What thermocouple should I buy for this unit. I notice they have a watt rating and I can't find out what mine should be on the unit or in my manual.
    Top Expert:
  • Heating & Co... Master
  • 44,260 Answers
Contact the manufacturer website and ask tech support .
Posted on Apr 19, 2015
Technical data
lumens is a measure of light intensity
the lower the number the duller the light, the higher the number the brighter the light average shops have a level of limens around 750 as this is the safe light level for eyes
Wattage is current flow ( amps) and was used as a measure to show the intensity of the light
12 watt bulb is dull in 240 volts situation where a 500 watt bulb as in ( quartz halogen bulbs) is something that will blind you
You will notice a change in readings from incandescent bulbs-- the old units that had a filament in them--20 watt, 40 watt,60 watt, 100 watt to fluorescent lighting where the power saver bulbs have a rating of 12 watts is equal to 60 watts of the old bulb ( a rough attempt to show the lumens ratings )
this was an attempt to compare the light intensity so that customers could see how bright the new bulb would be
Now that there are LCD units , the wattage is so low that a comparison cannot be made so the shift is to lumens as a measure of light intensity ---in reality the results are the same
for example a torch with 3 X aaa batteries as a low lumen rating as you can see by the brightness of the light and if you compare that with the lumens rating of driving lights that light up the road for miles
the wattage(amps)for the big lumens rated lights will still be low compared to the head light s in current use
Mar 10, 2016 | Televison & Video
Dyna glo ra18lpdg pilot won't stay lit.
would have to think the thermocouple need replaced or the pilot flame is not big enough
Jan 31, 2015 | Heating & Cooling
The air cleaner fell off and the nuts that hold the air cleaner on also holds the carb. on
If the studs are there to hold it all in place then just buy the correct ( metric probably) nuts for it.
Dec 08, 2013 | Sunpentown 2,800 Watt 6.5HP Power...
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
Jun 29, 2013 | Hardware & Accessories
How many Watts will 1350 btu RV roof model use? I have a Dometic 641815 model . I want to buy this Yamaha 2400 watt generator.
Hello, I have the same exact generator, 2400 Yamaha. It works fine for my Ac, and then some. After it first kicks on, is the biggest surge. Then I have even after ac is running, I have had tv on and even used microwave. But as far as running you ac on your rv , not problem. I do it all the time. Mine is ulta quite, and 8 to ten hours run time on about a gallon of fuel. Mike
Oct 29, 2011 | Dometic Rooftop RV Air Conditioner
What size circuit breakers should I use for my 225 welder?
Look on the specifications plate...there will be an input voltage and/or current/wattage rating. If you need to convert watts to amperage then you would use the following formula:
p=e x i or watts divided by volts will give you the current(amps). I think that unit is 240vac(mine is) and I use a 40A 240vac breaker and have no problems(thats 9600 watts)..you will want to choose a breaker as close to the max rating as possible...don't go too high or the breaker won't trip if something goes wrong
Dec 16, 2010 | Lincoln Electric K1170 AC-225 Stick Welder
My heater is not very old, but the thermocouple has gone bad. the pilot lights, but the thing won't stay lit. Where can I buy just the thermo? Thanks, tejondepuebla@gmail.com
Most of these units use a standard Honeywell thermocoupler but not in all cases, remove bad one and compare or look in manual.
Oct 04, 2010 | Dyna-Glo RMC-8001SS Heater
I like most of you have had problems keeping my Model 920-0010 patio heater lit. Mine would shut off after about 10 minutes. I found that the thermocoupler was the problem. Not the thermocoupler itself but...
That is not the fix ...although it works...the pilot light is dirty as you suggested...it really needs to be taken apart to be cleaned properly....the pilot should NOT fluctuate in size after any amount of time...if it does the pilot is dirty , it's windy , or the gas valve could be defective....the pilot should be large enough to envelop the thermocouple...outdoor units get spiders etc also that block the pilots etc.....the problem with your solution is when the pilot isn't of sufficient size it's supposed to go out...the reason being you could get "Delayed Ignition" if the pilot is too small to light the burner or as a result of being small...is too far away from the burner
Nov 12, 2009 | Heating & Cooling
Generator fails to start microwave
I had to buy a 2000 watt inverter type to run mine
Apr 06, 2009 | Whirlpool GH7145XF Microwave Oven
Psu
200 watt max. 19v DC power brick with a 4 pin plug, with two positive and two ground pins. The PSU is unique to the E-bot. I have not been able to find an exact match anywhere. Foxconn no longer sells the PSUs and will not help with tech support in any way. The PSU was originally produced by Fortron Source Power (FSP). When mine went bad, I had to buy a similar looking unit (but with only a 150 watt max rating), then I had to rewire the output cord, because the 4 pin plug had the positives and negatives switched around.
If you need a new power brick for the Ebot, I seriously hope you have the old original unit still. If you do, you can then simply buy any 19V laptop power brick that has acceptable power output (at least 120 watt) and then replace the power output cord with the original one from the Ebot's power supply (some soldering required). It's really the only way to replace the unit.
Jun 23, 2008 | Foxconn eBOT Barebone
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
