Question about Sony Televison & Video
I have a 46in vision TV I'm having problems with.. I also have a 46in Sony that needs its screen replaced can I use the screen from the visio an put it on the Sony ..
    Top Expert:
  • Sony Master
  • 74,198 Answers
No. Both are entirely different. They are not compact-able.
Posted on Apr 19, 2015
  • Sony Master
  • 2,355 Answers
No, two different manufacturers.
3 Suggested Answers
SOURCE: Visio TV and Direct TV remote
I bought a 42" Visio LCD from Costco and used code 10030 and it worked. It is the code for Goldstar TV.
Posted on Sep 20, 2008
sonicboomele
  • 1557 Answers
SOURCE: I have a Westinghouse 46in LCD tv with a cracked
no as experts we very rearly do them
Posted on May 08, 2012
How do I get my Sony universal remote to work with my Visio tv!
On your Visio TV remote control there will be a Source button or Input button. Press it & on your TV screen select HDMI 1 or HDMI 2. See the TV to see how the HDMI cable is connected from TV to Set Top Box. Now take the other remote control i.e. Sony Universal remote in your hand. Press mute & Select simultaneously. A blue light will blink twice, Immediately release the buttons & enter the code. You have to be extremely fast in doing this.
Following are few codes which you can try:
002, 000, 011, 080, 111, 006, 071, 128, 1904, 925, 0000, 0834, 0810, 1685, 1786, 1032, 1972.
Check the Visio TV manual for the make of your TV & model no & if code is printed. Then contact Visio TV manufacturer or retailer for the Visio TV code to enter & synchronize with the Sony Remote Control.
Nov 13, 2016 | Sony Televison & Video
Visio 1080p screen went light
Our Visio 42" flat screen TV did the same thing. It didn't happen that often but sometimes it would go darker or the sound would go off until I changed the channel or turned TV Off then back On. I contacted Visio through my warranty and they sent me a flash drive to install info on my TV. Did not fix the problems. A year later before warranty ended I contacted Visio again. They sent a huge box for me to pack my TV in to send to the warehouse where they fix everything. It took about 2 wks. to get it back. Worked fine for about 4 months and the problems continued. I will not buy another Visio TV. I found out that they had many problems with several models.
May 03, 2014 | Televison & Video
LCD displays 4 white lines and has double vision
I saw your tv pictures at above mentioned website link.
It is LCD Panel (screen) problem, call Sony and ask for warranty cover to replace lcd panel.
Thanks.
Jul 18, 2010 | Sony KDL40EX400 40 in. HD-Ready TV
Flickering screen
Two models of the 46 inch Sony Bravia have a screen flicker problem. On my 2008 model, starting from cold, it lasts for 5-10 min, on LHS of screen. The Telefix tech who visited said this is common with these models (46in only), a new panel is needed. Sony provides warranty on this fault for 3 yrs, so you do not need extended warranty to claim. Discuss your case with Sony or Telefix.
Jan 03, 2010 | Sony Bravia KDL-46V4100 46 in. LCD HDTV
I got a broken screen on my 46in sony bravia can it be fixed ?
HELLO
If the screen is broke, then to have it replaced will cost just a much as a new TV!
Sorry! (:-(
Nov 11, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Digital alignment on my Hitchi 46in projection tv
If the set cannot converge it self then the convergence ICs need to be replaced. Check local professional for prices
Apr 21, 2009 | Hitachi Televison & Video
Sony 46in hdtv picture and color has triple vision
Your TV most likely has one of two possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 22, 2009 | Sony KP-46WT520 46" Rear Projection...
Double vision with redness
  • Screen looks 3D
Dec 10, 2008 | Sony KP-53V85 53" Rear Projection...
Double Vision....
the problem on my sony projection tv is double vision,what equipment i need and how much it is. also is it easy to fix on my own?
Mar 08, 2008 | Sony KP-51HW40 51" Rear Projection...
Sony 46" tv picture
Is this a projection TV, or a flat screen model?
Feb 15, 2008 | Sony 46IN TV Stand Designed for Model...
Televison & Video Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
