Question about Sewing Machines
Rs2000 stitch selector dial. where can l buy on in uk
  • Sewing Machines Master
  • 1,860 Answers
Go to your search engine and type in the words parts for a rs2000 machine and it should come up with some sites
Posted on Jun 03, 2015
3 Suggested Answers
mountain_cra
  • 86 Answers
SOURCE: can't move stitch selector dial on singer cg590 c sewing machine
The machine has a 'hold' in the blank (or red) posiiton. You have to push the selector dial in a little bit then turn it. If it is in the red position it will only turn clockwise.
Posted on Sep 10, 2012
SOURCE: the pattern (stitch) selector doesn't work when I turn it
it sounds like you need a new pattern selector dial & it wouldn't
hurt to have the machine checked to see if the internel part of the
dial is ok inside
Posted on Oct 12, 2012
I have a Elna air electronic 68, I am not able to use different function. Like thr preprogrammed.
Your AE 68 will have three dials across the front, from L-R, stitch selector, stitch width and stitch length. To sew any stitch with a sidewise needle movement, you will need to turn the stitch selector to that stitch on the selector, then turn the stitch width to between 3 and 4 and the stitch length to a similar setting, adjusting to get the stitch formation you need. To sew with the discs, set all the dials to zero, then insert a cam into the Elnagraph on top of the machine. Then turn the selector to the disc icon, and the stitch length around to the "S" and stitch width to 4.
Don't use reverse if using the elnagraph stitches.
Jul 01, 2017 | Elna Sewing Machines
I put the stitch in center of dial but it still does straight.what is wrong
If you want a zig-zag stitch, you need to set the stitch WIDTH selector to a higher number. Sounds like you may be changing the stitch Length selector which simply makes a longer straight stitch.
Aug 31, 2016 | Sewing Machines
How do i alter the stitch lengthbon Bernina 1080
The bottom dial on the right of your machine is the stitch length selector. The dial at the top right is the stitch width selector.
Dec 05, 2015 | Bernina Sewing Machines
How do I set the dials on husqvarna viking 6000 sewing machine
The "dial" in the back is for decorative stitches which require a "programmer" to be inserted with the stitch formation you want to form. For a straight stitch no cam is required in the back of the machine. The three dials on the front:
Upper Left: Stitch selector
Upper Right: Stitch lenght
Lower: Stitch width
Using the upper left dial select the straight stitch picture
Using the upper right, choose your stitch lenght
Using the lower, choose your needle position, left/center/right
Dec 13, 2014 | Husqvarna Sewing Machines
How do I adust the tenion for a straight stitch on a BrotherXL-3510?
Set the stitch selector to straight stitching.
Set the stitch length to 2.5
Set the thread tension dial (leftmost dial) to 5.
Done
Sep 10, 2014 | Brother XL-3510 Mechanical Sewing Machine
Singer sewing machine
From the pattern selector (the bigger dial), select the zig-zag stitch. Then, using the stitch length dial (the smaller dial), adjust the stitch length. The closer your stitch length is to "0", the more dense will your zig-zag stitch be.
Sep 04, 2014 | Singer 2250 Tradition
TRADITION 2250 SINGER SEWING MACHINE HOW TO ZIG ZAG
The pattern (stitch) selector doesn't work when I turn it
dial is ok inside
Oct 11, 2012 | Singer Featherweight II 117
I have a Toyota RS2000 the stitch selection knob cracked I have ordered a new one which I have received but the knob will not tighten onto the switch selection shaft because metal strip is missing inside...
I have the same problem. I found the little metal piece down inside the machine. Shake the machine and see if you hear a little rattle. It might be that little metal piece. Bad design on that selector knob, for sure.
Apr 20, 2011 | Toyota Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
