), but before putting the new plug in connect it at the top to the ele ign wire, then lay it on the machine or any piece of metal, (screw driver will do) then try to start the engine. Watch to see if you have fire between the spark plug and the metal. If not it is the ele ign that isn't any good and must be replaced.
Jun 14, 2009 | John Deere 42 in. EZ Trak Bagger
I have an eztrak john deere 445... quits.
The vent in your gas cap is plugged, it's a very small hole right in the center.
Mar 30, 2009 | John Deere 42 in. EZ Trak Bagger
Garden Logo
202 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
