Question about Gateway Computers & Internet
Ordered this mobo from ebay to replace mobo in lenovo thinkcentre m52
Problem im having is the power button and leds connect to the front usb/audio panel. the cable that comes from there *which seems to be an old floppy ide cable* has nowhere to plug into this motherboard. i can live without the front ports but i need to have a power button to power the system back on. i can't seem to find any documentation on the motherboard other than aparently they come oem installed in Gateway E-4500D systems. the front panel issue is the only installation issue i have so far. any ideas on maybe a conversion plug.. or where on that motherboard would i have to directly plug the wires to use the power button.
  • Kevin Bellanger
    Kevin Bellanger Apr 19, 2015
    the front panel plug is a 34 pin plug.. the power button and power and hd leds are a 10 pin plug that plugs into the front panels board which is carried to the motherboard through the 34 pin plug.. the intel E210882 D945GPB motherboard has a 32/34 socket in the far corner of the board but the socket is quite a bit larger than the plug coming from the front panel. though without any documentation on this motherboard i dont know if that is what that plug is for in the first place.. the motherboard also has 2 usb sockets.. an audio socket.. and an unlabled 9/10 socket right next to the 32/34 socket on the board. im sure if i knew where exactly the power button and leds actually connected to this motherboard i could workaround the problem
  • 1,602 Answers
Www.allpinouts.org/mfg.name/make/model/
www.freeproductmanual.com/mfg.name/make/model/
www.manualsonline.com/mfg.name/make/model/
www.eserviceinfo.com/equipment_type/mfg.name/make/model/
------------------------------ gateway info.-----------------------------
gateway 2000, www.gateway.com/service/mb/pinouts
www.gateway.net
gateway electronics: www.gatwayelex.com
tech:1-800-846-2301, 1-800-846-2000,
customer service: 1-800-846-5259, tech:1-800-444-4257
gateway direct: 1-800-235-4425
gateway electronics: tech:1-800-669-5810 toll free: 1-800-422-7777
if you need more info or research info fixya.com rod gandy
tips and websites guides and data information
Posted on Apr 19, 2015
SOURCE: USB port installation
NavajoGirl,
I have a Jetway 663AS. The USB Header is J5 and is a 10 pin connector with 1 pin missing. It can be found near the battery.
HTH,
Paul
Posted on Dec 29, 2007
  • 2427 Answers
SOURCE: Connecting motherboard ?
Hi,,
ok lets see if i can help you out here
basically IDE 1+2 Is primary and 3+4 is secondary, it doesnt matter where you donnect your harddrive to it will still work ,, the standered is to use 1 and 2
as for the frount usb aint working is cause they are not connected or the wires are mixed up.. basically you can connect the wires to any usb section of the mainboard as long as you connect it propperly.
each wire is labeled and the bord is labelled as well. for example connect ground to ground, v++ to v++, +5 to +5 and -5 to *5 there is a diagram on the manual showing the connection ports location and pin id's it also labebled on the main board.
Posted on Jul 19, 2008
charcois
  • 763 Answers
SOURCE: how to connect usb cables inthe front panel to motherboard Gigabyte GA-6VM7A+
from your case there are wires to put it on the motherboards pin. you can check your motherboard's manual on where to insert the designated wires to the correct pins.
thank you for using fixya
CHARCOIS
Posted on Nov 10, 2008
  • 177 Answers
SOURCE: connection of wiring to board
6a98a1a.jpg For the usb connectors you can follow the diagram above:
For the rest of the connectors I need to know the model number of your motherboard
Posted on Nov 24, 2008
  • 23 Answers
SOURCE: Need Diagram of front panel hook up for Abit MoBo BL30G
try here http://www.abit.nl/ you might find what you need ;-)
Posted on Jan 13, 2009
Lenovo m52 thinkcentre on ubuntu has wireless built in or not?
Have you tried connecting to the internet with a wired connection. It may need to update drivers for your computer. The update option is in the software center I think.
Feb 03, 2014 | Lenovo ThinkCenter M52 PC Desktop
Does my lenovo m52 come wireless ready and if not can i make it connect to wifi?
i try to look for the model and so far it is not wireless ready, pci wifi card is very cheap and easy to install im sure you can do it yourself or i can guide you, if ever you bought one on how to install it
Feb 03, 2014 | Lenovo ThinkCentre M52 PC Desktop
Audio Device
The same model ThinkCentre can have different types of network, video and audio drivers and unless you know exactly which one is installed in your ThinkCentre, you need to download all the drivers and install each driver until you find the right driver. When you download the audio and device drivers, write down the device driver and it's file name so you have a record of which driver you are installing and which directory the unzipped files are located on your hard drive. Go to the IBM/Lenovo WEB site - support/download page and download the latest Windows device drivers for your model computer, Use this link: - http://www-307.ibm.com/pc/support/site.wss/product.do?template=%2Fproductselection%2Flandingpages%2FbrowseByProductLandingPage.vm&sitestyle=lenovo&brandind=10&validate=true
Sep 18, 2012 | Lenovo ThinkCentre M52 8212 - Pentium D...
Looking for and audio driver for lenovo thinkcentre 8212
Hi edmark701...
Sorry I could not find your free audio driver...but I did find a place here on the net that has the drivers but you have to sign up...suppose to be free...you read the fine print and decide if you want to sign up.
Please take time to rate me
http://www.driversforfree.com/omn_ofm_omd_dt/ibm/thinkcentre-m52/8212/audio-and-sound/drivers.aspx
There is also a free one here too, it will allow you to download two drivers free per day with the free edition...be sure to read the fine print...I use it, its not bad at two free drivers per day.
http://www.innovative-sol.com/drivermax/
Aug 31, 2011 | Lenovo ThinkCentre M52 8212 - Pentium D...
Lenovo 8112 sound driver
ThinkCentre M52 (8112) Driver Download
*Brand: Desktop *Family: ThinkCentre M52 *Type: 8112 *Model: Select the model of your System
*Operating System: Your Operating System
*Click on Continue *Refine Results: Audio
Download and Install
Thanks for using Fixya
Jan 25, 2010 | Aureal IBM LENOVO AUDIO CARD- VORTEX...
What dual video card is compatible with the M52?
The 256MB ATI Radeon HD 2400 XT Dual-VGA or Dual-DVI, TV-Out Graphics Card (43R1962)
The 128MB ATI RADEON X300 VGA, VGA PCI-e Dual Head Graphics Adapter (40Y8405)
The 64MB NVIDIA GeForce 6200 VGA PCI-e Dual Head ThinkCentre Graphics Adapter (73P2517)
The 256MB ATI Radeon X1300 Dual-VGA or Dual-DVI, TV-out PCI-Express Graphics Adapter (41U5028)
The 128MB ATI RADEON X300SE Dual-VGA or Dual-DVI Dual Head ThinkCentre and Lenovo PCI-e graphics adapter (41U4813)
The 128MB ATI RADEON X700 VGA, DVI-I, TV-Out PCI-e Dual Head ThinkCentre Graphics Adapter (73P2518)
All above are compatible with the ThinkCentre M52. Hope this helps, Best Regards, - md
Nov 10, 2009 | IBM ThinkCentre M52 8113 - P4 551 3.4 GHz...
Computers & Internet Logo
94 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
