Question about Garden
Wrong fuel mix - Garden
    Top Expert:
  • Garden Master
  • 43,003 Answers
Probably electric anyway
Posted on Apr 19, 2015
    Top Expert:
  • 10,875 Answers
1 pint to 16 pints
I think someone put the wrong fuel in it and now its close to empty I've got to drain the tank on it and I don't even know where the draian is or should I just flip the damn thing over?
tipping the car over damages the paint work and will still not drain the tank better to disconnect the hose from the fuel pump and turn the car on
collect the fuel in a container
or you could just fill that tank with the right fuel and the contamination will be diluted right down to very little problem
pity you could not mention what the wrong fuel was as any petrol grade fuel ( all octane ratings including e-10 mix) will not damage a vehicle and if it was disilene for diesel engines then the mix will only cause it to smoke lightly if at all when mixed with a full tank of petrol
again you never mentioned the engine type so if it is a diesel engine then you have to get the petrol out of the tank by the method suggested
Apr 02, 2017 | Cars & Trucks
Will not start someone put wrong flue mix in
You will need to drain the fuel tank and lines, to get rid of the wrong fuel mix. Remove the spark plug clean and dry it. Rotate the engine several times with the plug out, to get rid of some of the wrong fuel mix. Install plug, fill fuel tank with the right fuel mix and start using normal procedures. If it does not want to start, remove the plug and put a teaspoon of straight gas in the cylinder. Install spark plug and try to start unit. You may have to remove the plug more than once and put gas in the cylinder.
Nov 13, 2015 | Garden
I like to know if is ok to drive my car with engine licht is on the code is po175 po172
It means there is too much fuel in the air/fuel mix going into the engine. You can drive to a repair shop without too much trouble. A lean mix is much more dangerous, but you will use a ton of fuel and not get much power if the mix is too rich.
The real problem is why is the computer putting to much fuel in the mix. Maybe the carburetor is bad, maybe the computer or one of the sensors is shot. Either way, get a good mechanic to figure out what is wrong.
http://engine-codes.com/p0175_honda.html
http://engine-codes.com/p0172_honda.html
http://www.turbobygarrett.com/turbobygarrett/airfuel_ratio_tuning_rich_vs_lean
http://forums.anandtech.com/showthread.php?t=140155
Jun 12, 2015 | Honda Cars & Trucks
How to mix the oil for GTI 19?
Owners manual call for 40:1 mix for the Weedeater GTI19.
Or just use a good multi-mix oil that works from 16:1 to 50:1. It come in pre-measured bottles or packages for mixing with 1 or 2-1/2 gallons of fuel. This cut down multiple cans of fuel mix for your various pieces of 2 cycle equipment. This is what I use in the repair shop so I don't have to worry about using the wrong mix.
Nov 20, 2014 | Garden
Stihl chainsaw manual pdf
The fuel mix that you can't go wrong with is 40 fuel to 1 oil. Two stroke oil that is.
Aug 09, 2014 | Stihl Garden
What fuel to use
Look on the fuel cap for the proper mix of gas to oil. It could be 20:1 or 32:1 or 40:1 or 50:1. you MUST you the correct mix. Wrong mix could trash the engine with too little oil. Too much oil will give poor performance and foul out plugs or may not run at all .
Aug 04, 2013 | Garden
Engine wont run with wrong fuel mix
drain the fuel and replace with fresh fuel if you cant get it started you might need to replace the spark plug
May 03, 2012 | Briggs & Stratton Garden
My trx 450er run s good but the pipes glow red hot whats wrong
The fuel mix is too lean. Chances are the rubber seals from the carb to the cylinder need to be replaced to prevent un-carbureted air from getting into the fuel/air mix.
Sep 11, 2010 | Factory bike Desert YR 250 Motorcycles
Smoking outboard
Sounds like your running a bit rich. Try leaning down your air/fuel ratio.
Aug 23, 2009 | Sport & Outdoor - Others
My homelite yardbroom 2 won't start. Maybe wrong gas/oil mix
Hi
If you remove the fuel you believe to be the mixture out of the fuel tank and refuel with the correct mixture then remove the air filter. Put a few drops of the correct mixture in to the intake it should start. it may take a few times of repetting putting the fuel in to the intake, but eventually it will clean out the bad fuel and run good.Remember to replace the air filter!
Apr 24, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
43 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
