Question about Samsung Televison & Video
Hi guys i have a Samsung 50 inch TV same problem as every one else has sound and no pitcher now I've checked the capacitors and have replaced one but still no pitcher any suggestions please
    Top Expert:
  • Samsung Master
  • 74,377 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should trouble shoot. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Posted on Apr 20, 2015
  • Samsung Master
  • 681 Answers
Hi Buck,
"Sound and no picture means" the TV is working and the picture is also there but you are not able to see because there is no back light. This may happen due to a bad inverter board or the bad power supply which is not providing necessary voltage to the inverter section.
Posted on Apr 19, 2015
  • buck beitzel
    buck beitzel Apr 19, 2015
    Thanks sp now ive checked bot boards n doesn't apper to be any problem checked both n both have there values at 63 n 207 so where to from now im lost
  • Sp Gupta Apr 30, 2015
    Will you please give the model number.
james klgr
  • 362 Answers
SOURCE: Panasonic 50 inch Plasma
it could have over heated you can try to reset it first unplug it for about five minutes and try to turn it on if that dont work the remote might have a set button try holding that down until the red light flashes twice, then turn it on if not then hold the power button down on the set for a good five seconds to see if that resets it. if none of that works you will have to go to panasonic .com for the reset instructions.with the red light blinking the power supply is most likely good you just need to reset i.
Posted on Dec 24, 2007
SOURCE: we have samsung 50 inch plasma tv, we have only half a screen
I have a Phillips 50 inch Plasma. About two months out of warranty the top half of the screen would go black. Sometimes when we tapped on the back behind the upper right hand corner the picture would return. I did some research online and found that there is a Main Y sustain board (much like a mother board in a computer) and connected to that board is a upper Y Buffer board and a Lower Y buffer board. According to my research these boards seem to be the source of the problem. I am assuming that the upper buffer controls the top half of my screen and the lower controls the bottom. I removed the back of my TV (about 50 small screws) and searched for these parts by part number. Surprisingly all of the parts in my Phillips are made by Samsung. I found the parts on ebay at shopjimmy.com. I decided to try replacing the upper Y buffer first. I ordered it from shopjimmy for about 100.00. When I received the part I started to remove my upper Y buffer and realized that the new part was slightly different. The part number was the same but the REV. number was slightly different. The new part was missing a small white connector that connects the upper buffer to the lower buffer. I sent it back for an exchange for the right part with no problem. Ok so here is the interesting piece of this little adventure. When I started to remove my upper Y buffer I removed the screws and started to pull on it to loosen it. When I noticed that I had the wrong part I pushed it back into place and put the screws back . My TV has worked perfectly since I did that, with my original part. It has only been about two months, but if you are in the same situation it might be worth a try.
Posted on Oct 24, 2008
GadgetRaja
  • 150 Answers
SOURCE: 50 inch samsung tv clicks on and off when turn on
the Fuse needs to be Replaces, contact nearest samsung service center. would cost just $1 trust me
email me if you need any assistance ... rajanetworking@gmail.com
Posted on Sep 02, 2009
SOURCE: ysus board blowing fuses. any clue 42 inch esa made by LG
I have the same problem. Did you find a solution?
Posted on Feb 10, 2010
  • 50 Answers
SOURCE: Not the capacitors, replaced in August.
Hello solidsnake55, my names Dave.
I Have worked on this model of TV many times! This model has a power supply that is a two in one! Meaning it is the mean power supply / inverter board! If you look at the top side of the power supply you will see that there are two wires that go to the back light of the TV one is light blue and the other is pink! I think! Anyway next to where they plug in to the power supply is the main inverter! it is square 2 1/2 inch's by 2 1/2 inch's. You will want to check all the solder joint to the inverter on the back side of the board! Theres a good chance that you have a bad solder joint and all you'll need to do is re-solder the bad joint to complete the repair! This is a common problem for this particular power supply!
If you need any other help with this repair or any other repair please feel free to contact me at www.pleasefixitdave.com You'll find all my contact info at this website!
We are a plasma / LCD repair shop in Portland, OR. We also sell factory replacement parts for Plasma & LCD type TVs! All the parts we sell are warranted not to be DOA (Dead On Arrival) with a full cash refund or replacement part! I also provide TV repair tech assistance!
Thank you!
Dave,
Posted on Mar 31, 2010
Plasma tv repair
Samsung 50 inch plasma wont turn on - YouTube
? 0:59
https://www.youtube.com/watch?v=Uo-SazF_G9Y
Jan 9, 2014 - Uploaded by 8Jallin
Samsung 50 inch plasma wont turn on ... samsung plasma tvnot working, wouldn't turn on, FIXED, repair, diy - Duration: 14:56. by Matthew ...
Plasma TV Repair Tutorial - Common Symptoms ... - YouTube
? 7:13
https://www.youtube.com/watch?v=gnkyAGyI7GA
Oct 9, 2013 - Uploaded by ShopJimmy.com
Plasma TV Repair Tutorial - Common Symptoms & Solutions - How to Fix .... Samsung 50" Lcd tv model#Lf501EM6f Im not sure if its plasma or ...
WHAT Plasma TV BOARD CAUSES NO PICTURE REVIEW ...
? 4:10
https://www.youtube.com/watch?v=DC_75FfrR9w
Nov 8, 2012 - Uploaded by Tampatec
WHAT COMMON PART / TV Board IS BAD ON SAMSUNG Plasma ... a gamble. it the cost of repair is over 300 just buy a new 50 inch tv for 600.
Samsung 50" Tv Power Supply Boar...$34.00eBaySAMSUNG UN60EH6002FXZA...$23.00TV Parts Guy42% price dropSamsung 50" Pn50c550 Pn50c45...$18.99eBay
Dec 21, 2015 | Samsung PN60F5500 60-Inch 1080p 600Hz 3D...
Samsung dlp HL-R5067W sound no picture
Check for open or leaky capacitors look for bulge on the top of caps
Mar 28, 2014 | Samsung Hl-r5067w 50-inch Hd-ready Dlp Tv
50" samsung PN50B400P3D switching on and off power cycling
look for bulged capacitors and replace them. Amazpn has a guy who sells kits of cpacitors for most TVs and Displays, but a local electronics parts house is cheaper and faster. Make sure you get 105 degree Celsius capacitors.
Mar 27, 2014 | Samsung 50 in. Plasma TV
Tcl tv 50" keeps shutting off
Have someone check power Capacitors. China uses cheap Capacitors in a lot of their TV's. Doesn't matter brand. Replacement is simple.
Jan 15, 2014 | Samsung UN55ES6500 55 Inch 3D 1080p Smart...
I have a Samsung 50 in plasma tv that has sound but now picture. One day I was watching tv when the screen just turned into a horizontal thin red line across the center of the screen. Now I get no picture...
Your tv horizontal section is faulty change the horizontal transistor.or the diode that is at the leg of the collector of the HOT.do other checks around the transistor cause it can be more than one component is faulty in that section.also make checks in the power there is a diode that feeds from the pout put of tv regulator that might be leaking or is open.
Sep 24, 2011 | Samsung 50 in. Plasma TV
I have a samsung 50 inch plasma TV and it has no picture, the screen is blank and no light on the screen, we have no idea what is wrong if you could help would be great, Thanks.
Hi Its means that your television have no power.Maybe the power supply is dead.Its better to repair the power supply.If you have knowledge in TV,will you remove the back cover and check the power supply.Check the fuse if blown and check if the capacitors is leaked.
Jul 16, 2011 | Samsung 50 in. Plasma TV
I own a 50 inch samsung series 4 tv and it will not switch on it is making a clicking noise!!?
hello,
Clicking and not switched on because capacitors on pcb power have damage.
open and change the capacitors can solved your problem.
if any problem after replacing capaditors, let me know . thanks
Mar 27, 2011 | Samsung Televison & Video
LG 50 inch plasma has trouble powering up. have
Power supply board have dead capcitors.Know how to solders?These capacitors usally bulge or pop open,replaced these capacitors will solved this problem.Or tries websites Shopjimmy.com,Ebay.com to buy a Whole reburbish power supply board for the replacement.
Mar 04, 2010 | LG 50PX5D 50 in. Plasma HDTV
Televison & Video Logo
49 people viewed this question
Henry  Thomas
Henry Thomas
