Question about Samsung PN58B540 58 in. Plasma HDTV
58" Samsung plasma has no picture. While I was watching TV, it made a popping sound and went out. I have sound but no picture. Which circuit board should I change?
  • 50 Answers
Finding a capacitor that has blown is your only saving grace. Chances are it was on the PSU. Go to www.shopjimmy.com for parts. There are so many different parts it could be, start with the least expensive (if you don't know what capacitor popped), Start with the PSU then go to the Y scan upper and lower, then move onto the X main then buffers.
Posted on Sep 29, 2015
    Top Expert:
  • Samsung Master
  • 74,136 Answers
Fault in the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Apr 19, 2015
  • 960 Answers
Unplug it, take the back off and have a look. If something was popping, im sure you will find which board blew out. Make sure you get the full model and serial number so that when you order a replacement, you get the right one.
Samsung plasma Model PN60E8000GFXZA not turning on just clicking, TV was on and we heard a loud pop, tv went to a black screen with no sound. when we turn on tv no picture, no sound, any suggestions
Plasma TV'S contain many capacitors and TV manufacturers us substandard quality capacitors to make these TV'S affordable to the general public. If one of these capacitors goes out the TV will no longer turn on. If you feel comfortable removing the panels from the TV you can look at the circuit boards and find the capacitor(s) that have went bad. They will either be burned or the top of them will be burst open or bulging. From your description you will probably have one that will be burst open. If you know how to solder electric components this is a very cheap and easy fix. A TV repair man will charge quite a bit to do this.
Oct 25, 2016 | Samsung PN60E8000GFXZA - PN60E8000 60 3D...
How to fix a 58 in plasma tv that makes a clicking noise ; no picture
SOUNDS LIKE A FAULTY RELAY HAD THIS FAULT PREVIOUSLY ON SAMSUNG -SONY-TOSHIBA
Jul 25, 2015 | Samsung PN58B560 58 in. HDTV Plasma TV
Hello, Last night my Samsung plasma TV made a fairly loud popping sound while I was watching it and then the power went off. When I turned back it on, no picture but sound was o.k.
Yes the caps on theower supply, but you can check power supply board by smell an look for burnt parts it is common. May need more than one board if they are cheap get both.
Jan 29, 2015 | Samsung Televison & Video
Why does my samsung plasma 550 have no picture?
It sounds like a capacitor blew in one of the internal circuit boards. A capacitor makes the pop you described, and techs actually refere to them as "being popped".
Sep 05, 2014 | Samsung Televison & Video
I heard two popping sounds and now my television will not power on.
A popping sound as you describe sounds as if your tv blew a couple capicators on the main control board. More than likely , you are needing to aquire a new main circuit board.
Sep 01, 2014 | Samsung UN55B8000 55 in. LCD HDTV
My Vizio p50hdtv herd spark, and TV went black, no picture no sound
Check and replace the main power regulator board as card basis. It has damaged.
Oct 11, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Samsung 58" plasma pop spark no picture
Hi
A common problem for these is bad capacitors in the power supply, Remove the back from your Tv and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jul 02, 2010 | Samsung PN58B650 TV
Samsung no picture
There are several capacitors that are known, in Samsung TV's that go out.. ( I replaced mine until the board was burnt through.. bought a new board, they went out again.. BOUGHT A LG TV!!)
Samsung settlement warrants older TVs with faulty capacitors
Samsung LCD Plasma TV Capacitor Repair Kit Replacement Parts
replacing these is not hard at all.. if you can use a soldering iron, you can do it..it just takes time..
Repair Samsung LCD TV Relay Clicks Shuts Off Won Come On
WATCH THESE VIDEOS FIRST.
Samsung TV Won Turn On How to Repair Bulging Capacitor for Clicking Noise
My Repair of 46 Samsung LCD TV with Bad Capacitors
Jul 18, 2017 | Samsung - Projection TV replacement lamp...
Blown Picture
There is not much you can do to fix your plasma. Since the plasma is less then 1 year old, still under Samsung warranty.
I would suggest to call them to fix it.
Good luck.
Aug 18, 2008 | Samsung FP-T5884 58 in. Plasma Television
Samsung PN58B540 58 in. Plasma HDTV Logo
156 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
