Question about Electrical Supplies
I have A Steele 3250 watt generator 196 cc OHV engine gas powered and it wont start.what do Can l do too fix it?
    Top Expert:
  • Electrical S... Master
  • 42,217 Answers
Turn on the ignition switch
check and bring the oil to the correct level
check for spark
check choke operation
check low oil level switch is operational
Posted on Apr 19, 2015
SOURCE: generator shutting down after 1.5 of run time
I had the same problem with a simular generator. I took it to a repair shop who told me it was the "low oil sensor". They fixed it and it lasted another 1.5 hours. I told my-self I would monitor the oil and cut the "low oil sensor" electronic line. It has laster 12 years as a backup generator running at least 200 hours per year. I still have it but have switched to a larger generator. If you, or whoever uses it, can watch the oil level, then cut this line, it will be fine. This sensor is for those who are not able to measure oil level !!!
Posted on Sep 21, 2008
sal_kh_sab
  • 98 Answers
SOURCE: i have a 3000 watt generator american camper6.5hp
one idea is to check the amount of oil you are putting in....remember...you mustn't flip the gen. to fill it....keep it level and keep filling until the oil level is visable and about to drip out...that's the right amount....if you overfill it it will cause the problem you pointed.
Posted on Nov 05, 2009
stunt driver
  • 5 Answers
SOURCE: Older Coleman 3500 Watt generator, sitting for
there can be many reasons. need more info:
Is it Inverter typr generator?
measure output voltage - anything?
take back cover off generator itself, measure continuity of stator and rotor, and visually inspect windings. You'll find AVR module there too, it may be the reason.
Posted on Jan 13, 2010
  • 142 Answers
SOURCE: 11 hp 5700 watt generator wont fire
If you could not start in spite of oil and gas change, checked gas supply, spark plug, ignition cables and coils (magnetos) and so on whitout success, then try this:
Your generator has a low oil level protection, which stops the ignition of the motor.
After "a couple of years" sitting without or with old oil, the level switch may have got lazy or stuck down.
If your oil level seems to be good, while measured, find the oil switch and try to shorten or disconnect it.
If you succeed in running the generator change or repair the oil switch.
I hope that this will be helpful, because I don't have your device in front of me, but some people rank such an answer with 2 thumbs, which means useless. Better dont rank.
Posted on Jul 24, 2010
SOURCE: my 5700 watt 11 HP McCullough generator wont
The spark coil is bad if you have no spark
Small engine repair. Part is expensive.
Have you checked spark for sure?
1) Spray WD-40 directly into carburetor
If machine has spark, it will fire
2) Is exhaust port clogged with carbon and dirt?
3) Get new spark plug
Pull out old spark plug
Put spark wire on plug
Hold spark plug wire with fingers
Put spark plug threads against metal opening where spark plug came out.
Metal to metal
Pull cord or push starter
Look for spark between metal
No spark, then spark coil is bad.
Posted on Oct 26, 2010
Has gas in bowl and fire but wont start without starting fluid
McCulloch u spray starter fluid Power Generators Questions ...
www.fixya.com > Forum > Tags > u spray starter fluid > Power Generators
McCulloch power generators u spray starter fluid related questions and ... Question about 13HP 338 Cc Portable Generator # FG6000MK ... My 5700 watt 11 HPMcCullough generator wont ... My generator will start if I spray it with either but won'tstay running in less I keep ... The bowl has gas in it and the needle is clean.
This generator McCulloch fg6000mk 11hp has no spark. I've ...
www.fixya.com/.../t7785814-generator_mcculloch_fg6000mk_11hp_no
Jan 13, 2011 - this generator McCulloch fg6000mk 11hp has no spark. I've checked the gas bowl , a small amount of water in the - McCulloch ... water in the bowl not much also sprayed a small amount of starting fluid in .... My 5700 watt 11 HPMcCullough generator wont start. I'm getting good gas to the plug but no spark.
Won't start. I have a never used McCulloch 5700 11HP ...
www.dqrkc.com/support/t1325485-start
Dec 2, 2008 - Question about McCulloch 13HP 338 Cc Portable Generator # ...evaporated. you might tryt a little spray starter fluid in the spark plug ... My generatorwill start if I spray it with either but won't stay running in ... The bowl has gas in it and the needle is clean. ... My 5700 watt 11 HP McCullough generator wont.
1325485 Won't start. I have a never used McCulloch 5700
Jan 21, 2016 | McCulloch 11 HP 5700 WATT GENERATOR
Have a steele 6000 will start but then dies
just search on You tube as Pakistan free energy Magnet motor. you will forget generators. See professor Yel free energy magent motor in delft university on Youtube.
Oct 17, 2015 | Steele Products 6000 Watt Portable...
My Nikota 3500 watt 6.5hp OHV Engine Electric Generator all of a sudden quit running. I am getting gas and fire to the plug,but it wont start. I am lost and need help.
replace the gas with fresh and treat it with Startron additive to fight against the ethanol in gas and keep it fresh. gas goes bad in a bout a month if not treated now. you might have to take the carb bowl off and clean the carb. good luck hope this helps
Feb 23, 2015 | Electrical Supplies
Runs at a galloup but wont continue to run
check spark plugs and engine carbon level. change filters. otherwise search on youtube about delft university free energy magnet motor.
Apr 15, 2014 | Steele Products 3250 Watt Portable...
Steele 9000 watt generator won't start
Hi Derrick
I assume you can turn over the engine, and the engine has run previously?
Check for spark, -take off the plug lead and connect an old spark plug to the ignition lead open the gap up to about 5/16 inch . Tie the thread of the spark plug to the engine to hold it and earth it with a bit of soft wire. Wind over the engine you should get a nice fat blue spark. If you get a nice spark do you can eliminate ignition issues. This just leaves fuel. You can then focus on this.
Jacko
Apr 13, 2014 | Steele Products 9000 Watt Portable...
How to start a gas generator (should the choke be in or out, to the right or the left before starting
Most Generac generators have a lever for the choke that pulls out. So if the generator is being started for the first use or cold you should choke when starting . Let it run for 30-45 sec. then push it in . Once the engine has been run or warm you dont need to choke every time when starting .
Nov 04, 2010 | Generac Power Systems Generac 0057890 3250...
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Electrical Supplies Logo
100 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
