Changing channel and volume by itself
I have turned it off unplugged it and replaced batteries it will not let me control anything with remote. what should I do. got it under six months ago and no receipt.
    Top Expert:
  • Televison & ... Master
  • 45,340 Answers
Read the instruction s again or just buy another same thing then use that receipt to exchange the other one which is not totally legal but.
Posted on Apr 18, 2015
The tv is stuck on searching through channels and HDMI.. it will not allow me to control anything else like volume or menu
If this is occurring while using a remote control, it might very well be due weak batteries and/or a defective remote control itself, and needs to be replaced.
Oct 19, 2015 | Televison & Video
Toshiba 32AF44. While watching a baseball game yesterday, the volume bar appeared by itself and scrolled down to zero. The bar will not disappear. It's like someone is holding the down button. Tried...
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. http://electronicshelponline.blogspot.com/ Before replacing it, try a reset to this set, and then check.
There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here.
Mar 04, 2017 | Toshiba 32AF44 32" TV
My remote control just stopped working to control the volume or channels. Changed batteries...what else can I do?
make sure nothing is damaged on the remote. after doing so unplug you're tv. when the tv is turned back use the remote close to the tv and use the remote. make sure the sensor on the tv is not blocked by anything (movies,books anything). if it still isn't working consider buying a replacement
Feb 28, 2011 | Samsung TV Remote Control
My remote stopped working can it be reset
Hello;
I found the following reference to resetting anything related to the ZN110 remote:
"This remote control works well for all the basic functions on the television: changing channels, adjusting volume, and turning the set on and off. There is not a way to program the TV with the remote control, so if you need to reset the channels after a power outage, for example, you have to do it manually on the TV set itself."
Or it could just be batteries?
Feb 26, 2011 | Zenith ZN110 Remote Control
Controller will only turn equipment on and off. Can't do anything else, ie: adjust volume, change channel, etc. Universal MX-900 Remote
Hello, Reset the remote control and use with the equipment . If it does adjust volume, change channel. then use have to get another one of different model
May 20, 2010 | Universal MX-900 Remote Control
TV turns itself on, keeps changing it's own channel
the problem is with the control panel of your tv...make sure your remote doesnt have any part in this...just remove and the batteries and check if the channels still are changing.....see if the onboard switch for channel changing is stuck ?..if stuck u can use homemade tools to pull it back......if your tv is within your gurantee period...just giv a call to customer care....if not u can take it to a local repair shop...there is nothin that u can urself do to make it right ...sorry....for further info contact at
Jul 06, 2008 | Televison & Video
Wharfedale LCD3210AF Television- Digital problems!
Well there is still a problem with the TV. I found that by unplugging the power cable that the digital channels worked. But, when I turned the TV on today the problem had returned, I had to take out the power cable again!
Feb 11, 2008 | Televison & Video
Buttons/ Remote won't operate TV
Defective tactil switch?? Remove tact switch control board.
unplug connector,use meter--check each switch.
If no problem found,leave unplugged overnight or longer.
Sony is famous for getting brain freeze!.........T.
Oct 24, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
