Question about Coffee Makers & Espresso Machines
How do I find fuses
The heater doesn't have any power. the front panel is fine.
    Top Expert:
  • Coffee Maker... Master
  • 46,364 Answers
Do not believe there are any serviceable by consumers
Posted on Apr 18, 2015
94 econoline no blower fan front or rear.
What fuse did you Check and where ? Inside fuse box ? Fuse # 9 15 amp . this fuse powers the control panel for Heater/AC ! Pull control panel an check pink / black wire for B+ voltage with key in run position . If there is power then check yellow / red for B+ power with the switch on .
Dec 02, 2016 | Ford Cars & Trucks
Rear wiper doesn't work
check rear wiper fuse and relay.if wiper motor getting power but do not work.rear wiper motor bad.if fuse and relay okay but no power going to rear wiper rear wiper switch could be bad.
May 14, 2013 | 2000 Seat Ibiza
Heater in the front doesn't blow. could it be a fuse?
Yes ,Or it could be the blower motor is burnt out,
Nov 29, 2012 | 2001 Chevrolet Tahoe
How do i check to see if the fuse went out for my heat
Do you want to know why the blower doesn't work? If so, start at the underhood junction block and check the 30A BLO MOT maxi fuse which feeds power to the blower control module. Next, at the instrument panel junction block, check the 10A CSTR/SBM fuse and the 10A HVAC fuse. Both of these supply power to the heater and A/C programmer and the HVAC fuse also supplies power to the heater & A/C control. If all fuses are OK and everything is operating except the blower motor, check the voltage across its BLK and RD leads. The blower motor may be no good
Oct 27, 2012 | 1998 Buick Park Avenue
2005 Honda Odyssey left front power outlet doesn't work.Right one works fine.How do I fix
using a test light check the fuses in the fuse panel then check for power and ground at the socket. if one is missing remove the socket and check for power and ground at the electrical connector. if you have both the socket is bad and needs replacing. if you missing one you will have to check that wire to find were the problem is and repair it.
May 14, 2012 | 2005 Honda Odyssey
I have a Sta Rite pool heater. My Sta Rite control panel in my home does not work. it doesn't diplay or turn on at all. the heater still works if I turn it on manually.
If you haven't done so already,if it is battery operated then try new battery. If it is dual power and uses a/c also then make sure you have power to the unit. Try to remove front or back cover and see if you can find a fuse. If none of the above works then I think you need to replace the control. Thank you.
Aug 29, 2011 | Heating & Cooling
My A/C panel will not turn on. Read A/C works just fine, but the entire front A/C panel gets no power. Suggestions?
Power to both front and rear A/C control panels goes through fuse No. 3 (7.5 amp) in the driver's under dash (left kick panel) fuse/relay box. But power to the main front panel goes through an additional fuse, No. 13 (7.5amp), in the passengers under dash (right kick panel) fuse/relay box. The other thing to check is the grounding point for the front panel (labeled G401 in wiring diagram.) It is located under the left side of the dash panel on a metal support with a through-bolt fastener. Many items ground at this point so look for multiple ring lugs under the bolt.
Mar 07, 2011 | 2004 Honda Odyssey
I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
Aug 17, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Front a/c heater blower wont work
Here is the order of checking;
) Check maxifuse 105
) Check fuse 24 on interior panel
) Check blower resistor
) Check power and ground at motor.
) May be bad motor
May 18, 2009 | 2001 Ford Expedition
Heat works on the front and the back only works when I use the front controls to turn on heater.The back Heater control panel wont turn the heat on for thr back.but still blos hot air when turned on only...
Here's what the system looks like. left rear panel
please rate as fixya if this solves your issue
Check fuse #7, 5 amp dash fuse panel
check fuse # 13, 30 amp in power dist. box under hood I think
check auxilaiary a/c relay in RPO Relay box (rear floor panel)
check fuse #23, 10 amp in dash fuse panel
Feb 26, 2009 | 1997 Ford Expedition
Coffee Makers & Espresso Machines Logo
43 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
