Question about Poulan Garden
Hard to get clutch to disengage without having to cut mower off
    Top Expert:
  • Poulan Master
  • 51,139 Answers
Check for rusty pivot points for all levers
lubricate with a good penintrant oil
Posted on Apr 19, 2015
  • 6 Answers
SOURCE: Mower shuts off when clutch is disengaged.
Check your seat adjustment to make sure you're applying constant pressure to the safety switch under the seat.
Posted on Apr 22, 2009
  • 153 Answers
SOURCE: Dies when clutch disengaged
It sounds like the seat switch is disconnected or failed. Check it out. If it thinks there is no **** on the seat it will cause your symptoms.
Posted on May 26, 2009
lester482529
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
YOU MAY HAVE A BENT BLADE OR EXESSEIVE BUILD UP UNDER THE DECK
Posted on Jun 01, 2009
  • 33 Answers
SOURCE: Sears 18hp starts but cuts off when clutch is released
chances are your seat safty switch is bad,
Posted on Jul 04, 2009
SOURCE: craftsman riding mower blades won't disengage
This is too late, but for the next person: There is an extension spring around the cable attached to the blade engage/disengage lever.
On my tractor one end of the spring had the hook broken off or it. Because it is around the cable it is still in place but doesn't stretch when you engage the blade (so can't pull the pulley out and slacken the belt when you disengage).
The replacement is a few dollars and can be bought on ebay or Amazon.
Posted on Aug 04, 2012
Why will a cub cadet lawn mower cut grass a few mi. then stop cutting?
Sounds like the electric PTO clutch is bad and needs to be replaced.The straps within the clutch brake causing it to get out of position and the clutch keeps disengaging. You can buy the clutches on line cheaper but they don't last as long.
Apr 22, 2015 | Cub Cadet Garden
Clutch won't disengage on my Riding Mower
WITH THE ENGINE TURNED OFF, open the hood and watch the engagement cable. engage mower lever and then disengage the switch sounds happy, possibly the cable is starting to seize up
Apr 19, 2014 | Husqvarna Garden
Clutch does not disengage gears
You either have a hydraulic clutch system or cable. What probably happened is your hydraulic system failed. You either have a separate reservoir for the clutch master cylinder or it shares the brake reservoir. Check under the hood next to you brake master, Too difficult to answer without more info on year, make and model.
Dec 15, 2013 | Garden
I have a rzt 54 cub cadet, when i engage the pto it cuts breifly then the mower shuts down PLEASE HELP
A battery going bad may be your culprit. I found out just the other day that your mower can keep running but when the battery gets too weak, the pto clutch disengages and shuts down,
Apr 29, 2012 | Oregon Scientific Electric PTO Clutch for...
Cutting blades won't disengage
Check you blades to see if one is bent. Do this with the mower NOT RUNNING and the KEY OUT of THE IGNITION! Look under the deck to see if one is bent. This will cause the wobble. As far as no disengaging your electric clutch could be bad. The bearing could have seized up.
Apr 24, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
After cutting for 20 minutes engine stalls. Disengage cutting blade and engine runs .
is this a lawn tractor with an electric clutch?if so the clutch could be drawing too much power after it warms up and needs to be replaced.
Aug 11, 2009 | Garden
The pto keeps disengaging but comes right back on when reset
I would check the clearence on the clutch you need a 10 thou feeler gauge and a 1/2 or 9/16 spanner there is 3 holes around the sides that is where you measure the clearence if too wide adjust the 3 nuts accordingly
Jun 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
42 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
