Question about Task Force 2000 PSI Electric Pressure Washer NEW 6127
Where is the in line filter and how do I take it off and check it do you have to take off the cover
    Top Expert:
  • Task Force Master
  • 44,510 Answers
The inline filter is normally at the pump connection for the hose
it is a brass gauge located under the seal ring for the connection
Posted on Apr 19, 2015
Where is fuel filter on a 2001 intregue
Instructions
    • Open the hood to access the engine compartment. Locate the fuse panel behind the battery. Open the relay cover and locate the fuel pump relay. The cover will have a diagram to pinpoint the exact relay.
    • 2Pull the relay out of the fuse panel and place it to the side. Start the car and allow it to idle until it stalls out. This will depressurize the fuel system.
    • 3
    • Locate the fuel filter underneath the car directly under the rear driver side door. The filter will be a foot in front of the fuel tank.
    • 4Unscrew the outlet side with an open-end wrench. Use a second wrench to hold the stationary nut on the filter; this will prevent the filter from turning. Pull the fuel line away from the filter.
    • 5Squeeze the clip on the inlet side by hand and pull off the inlet pipe of the fuel filter. Pull the fuel line away from the fuel filter.
    • 6Unbolt the filter from the mounting bracket to release the filter. Replace with the new filter. Tighten the mounting bracket with a socket wrench.
    • 7Push the inlet line onto the fuel filter by hand. The line will lock in place.
    • 8Screw the outlet line onto the fuel filter by hand. Tighten with a wrench to ensure the line is secured. Use a second wrench to prevent the filter from turning.
    • 9Insert the fuel pump relay into the fuse panel. Close the fuse panel cover back onto the fuse panel.
    • 10Turn the ignition to the "run" position and hold for three seconds. This will engage the fuel pump to prime the line. Turn the key off and repeat again. Attempt to crank the car to circulate the fuel into the fuel line.
    • 11Allow the car to idle for five minutes. Inspect for any fuel leaks before turning off the car.
Nov 30, 2012 | Cars & Trucks
I have a clogged fuel line (filter?) I do I remove the bushing without damaging it?
FUEL FILTER
(For 40/55/60/70/110/115/155/165 Models
Only)
1. Remove side cover screws using 5/16" nutdriver.
2. Remove side cover.
3. Pull upper fuel line off fuel filter neck (see
Figure 15 or 16).
4. Carefully pry bushing, fuel filter, and lower
fuel line (110/115/155/165 Models only) out
of fuel tank (see Figure 16).
5. Wash fuel filter with clean fuel and replace in tank.
6. Attach upper fuel line to fuel filter neck.
7. Replace side cover.
Jan 20, 2012 | Reddy Heater-70,000 BTU Kerosene w/T'stat
Where is the filter on my rs2630
Removing and replacing a water filter - inside liner location
Filters situated in the interior liner of the refrigerator compartment of Samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Grasp the filter and make a one quarter turn to the left. There should be an indicator line located on the filter bracket cover. The install mark on the filter itself will line up with this indicator line.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard the used filter.
  4. Remove the new filter from its packaging, and remove the red plastic cap from filter cartridge.
  5. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  6. Line the install mark on the filter up with the indicator line found on the filter bracket cover. Push up on the filter. Turn the filter a quarter turn to the right to lock it in place. The remove mark on the filter should line up with the indicator line of the filter bracket cover.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Aug 19, 2011 | Samsung RS2630WW Side by Side Refrigerator
I need to gain access to the fuel filter system on a 2001 Chevy Malibu. There seems to be a metal covering the underneath side of the car so I cannot even trace the fuel lines to find it without removing...
Have you checked around the back wheel, passenger side? That is usually where they are. The cover is to protect the gas tank, so you might not be down far enough. It should be on the left side. You shouldn't have to take it off to get to the fuel filter. Check that back area. Remember, your gas cap. The gas goes in there, so in that area, there is a gas line. Follow them and you will see the other gas lines. Follow them and you will see the filter. Hope this helps. If you have a question, let me know.
Mar 04, 2011 | 2001 Chevrolet Malibu
How do you replace a 2001 Mazda 626 Fuel Filter
Fuel Filter On all models except the Millenia, the fuel filter is attached to a bracket located in the left rear of the engine compartment, next to or beneath the brake master cylinder fluid reservoir. On the Millenia, the fuel filter is located beneath an access cover in the trunk. Access to the cover is achieved by removing the trunk mat to expose the cover.
REMOVAL & INSTALLATION Except Millenia
  1. Before servicing the vehicle, refer to the precautions in the beginning of this section.
  2. Properly relieve the fuel system pressure.
  3. Remove or disconnect the following:
    • Negative battery cable Fig. 1: Exploded view of a common fuel filter and related components 7923mg68.gif
    • Air intake hose and/or filter housing, if necessary
    • Fuel line clamps, if equipped
    • Fuel lines from the filter and plug the openings
    • Filter clamp bolt/nut by loosening them.
    • Fuel filter from its mounting bracket
    NOTE: Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position. To install:
  4. Install or connect the following:
    • Fuel filter in its mounting bracket, making sure the flow arrow is pointing in the proper direction
    • Fuel lines to the fuel filter
    • Air intake hose and/or filter housing, if removed
  5. Pressurize the fuel system and check all connections for leaks.
Millenia
  2. Insure the ignition switch is OFF.
  3. Relieve the fuel system pressure.
  4. Remove or disconnect the following:
    • Trunk mat
    • Service hole cover
    • Fuel lines from both ends of the fuel filter
    • Fuel filter and bracket
    • Fuel filter from the mounting bracket.
    To install:
  5. Install or connect the following:
    • Filter in the bracket. Tighten the nut to 70-95 inch lbs. (8-11 Nm).
    • Fuel lines to the filter
    • Trunk mat
  6. Run the engine and check for any fuel leaks.
Oct 17, 2010 | 2001 Mazda 626
How to relplace fuel injectors 02 chevy trailblazer
Thanks for contacting Fixya.com.
The fuel filter is located on the driver's side, centered between the front and rear tires, along the inside of the frame.
There happens to be a hole in the plastic covering that runs from just under the transmission back to the rear axle. If you can manage to remove the filter without removing the cover, you're better at this than I am.
After removing the cover, which entails removing a cross bar, four bolts and two nuts, the rest is easy. Make sure you have something to catch the gas that will drain from both lines. Squeeze the the blue clips on both lines to pop them off the filter. (This is when all the gas drains out). The filter is held in place with one screw (phillips) located above the filter. Remove old filter and replace with new. The new filter should be labled with "OUT". That line is the line that goes up to the engine. You will need to remove the blue clips from the old filter and snap them onto the new filter. Snap the fuel lines on the filter, tighten strap that holds the filter in place, replace the plastic cover then you're done.
Let us know if you have something more to know else please accept the suggestion.
Thank You.
Jun 01, 2010 | 2002 Chevrolet TrailBlazer
Where is the fuel filter on a 2000 Mazda Millenia 2.3 V6
Fuel Pump-Mounted Filter
    • Fuel pump cover plate
    • Fuel lines from the fuel pump
  4. Raise the fuel pump from the tank.
  5. Remove the fuel filter assembly.
To install:
  1. Install or connect the following:
    • Fuel filter to the fuel pump. Lower the pump assembly into position
    • Fuel lines
  2. Start the vehicle, check for leaks and repair if necessary.
  3. Install the fuel pump cover plate.
Inline Filter
Exploded view of an in line fuel filter and related components
  • NOTE Note the direction of the flow arrow on the filter so the replacement filter can be installed in the correct position.
    To install:
    2. Pressurize the fuel system and check all connections for leaks.
    May 24, 2010 | 1998 Mazda Millenia
    2007 Royal Star Tourer Deluxe with 9K...gasoline
    You didn't mention where the fuel is coming from, so I'll start from the fuel pump; if it's not leaking with the key off, it has to be between the fuel pump and the carburetors.
    First, remove the driver's seat, then the left side cover (it's the color matched cover under the front seat; it's held on by one bolt, the one toward the back of the motorcycle, and a friction pin through a grommet on the inside of the side cover, low and toward the center of the bike). Next remove the center cover, held on by pins and grommets on both sides. You've now exposed the fuel pump and filter, you can see the supply line from the fuel tank to to the pump, the output of the pump to the filter, and the line from the filter back toward the carburetors.
    Check all exposed hoses and clamps for cracks, tears or loose connections. If none are evident, turn on the key; you should now be able to detect the source of the leak IF it's in the vicinity of the fuel pump and filter. The pump puts out 2-3 lbs. of pressure; a leak in that area should be obvious.
    If you've detected no leakage there, reinstall the center cover, then the left cover, and proceed to the vicinity of the fuel tank and engine. Remove the fuel tank mounting bolts (there are two under the front of the tank, through tabs on the underside of the tank to the sides of the frame; there is also a bolt through a special washer and rubber insulator to the top of the frame at the rear of the tank. Lift the tank enough that you can see the fuel feed lines on both sides, as well as the fuel supply line from the fuel pump and filter. Examine lines on both sides, looking for cracks, tears of loose connections. Turn on the key, a leak in this vicinity should be immediately evident.
    If none of the supply lines are leaking, the carburetors will have to be removed individually and checked for stuck needles, bad floats, or leaks in the carburetor housing. Those leaks, however, are typically sufficiently small that they would not be described as "gasoline pouring out".
    Mar 18, 2010 | 2007 Yamaha Royal Star Tour Deluxe
    Leaks at the filter of a frigidare side by side SXS FEFRIGERATO
    Assuming this is a side by side, with the water filter located at the top back of fresh food side, assuming filter is unclogged, i.e., new, check the housing that the filter slips into, that which you actually grasp and turn to remove the filter. If there are any cracks in this filter housing, you will need to replace it. If the cover is sound, the problem will lie within the housing assembly, that which you screw the filter cover into. This housing is held on with 2 or 3 screws. IN order to remove the water lines, you must squeeze the white collar towards the housing, away from the water line, while at the same time gently tugging the water line. If you squeeze the collar correctly, the line should come right out. Make sure to connect ONE line at a time. Do not disconnect both and reattach at the same time. If the lines are reversed, you will damage the filter and possibly water system itself. attach water filter and check again. if filter cover is ok, and this does not fix your problem, without personal inspection, i cant help you further. You can reply here or send me a question from my website: www.FixMyFridge.net
    Mar 15, 2010 | Refrigerators
    Air intake loud "humming" noise
    check to make sure nor of you vaccum line is not loose and all your clamps are tighten sound line a line is off the system and your intake is not tighten properly
    Jul 01, 2009 | 2004 Honda Accord
    Task Force 2000 PSI Electric Pressure Washer NEW 6127 Logo
    132 people viewed this question
    Top Task Force Garden Experts
    Tom Chichester
    Bill Boyd
    Are you a Task Force Garden Expert? Answer questions, earn points and help others
