Question about Ematic 7" Portable DVD Player with Swivel Screen
Player will not turn on or charge; loaded disc repeatedly then shut itself down. Nothing appeared on the screen.
DVD player automatically stops and turns itself off, how do I prevent this?
Warning: Laser inside! If you want to open it up and troubleshoot, make sure you don't point toward your eyes.
Check the nylon laser carriage to see if it slides laser from center to outside line. If it sticks, it's probably shutting down from not properly reading a disk.
Aug 03, 2014 | Pioneer DV-343 DVD Player
Unit model D-C350/XSA only opens region 4 need to also to open region 2 DVD's
When I was with Samsung NZ, the following was how we multizoned our DVD (Region 4) players:
1. Turn on your player, but ensure no disc in machine - screen should show "No Disc"
2. Turn on your TV and select your DVD input (as if you were to watch your DVD).
Using your factory supplied remote, press the following buttons:
3. Press the Repeat (or Repeat A-B) button
4. Press the following button sequence: 7, 6, 8, 8, 4, 9 (you should see the number '9' appear on screen - this means 'Region Free').
5. Press the Open/Close button (to open the tray)
6. Press the Open/Close button again (to close the tray)
7. Press Power OFF (to shut down your DVD player)
8. Press Power ON (to turn on your DVD player)
9. Insert Region 2 disc and wait (up to 1min) for firmware to respond and read your disc
If this fails, try procedure again, except for Step 4: change the last number (instead of 9) to '2'.
Let me know how you get on.
Cheers,
Scott
"If this has helped you, please be kind enough to leave a testimonial rating"
Jul 09, 2011 | Samsung DVD-C350 DVD Player
When the Wii is turned on the main menu screen comes up and then says to shutdown the Wii console and shuts itself down ?It won't load a game disc or nothing ? We have tried blowing the system out with a...
If the system turns on but then turns itself off, beeps at you and flashes its lights at you then you have over heated the system. The GPU chip has problem pulled itself away from the board. This will require you to disassemble.......
OR Click here to download repair guide
Jan 05, 2011 | Nintendo Wii Console
Unlock region free?
1. Remove any DVD discs from the tray/unit.
2. Switch off the DVD player and unplug the power cord.
3. Wait 30 seconds, then reconnect the power cord.
4. Turn on the DVD player with the supplied Samsung remote and wait for player to finish loading and display 'no disc' or the Samsung logo before you do anything else.
5. Press Enter on remote. (There will be no on-screen response to you doing this.)
6. Press the following numbers in sequence using the supplied Samsung remote unit's keypad -
8 4 2 6 9
(Again, there will be no on-screen response to this action.)
7. Press Enter on the remote. The DVD Player will automatically shut off.
8. Now, turn the DVD player on.
9. When it is on and showing the "no disc" or Samsung logo, turn it off again.
10. Repeat this action by turning the DVD player on, then off again.
11. The DVD Player should now be Region-free.
Sep 29, 2010 | Panasonic DVD-S54 DVD Player
Wanted steps to unlock region code for Samsung DVD-C370
  • Make sure there is no disc in the player.
  • Turn on the player (you can use remote control or front panel, it doesn't matter)
  • Wait for "No Disc" message to appear on the TV screen.
  • Press the Repeat button on remote (plain, not A-B).
  • Press the correct sequence of buttons of remote according to the original region code of your player (it's on the sticker on the back panel of the player).
  • FF = fast forward, FR = fast rewind.
  • Region 2 players: FF, FR, FF, UP, DOWN
  • Region 3 players: FF, PLAY, FR, UP, LEFT
  • Region 4 players: FR, PLAY, DOWN, DOWN, RIGHT
  • Region 5 players: FF, UP, DOWN, STOP, RIGHT
  • Region 6 players: LEFT, RIGHT, RIGHT, PLAY, LEFT
  • If you pressed the correct sequence, a small white number 0 will appear somewhere on the top right of the screen.
  • The white number 0 of the same font and size as the "No Disc" message, so don't confuse with the red "not allowed" sign that would appear when you press a function that's not available.
  • Turn the player off and on again, then you can pop in a DVD of any region and watch immediately.
Jun 03, 2010 | Samsung Televison & Video
How do you unlock the Samsung DVD - P191 from all regions?
The following solution was posted on Whirpool.
Turn on the unit with no disc in the unit. The No Disc message should be visible
Press the following keys in this sequence
Repeat (not the A-B Repeat, just the plain Repeat)
Fast rewind button (just below the Disc Menu button)
Play button
Down button
Down button
Right Button
The number 9 should now appear towards the left of the screen.
Open then close the disc draw
Turn off the unit and then on again. You should now be able to play DVDs from any region
Apr 18, 2009 | Televison & Video
Message ''disc is dirty'' appears
now u need to clean the player:
Be careful how you use this, but u can utilize canned air to blow out the debris from your player.
get a laser lens cleaner kit from walmart or something, it will cleans your laser lens inside the dvd player for you, if the canned air and laser lens cleaner doesn't work, your last resort is to completely unplug the player to see if it resets itself, if none of those works i would turn the player in under warranty or take it back to the store.
Nov 13, 2008 | Sony DVP-NS315 DVD Player
European DVDS
Turn on (on the remote)
-Wait until appears "no disc"
-Open and shut the tray
-Wait for "no disc" again
-Press REPEAT on remote
-Press 76884 on remote (for region 4. I guess that to other regions the codes below**** will apply)
-When appears the number 4 on TV screen, press number 9 on remote
-Press ENTER
Now you have a region free player!
****Codes for other region players:
R1 - 29334
R2 - 38767
R3 - 56732
R4 - 76884
R5 - 53814
R6 - 24462
Aug 24, 2008 | Samsung DVD-1080P7 DVD Player
I HAVE A MEMOREX (MMP8640A) AND IT WON'T COME ON.
myn wont even turn on ..it was just like charged half full!
i had it plugged inot the computer ..and it wa turned on so i turned it off ..like usually when i plug it in it makes a noise then it loads and a list of options comes up now nothing ..before when it was connected ..yesterday.. the screen said do not disconnect now nothing is on the screen ..its plugged in right now .. i tried going 2 windows media player to sync some music but it says nothing is connected!!!
good luck
Feb 21, 2008 | Audio Players & Recorders
Loading screen
as i thing u have 100% the disc full..!!! :P i have the same model and i saw that when i had it about 7-8GB it was normal but when i puted a lot of other softs and some more music it started slowing down.. so (thats my advise) its better to backup your mp3 and do a reset from the bottom next to the charging inpout..then please install only music and not every program u find on the internet..u have to trust it..!
holpe i helped
stratos
Nov 16, 2007 | Sony Network Walkman NW-A3000 MP3 Player
Ematic 7" Portable DVD Player with Swivel Screen Logo
Top Ematic Televison & Video Experts
Electro Med Services...
Are you an Ematic Televison and Video Expert? Answer questions, earn points and help others
