Question about LG Refrigerators
How do I remove back panel inside of freezer on lg lrfc25750?
  • 973 Answers
Once you have the racks etc out, you should see some round plastic plugs which hide the mounting screws, carefully use the point of a knife to pick these out. The screws for the back panel are then visible. Once they are out, the back panel is also held in with clips which are part of the back panel. Start at one of the top corners and carefully ease the panel out and away from the back of the freezer. If your model has the fan motor attached to the back panel, there will be a wiring plug you will need to undo to fully remove the rear panel.
Posted on Apr 19, 2015
My refregerator displays code f dh,we changed maine board ,but code still come back after about 10 h,what is wrong?
Freezer defrost heater. Heater good but the sensor is bad. Right side of coil, be attached to the evap cool, covered in what looks like a clear bag. Most have 2 sets of leads
Mar 29, 2013 | LG LRFC25750 Refrigerator French Door
Ice is forming on bottom of refrig. under the freezer bin. Suspect it is the defroating system malfunctioning. Repairable without calling an expert?
HI,CHECK IF THE FREEZER DOOR IS CLOSING PROPELY..IF HOT AIR IS GTTING INSIDE THE FREEZER WILL BE SWETTING AND BUILDING ICE.
Jul 05, 2011 | LG LRFC25750 Refrigerator French Door
Ice forming on floor under freezer drawer
Check out these tips...they can help you figure out what is going wrong withyour refrigerator
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Apr 08, 2011 | LG LRFC25750 Refrigerator French Door
We have a LG french door refrig, Model #LRFC25750TT. Ice forms in the bottom of the freezer which causes the door to stick when opening and closing. It appears that water may be coming from the vent on...
You have a frozen drain tube. Remove the back cover after unplugging the unit. Locate the drain tube running down to the drip pan. If it is frozen, thew it with a hair dryer. In the inside, find the drain hole and pour hot water in it until it drains properly. I f it happens again your defrost element is too far away from the aluminum drain pan and needs to be GENTLY lowered closer to the drain
Dec 03, 2010 | LG LRFC25750 Refrigerator French Door
I have an lg secial #LRFC25750SW.The freezer has a tray and it broke,how much is the part
Contact LG @ 1 800 243-0000 have your model and serial # ready.
You can order it from them.
Jan 02, 2010 | LG LRFC25750 Refrigerator French Door
HISSING SOUND FROM FRIDGE FREEZER
I poked a hole in the freezer with my knife while trying to defrost it. Now it is making a constant hissing sound. what should I do? is this dangerous?
Jan 23, 2009 | LG LRFC25750 Refrigerator French Door
Noisy vibration
Remove the back panel inside the freezer (if there's a removable panel there. There is a fan behind it - may be source of your problem.
Jan 22, 2009 | LG LRBN20510WW Bottom Freezer Refrigerator
Freezer section evaporator fan motor bearing are going out. This would be indicted by a high pitched squealing noise. Have the fan motor replaced and it should solve your problem.
Jul 31, 2008 | LG LRFC25750 Refrigerator French Door
Outside of fridge condensation; hissing boiling noise
under the compressor there will be rubber bushes which would have got damaged so change the rubber bush and ur problem may get solved
Jul 25, 2008 | LG LRFC25750 Refrigerator French Door
Where is this fuse located on the LG refrigerator is displaying a ER DH code error
GO TO SEARS .COM ,CLICK ON PARTS,PUT YOUR MODEL NUMBER IN AND YOU WILL FIND WHERE THE PART IS,LET ME KNOW-MIKE
Jul 07, 2008 | LG LRFC25750 Refrigerator French Door
Refrigerators Logo
588 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
