Question about eMachines Emachine T2385 Power Supply Replacement 300W
Where can I find the fuse to replace it, because my cd rom and DVD recorder won't turn on. I opened it to remove dust and I must have hit something, I also forgot to unplug it. Can you Help Please???
  • 899 Answers
With it UNPLUGGED, check all connections to and from the main power supply. The multi connectors are not hard to dislodge and you will probably find one of them has partially come out of its socket. I don't think PC power supplies have a fuse in them.
Posted on Apr 19, 2015
Aspire dvd drive won't open
If you open Start Menu,Computer, DVD/CD rom, and right click, eject? If it is damaged or there is something in it you may have to remove it and clear the obstruction.
Nov 29, 2012 | Acer Aspire X3200 PC Desktop
FUNAI SV2000 WV10D6 DVD recorder Recording errors on new DVD +RW discs
HI,
You can try cleaning the dvd lens with a commercialy available cd/dvd cleaner.
Aug 27, 2008 | Computers & Internet
My Sony CDRWDVD CRX880A ATA Device won't read Dvd's I'm trying to make burn a movie on there and it won't load the disk it says " Let windows help me choose a disk" because D:/...
The
CRX880A is a cd writer and DVD reader it doesn't record dvd only plays them
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Thanks for using Fixya.
Jul 03, 2011 | Sony CRX880A CD-RW/DVD-ROM Combo Drive
E Machines T3302. DVD will not eject. In hitting the eject button, or right clicking on e-drive for DVD, and clicking on "eject", it sounds like it is trying to eject, but it won't eject....
On the dvd rom drive sound slike it catching on something on the inside stoppin git from ejecting you will have to use a flat head screw driver poke it from the top and very gently pry it open while pushing the eject button as soon as it ejects you can then remove any cds inside it and you can remove the dvd rom drive bezel and close it if it opens and closes freely while this dvd rom bezel is off then the piece of plastic you took off it is slightly made wrong you can get these bezels cheap or by finding an old rom drive and removing that one to replace with yours. any additional questions please use the comment box below Kronoguy
Jun 29, 2011 | E-Machines Computers & Internet
CD DVD ROM doesnt read dvds when i insert the disk the light turns on i can hear the dvd turning but later on it stops. turn and stop again. then it doesnt read the dvd anymore
how long have you been using this CD ROM? I suspect the laser (lens) of the CD ROM. I think the laser (lens) is weak that's why it cannot read data/files on DVD.
To confirm if actually its a laser problem, insert an Audio CD into the CD ROM and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the CD ROM cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new CD ROM.
Good luck...........
Mar 18, 2011 | Toshiba 100GB Laptop for Satellite 2400,...
Panasonic DMR-EZ48V Dvd unit said disc was scratched/dusty - so would not record. Tried a newly opened DVD disc - same problem. Tried a pre-recorded DVD that had previously been played on this machine...
I would suggest since this is just out of warranty/guarantee as you say, try a DVD laser lens cleaner (these look like DVDs but they are for shifting surface dust off the laser lens in these drives (without the need for you to worry about opening them up). If the recorder suggests dirty discs, the laser probably has a speck of dust on it - you cannot see this speck, but the device can.
Do not use CD/DVD lens cleaner discs - those are supermarket products designed for CD/DVD players, not recorders or DVD-ROM drives in a PC. I recommend a true DVD lens cleaner kit - you may be able to obtain this through Panasonic or similar electrical outlets (like where you originally purchased the combo). These 'specific cleaners' are cheap, but unlike CD/DVD cleaners, these will not damage your unit.
Hopefully it is nothing more than a bit of stubborn dirt stuck on the lens inside the drive or anything more serious.
Feb 24, 2011 | Panasonic DMR-EZ47V DVD Recorder/VCR
How to a record directly onto dvd using dazzle, when i install it only selects the hard drive as a place to record to. it has installed so as i can record directly to dvd but had my pc upgraded and had to...
Hi and Welcome to Fixyah,
Could you please checked your computer if you have your DVD writer.
Check here and do the procedure on how to checked it.
1. Click on Start
2. click Run
3. Type msinfo32 then click ok
4. System Information appears
5. click the "+" for components and see if you can find a DVD Rom drive listed. If you find one click on it.
6. Then click Edit and the Select All and the press CTRL+C 7. Go to your email reply and press CRTL+V to paste the information there.
It should look something like the info below.
Drive?D:
Description?CD-ROM Drive
Media Loaded?Yes
Media Type?CD-ROM
Name?TSSTcorp CD-R/RW SH-R522C
Manufacturer?(Standard CD-ROM drives)
Status?OK
Transfer Rate?Not Available
SCSI Target ID?0
PNP Device ID?IDE\CDROMTSSTCORP_CD-R/RW_SH-R522C_______________TS03____\5&19694FF7&0&0.0.0
Driver?c:\windows\system32\drivers\cdrom.sys (5.1.2600.2180 (xpsp_sp2_rtm.040803-2158), 48.38 KB (49,536 bytes), 2
On select burner to you Instant DVD recorder program just click the pull down arrow and check the model of the writer and then click it and then hit prepared.
Regards.
Mar 17, 2010 | Pinnacle Dazzle DVD Recorder
My Dvd rom has disappeared. how do i get it back
To solve this follow these instructions:
NOTE: After removing these registry keys and rebooting, it may be necessary to reinstall any CD or DVD recording application
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7)uninstall the drivers for cd drive and dvd drive from device manager and then
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that there is no yellow exclamation on the CD or DVD drive
Jun 09, 2009 | E-Machines emachines (emachinees) CD-ROM...
Unit powering off unable to stay on
mine did the same thing. Try this turn the power on with the remote, hit the record button and the tape should come out. This means that you need to record something.
Chet
May 26, 2007 | Emerson EWD2202 DVD Player/VCR
CD tray opens and won't stay closed for burning
Sounds like an issue with the contact behind the button on the drive. How old is the drive? Replacements are cheap these days.
Sep 04, 2006 | HP (dw381a) CD-RW/DVD-ROM (Combo) Burner
eMachines Emachine T2385 Power Supply Replacement 300W Logo
51 people viewed this question
Top eMachines Computers & Internet Experts
brian soufane
Michael Vincent Cruz
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
