Question about Grohe Plumbing
How to remove escutcheon on grohe geneva? - Grohe Plumbing
2 Suggested Answers
  • 50503 Answers
SOURCE: Grohe Geneva cross handle bathroom faucet dripping. Is a slow but steady drip. Ideas how to fix?
probably a faulty washer in the tap
call a plumber to fix in not a handy person
Posted on Nov 06, 2016
Nov 06, 2016 | Grohe Plumbing
I can not get the handles off. there are no screws
There is either a screw under a cap from the top or a set screw from the side. Looked at about 200 Grohe diagrams and they all have that arrangement.
Aug 07, 2012 | Grohe Seabury Widespread Lavatory Faucet...
The plastic end piece which fits into the Milano towel bar has broken so that the towel bar doesn't stay in place. I don't know where to find a replacement.
"Milano" or "Geneva"???
Geneva 24" Towel Bar:
http://www.grohecatalog.com/product/40146
Contact Grohe. They might just replace the broken part.
http://www.groheamerica.com/en/contact-grohe/p/25_16615.html
From their web site:
"For Warranty or Replacement Part information
Please be sure to provide your product / part number, type of product finish, the original install / purchase date of the item in question and leave your shipping address (cannot be a P.O. Box), daytime phone and (if available) a fax number, in order for us to contact you if necessary or promptly send your requested information and/or part(s)."
To fill out an online request form:
http://www.groheamerica.com/en/contact-grohe/customer-service-email/m/25_16617/page/modules/formchain/
Feb 08, 2011 | Grohe Geneva Chrome 24" Bathroom Accessory...
Cannot get the hot water handle off. Have remove the collar and the base, handle will still not come off
im not 100%sure on the particular set of taps you have ,but by looking at the picture on screen ill hazard a quess.by the way im a plumber .under the lever for hot water tap is a cone shaped shrowd .narrowest at its point where its in contact with lever and broadest at bath top end .this shroud will screw off .in the middle of the lever you pop off insert and unscrew cross head screw and then back off shroud ,the tap spindle should then be exposed
Jan 19, 2011 | Grohe 25.506.EN0 Geneva Roman Tub Filler...
I have a grohe 19 614 thermostatic valve / mixer. I want to adjust it so that the wateris hotter than what is coming out right now. I have the diagram showing how to take the trim off, and shows where to...
http://docs.homeclick.com/PE-Links/Grohe/Grohe-19614-manual.pdf
1. Turn thermostat handle (L) to the 100 °F (38 °C) safety
check, see fig. [6].
2. Unscrew handle (N) or lever (O).
3. Unscrew cap (M).
4. Pull off thermostat handle (L).
5. Remove screws (H) and escutcheon (G), see fig. [4].
6. Close both isolation valves (I).
7. Pull sleeve (F) from the mixer shank by pressing
down the tongue (D2), see fig. [7].
8. Extract clamp (D1).
9. Pull stop ring (D) until resistance is encountered
(approximately 3/8" [10mm]), see fig. [8].
10. Unscrew stop ring (D) complete with regulator
nut (K).
11. Unscrew thermoelement (47 050, 47 582) with 24mm
open-ended wrench, see page 2.
It is not too clear to me, but I'm not looking at it. lol
Gary
Dec 14, 2010 | Grohe Grohmix Thermostat Valve & Trim -...
I have grohe geneva 20 801 faucet. How do I remove the handle lever (part 45 790)? I removed the decorative cover (45 783) over lever and also the screw inside the handle and lossened piece below it but...
None of the above solution pertains to Grohe 20 801. What I did was ...
After undo the phillips head screw inside the decorative piece, pour a lot of lime away into the hole, flooding the hole if possible, wait a while. The parts are just bound together with deposits after years of wear and tear. Now, take a hammer and use the prying end to pry up the handle with all your might and you hope it would come out. The handle came up for me after working it loose for about an hour.
Apr 18, 2010 | Grohe Plumbing
How to remove diverter cartridge in shower 1 handle
Follow these steps.
  1. Remove Set Screw in handle and remove handle.
  2. Remove the 2 screws from the handle housing and remove the housing and escutcheon from escutcheon adapter plate.
  3. Remove valve stem screw and valve stem coupling.
  4. Remove the escutcheon adapter screws and escutcheon adapter.
  5. Using a pair of pliers pull the cartridge retaining clip out of the valve.
  6. Grasp the cartridge by the stem and pull out.
I hope this is helpful to you, please rate if this answer was of any help. Good Luck and have a great weekend.
Apr 02, 2010 | Moen & One Handle Tub & Shower Faucet
Plumbing Logo
189 people viewed this question
Top Grohe Plumbing Experts
john h
Craig Butler
Craig Butler
Mike
Are you a Grohe Plumbing Expert? Answer questions, earn points and help others
