Question about 4103LX Avital 1Way Remote Start and Keyless Entry Sys
System starts but only runs for 30 seconds - 4103LX Avital 1Way Remote Start and Keyless Entry Sys
Reset change oil light on a 2001 Saturn l300
I don't know the year of the vehicle so I'll give you 2 possible ways to reset it.
2004-2005
Turn the ignition to run (one position before starting engine).
Immediately after Step 1 press and release the gas pedal 3 times within 5 seconds. If the Change Engine Oil light is flashing, the system is reset. The light will flash for up to 30 seconds or until the ignition is turned off. If the light comes on again and stays on for 30 seconds at the next engine start, it did not reset. You will need to reset the system again.
Turn the ignition off and then start the engine to verify the indicator has been reset.
Turn the key to run, but don't start the car. Open up the underhood fuse box (move the coolant line out of the clips for easier access). In the fuse box is a button labeled "OIL-R". Hold it down for five seconds. The "change oil soon" light should flash for about 30 seconds or so. That means it's reset.
Sep 09, 2016 | Saturn L300 Cars & Trucks
Engine runs for about 30 seconds and shutdown like an electrical shutdown as opposed to a fuel related shutdown.
Engine fired up, ran normally for 30 seconds, then shut down ...
www.thedieselstop.com > ... > 7.3L IDI Diesels (Not Power Strokes)
Sep 25, 2012 - Engine fired up, ran normally for 30 seconds, then shut down. ... it fired up and has been running since... if it just ran out of fuel jump it, and keep ...
Viewing a thread - cummins m11 starts then dies - AgTalk Home
talk.newagtalk.com/forums/thread-view.asp?tid=332921...flat...1
Sep 24, 2012 - 9 posts - ‎9 authors
98 KW with a cummins m11 will start and run for 5 seconds then dies. ... anything else like that, because it would run for 30 seconds and then die, not 5. ... The engineprotection system will not shut down the engine unless the ...
[PDF]John Deere Engine Safety Shutdown with "Black Box" (prior ...
www.tuckerbilt.com/.../John%20Deere%20Engine%20Safety%20Shutdo...
John Deere Engine Safety Shutdown with "Black Box" (prior to Tier II ECU ... Ifengine fails to start in 30 seconds, the Low Oil ... Test #1 (Engine not running).
1800 RPM for 30 sec before shut down [Archive] - Pilots of America ...
www.pilotsofamerica.com > ... > Pilot's Lounge > Technical Corner
Jan 01, 2016 | Cars & Trucks
How to disarm the anti theft system on an 05 CTS Cadilac
A reset is ten minutes on and 30 seconds off. One time. Relearn is three times this. Older vehicles used to be 5 to 10 seconds off. now is 30. There are minimal times on and off, but I haven't found the maximum time. I have left cars on for 30 minutes and off for 30 minutes and the reset/relearn has still worked. Just a note , the securit relearns in the off position.
Dec 13, 2014 | 2005 Cadillac CTS
Lexus sc 400 anti thieif could this be why my car don't start
Yes, car will not start or will start and run for about 20 seconds and shut off if the anti theft system is active. The theft system will either disable the starter circuit, cut the fuel injector circuit or both. Sometimes you can lock the doors with either the key fob or electric door locks, then open manually with a key and then lock with key fob, wait 30 seconds and unlock with key fob or key. Occasionally that will reset the system, or turn on ignition 3 times for 10 seconds each without starting the car, (turn key to where dash warning lights illuminate, but not to the start position), wait 30 seconds then start the car, for the ECM to relearn the key code. If that doesn't work, most likely will have to be reset at a dealership. Good luck!
Jul 17, 2014 | Cars & Trucks
Why does my briggs and stratton 310000 run rough on startup?
look for fuel puddling in the carb area (strong fuel odor on start up or after primering) may need a needle and seat valve
Jul 11, 2014 | GE 7KW Generator System With 50A, 10...
I need a wiring diagram on the ignition and information to bleed the diesel pump after running out of diesel. I have a 1.7 utility 2001
prime system by switching on the ignition three times for 15 seconds each time.then operate starter maximum 30 seconds. if engine still dont start wait 5 seconds repeat the procedure.if engine does start idle rough run engine fast idle speed for one minute purge air out the lines until engine run smooth.
Oct 03, 2013 | 2001 Opel Corsa 1.7
2003 yukon starts with the remote, runs about 30 seconds then shuts off, then restarts for 30 seconds and shuts off, over and over
remote start might need reprogrammed check for codes in system security code may have set
Jul 02, 2012 | 2003 GMC Yukon
2003 Impala 3.4 missing/dying
1 Inspect Timing Belt SlipPED or Broken Timing Belt. 2 Inspect Timing Chain SlipPED Timing Chain. 3 Inspect Timing Set SlipPED Timing Chain or Worn Timing Gear(s). 4 Inspect Fuel Injector Dirty or Worn Fuel Injectors, or Vacuum Leak in Fuel Injection System. 5 Inspect Carburetor Incorrect Carburetor Adjustment, or Vacuum Leak at Carburetor. 6 Inspect NEEDLE Seat Dirty, Worn, or Damaged Carburetor NEEDLE and Seat. 8 Inspect Timing Specification Incorrect Ignition Timing. 9 Inspect PCV Valve Clogged Emission System. 10 Inspect Wireset Worn, Damaged or Faulty Spark Plug Wire(s). 11 Inspect Distributor Cap Distributor Cap Cracked or Burned. 12 Inspect Spark Plug Fouled, Damaged, or Broken Spark Plug(s). 13 Inspect Intake Manifold Gasket Leaking, Worn, or Damaged Intake Manifold Gasket. 14 Inspect Crankshaft Gear Worn Timing Gear(s). 15 Inspect Camshaft Gear Worn Timing Gear(s). 16 Inspect Distributor Cap and Rotor Kit Distributor Cap Cracked or Burned. 17 Inspect Valve Burned, Worn, or Sticking Exhaust Valves. 18 Inspect Camshaft Worn Camshaft LOBE(s). 19 Inspect Valve Lifter WornValve Lifter(s). 20 Inspect Belt Incorrectly Routed, Adjusted(Tensioned), Missing or Worn Drive Belt(s). 21 Inspect Alternator Low or No Voltage OUTPUT From Alternator/Voltage Regulator. 22 Inspect Voltage Regulator Faulty, Shorted or Incorrectly Connected Voltage Regulator. 23 Inspect Relay - Charge Lampat Damaged or Faulty Charging Relay.
Aug 31, 2009 | 2003 Chevrolet Impala
4103LX Avital 1Way Remote Start and Keyless Entry Sys Logo
32 people viewed this question
Top Directed Electronics Vehicle Parts & Accessories Experts
Kevin Daniels
Joe Taylor
Joe Taylor
Are you a Directed Electronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
