Question about Sewing Machines
I need to find the bobbins that i can use for this machine, current bobbin numbers don't coordinate. Please advise
  • Sewing Machines Expert
  • 458 Answers
Try consulting the web site of whatever machine you have, they are usually very helpful in their Support or FAQ sections.
Posted on Apr 18, 2015
How do I set bobbin tension?
Generally bobbin tension is the last thing to try to adjust on your machine. Most sewists adjust the bobbin tension ONLY if they are using very lightweight or very heavyweight thread in the bobbin. Most sewists will advise to make all possible adjustments to the top tension before tackling the bobbin tension to resolve issues.
Try searching YouTube videos or this may be helpful:
Bobbin Tension How and Why Tension is Adjusted
Understanding Bobbin Tension
Setting the Bobbin Tension on your sewing machine
Liz Kettle adjusting your bobbin case tension 1 wmv
How to fix Tension Don Panic
Sep 27, 2015 | Janome Memory Craft 3000
Instruction manual for freezer , philips
have you made sure that your bobbin thread is going into the case going back on itself rather than threading directly into the bobbin case slit. This creates tension. Also check the thread take up as you hand wind the fly wheel. If the tp and bottom threads are not catching each other from the bobbin hook then it could be that the timing has gone out of sync. If you can get hold of a Readers Digest sewing book there are good operational drawings of how the bobbin and needle coordinate.
Mar 28, 2014 | Sewing Machines
Error code c4
try these suggestions
try changing the needle
make sure the bobbin is turned the right way in the bobbin case
if these suggestions don't help then the machine needs to be checked
Oct 06, 2012 | Singer 7258 Sewing Machine
I have a faithful 730 Bernina and currently the bobbin thread keeps breaking. Please advise what may be causing this. Thanking you.
Bobbin thread breaks
1. There is a right way & wrong way to insert the bobbin in the case --when you insert the bobbin in if it doesn't stitch correctly turn the bobbin over see if that helps or bobbin case is not inserted correctly
2. Lint has collected in the bobbin holder
3. The bobbin is damaged & doesn't turn smoothly
4. Lower thread tension is two tight
here's a free manual
http://www.bernina.com/getdoc/48e8d09f-98f7-40ab-8663-a23663df4fae/Bernette_715_730_740E_manual
Sep 17, 2012 | Bernina Sewing Machines
I need a manual and a bobbin case for a new home model 764
http://www.sew4less.com/index.php
I don't know if the link will work for the bobbin case, if it doesn't
go to sew4less.com
Bobbin Case # 52237 NB, Click for model info.
p_4754_1148578825.jpg Product #: 4754
Price: $ 19.95
Bobbin Case # 52237 NB, No backlash type.
A bobbin case, also known as a bobbin holder or bobbin shuttle, holds the bobbin that is filled with thread.
Each machine has a specific bobbin case. # 52237NB
Brother 755 Brother B714 Brother B735 Brother DDL-227 Brother DDL-555 Brother DL-5550 Consew 103 Consew 104 Consew 210 Consew 230 Consew 231 Consew 7360R Consew 99 Consew CN 223OR Janome / New Home 764 Juki DDL-227-L Juki DDL-5530 Juki TL98E Kenquilt 622 Singer 1300 Class Singer 1400W Singer 188K Singer 191U Singer 195K Singer 196K Singer 241 Singer 245 Singer 251 Singer 281 Singer 291U and more!
here are is a site that have manual
http://www.sewingpartsonline.com/
Jun 09, 2012 | White Sewing Sewing Machines
The bobbin on my kenmore sewing machine model 158.15720 won't spin to wind the bobbin. I oiled it but it didn't help. The belt is a little loose. Could replacing it help?
most machines will have a rubber o ring as part of the bobbin winding mechanism, when you engage the bobbin winder, this o-ring will move over against the main engine drive wheel and this then makes the bobbin spindle turn. So yes, you may need to replace the rubber o-ring, they can perish and wear. Called Bobbin Winder Tyre, you could try www.sewingpartsonline.com, they have loads of Kenmore models listed but can't see yours. However, if you email them, they should be able to advise what part number it is. If you start by opening up the machine case and take a look at the bobbin winder area first, you may find this rubber has split or perished.
Oct 11, 2011 | Elna 2007 Mechanical Sewing Machine
I bought my daughter a White sew E-Z so she can have fun on her first sewing machine. However there is no manual and no instructions on how to thread the bobin. the bobin just sits on its flat side to go...
Check the model number of the machine. White sewing machine manuals are available from Singer at http://www.singerco.com/accessories/instruction-manuals . Enter the model number and click Search.
The White Sew E-Z model W338 manual is available here: http://www.singerco.com/uploads/download/705_white-338-x.pdf .
Unlike some machines this one doesn't really need the bobbin threaded. Place the bobbin in the bobbin holder and leave about 5" of thread extended out from the bobbin holder. With the bobbin compartment still open, lower the presser foot and turn the handwheel to move the threaded needle through the stitch cycle. (I find holding the threads helps; normally, you'll feel them pulling under your fingers.) When the needle has returned to the top of the path, lift the presser foot. Then pull both threads around to the front (the bobbin thread should wrap around the top thread). Then move the threads to the back of the presser foot.
If the needle isn't catching the bobbin thread, first try a new needle (bent or dull needles don't always function properly). Next check the bobbin holder for nicks or other damage. There is a small hook on the bobbin holder that should be where the top and bottom threads intertwine. Under rare circumstances, you will find that the bobbin tension of the bobbin holder is misadjusted. This can interfere with the bobbin thread twisting properly. There is a little set screw that allows you can tighten or loosen the bobbin tension as needed. Adjusting the screw is to be avoided when possible and done in small increments (1/8 turn) if needed. It's easy to strip the threads for the set screw and end up needing to replace the bobbin holder.
I hope this helps.
Jul 13, 2011 | White Sewing Sewing Machines
What bobbin size for elna supermatic 722010 Can I purchase metal bobbins for this machine at a Joannes? or ? Is there a staner bobbin number or size to ask for?? thanks@ The Elna I have came with ONE...
Elna Supermatic 722010 is a very vintage elna and would take the metal 7 hole dished bobbin like this.
Don't try to use any other bobbin in it, and always load and wind with the holes on top.
You can still buy these; one supplier is sewingpartsonline, here is like to the item
http://www.sewingpartsonline.com/bobbins-elna-426000-10pk.aspx
Aug 17, 2009 | Elna Heirloom Edition 6005
Bobbin tension problem with kenmore model 385.16231300
If You have a drop in bobbin you will have to remove the hook and adjust the tension, however try adjusting the top tension before you remove the hook.
Jul 17, 2009 | Kenmore Drop-In Bobbin 505S-21BH...
Kenmore Model 385.16231300
I discovered the same problem. What I figured out (after having the machine "repaired" several times) is that it seems as if the bobbin type may be the suspect. I started looking closely and it seems as if I have 2 different types of bobbins. So, I tried both types. Since I don't know the bobbin number(s), you will have to put up with my description .... the bobbin that is flat, top & bottom, seems to bunch up. The bobbin "bounces" when I sew. The bobbins that are rounded on the top and bottom don't seem to "bounce" and it doesn't bunch up the lower thread. Now, I have read my manual front to back and it does not say what bobbin type or number to use. So, if anyone knows, it would be a great help. I am assuming the correct bobbin is the "class 66" bobbin. Does anyone know for sure?
Dec 11, 2007 | Kenmore 756A-30BH Mechanical Sewing...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
