Question about John Deere Garden
How do I keep my 2510 John Deere tractor to not stop running when it gets warm?
Pulling a small 10 ft disc across cornstalks on deer food plot, the tractor stops running after 10 minutes. Tractor restarts after it cools down.
  • 954 Answers
I am sending you an article from homeguides.sfgate.com but they don't mention the first thing I would suspect until the end of the article, which is the coil.
" It can be puzzling when a lawn mower starts easily and runs fine for a few hours, only to stop with no warning. This sudden shutdown can be caused by an overheating engine. Reasons for an engine to overheat and shut down include debris clogging the area around the engine, low coolant levels, a problem with the oil, or an engine mechanical breakdown.
Sponsored Link Consumer Reports Website Find the Top & Worst Rated Products Unbiased Tests, Ratings & Reviews consumerreports.org/Reviews Debris Buildup of grass, twigs, and other debris that block air from reaching the engine can quickly lead to an overheating lawn mower. Debris in the engine cooling fans, engine shroud, air intake screen, grille and/or side panels prevent air circulation that would normally keep the engine cool. If the engine gets too hot, it will shut down and may be damaged. In some cases, the buildup of dry grass may catch on fire. Remove grass clippings from the engine area regularly to prevent this problem.
Low Coolant or Oil Some lawn mowers use liquid engine coolant to keep the engine from overheating, much in the same way as a car. For these mowers, check the engine coolant before each use and refill as necessary. Engines also require lubrication from oil to prevent overheating. Check the oil levels when the engine is turned off and the mower is resting on a level surface. If the level is below the "full" mark, add fresh oil. Ideally, check oil levels after every 20 hours of use, or each time you use the mower.
Loose Fasteners If a mower dies when the area around the engine is clean and oil levels are correct, there may be a problem with the fasteners in the engine. Begin by checking the carburetor mounting bolts and the bolts located where the intake manifold and engine block attach. Popping or puffing noises near the engine head may indicate that the head bolts are not tightened far enough. If noises seem to be coming from the exhaust system, check the exhaust valve. Tightening any of these fasteners that seem loose may solve the problem.
Engine Maintenance Certain problems that cause a lawn mower engine to overheat and shut down require more extensive maintenance to correct. Routinely check engine parts, such as shrouds and cooling fins, for damage and replace as needed. If the engine will not restart until it cools down, the exhaust valve or valve seat may need to be replaced. The condenser and engine coil can also cause overheating if they start to go bad. Maintenance on these systems can be performed at home by removing and disassembling the engine to replace damaged parts, or by taking the mower to a qualified service technician."
I hope that helps! :)
I I
Posted on Apr 23, 2015
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
Sep 25, 2017 | John Deere Garden
How do i check my hydaulic fluid for my 445 tractor
JD Mower Maintenance - YouTube
? 16:56
https://www.youtube.com/watch?v=RYeP_QLhsoU
Mar 31, 2013 - Uploaded by GreenMachine757
Doing routine maintenance on my John Deere 757 zero turnmower. ... DIY Mower Seat Repair - Garden Tractor Seat - Zero Turn - eXmark ...
John Deere Tractors Information - SSB Tractor Forum
www.ssbtractor.com/wwwboard/messages6/
Service Transmission - John Deere Ag - New Equipmentmanuals.deere.com/cceomview/OMM144042.../OMM144042_D010.ht...DO NOT mix oils. These tractors are equipped with a hydraulic wet disc PTO clutch.... DO NOT use type "F" automatic transmission fluid. John Deere Low ...JD 445 Rider Mower Issues - Need Help Please - GardenWebforums2.gardenweb.com > Garden Forums > TractorsNov 12, 2009 - But I've read a lot of threads hoping to read about my issues, and was ...What tools I don't have my friends do, and both are real mechanics, big Deere fans ....it steer hard due to lack of fluid in the hydraulic steering cylinder. ... You may need to add fluid, run the tractor around a bit, and then check it again.
Jan 09, 2016 | John Deere Garden
My brakes are sticking and/or locking up on my john deere 2355 tractor has anyone had this problem and fixed it
Troubleshooting - Operator's Manual - John Deere
manuals.deere.com/cceomview/...J7/Output/OMLVU17926_J716.html
See your John Deere Dealer. Fuel pump not ... Brakes dragging. Misadjusted .... Parkbrake locked. ... Cruise Set/Decel switch is held or stuck on. No cruise ...
Service Engine - Operator's Manual - John Deere
manuals.deere.com/cceomview/OMM139226.../OMM139226_A99.html
Warranty repairs must be performed by an authorized John Deere dealer. ... 3. Push down on front of hood to lock latch. ... brake. 2. Stop engine. Allow engine to cool. 3. Raise hood and latch open. 4. ... Remove right side engine shield from tractor. ....Check engine speeds when engine is warmed up and not under load.
Oct 29, 2015 | John Deere Garden
John Deere troubleshooting
Fuel starvation: Plugged filter or needle valve in the carb. The fuel is not getting to the carb fast enough to keep the float bowl filled.
Oct 30, 2013 | Garden
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
Jul 28, 2012 | John Deere Step 2510 2520 3010 3020 4000...
John Deere LX 255 does not move
most likely its the drive belt.
Jun 14, 2012 | John Deere Garden
John Deere 2510 Diesel will only start if I coast it then put it in gear
Then either you have a dead battery, a bad start soleniod or a bad starter...you need to eliminate each of those pieces one by one till you find the bad part...
heatman101
Aug 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Our new to us john deere 345 tractor won't keep running
You may try blowing backwards from behind the fuel filter into the gas line. Not to much air pressure though. Make sure the gas cap is off.
Mar 13, 2010 | John Deere A,b,g Tractor Carburetor Float...
Garden Logo
220 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
