Error code 1762
No start up even in safe mode or sefe mode with network or command prompt
  • Computers & ... Master
  • 2,825 Answers
Do you have the original windows disks? There's a repair option there...
Posted on Apr 18, 2015
  • tom cassidy
    tom cassidy Apr 18, 2015
    sorrie no disk bought sec hand its an ibm desk top thanks for ure help
BIOHD-s no drives detected
Error Code Biohd-2 No Drives Detected errors are caused by missing system files or broken system registry structures. This is a critical sign of an unstable system that is typically caused by improper maintenance of the computer.
You could run the chkdsk disk utility
Click start run type cmd then type chkdsk/r/f which will scan for and attempt to repair any bad sectors and automatically fix any corrupt files on your Hard Drive.
or an easier way to run the chkdsk utility
Windows 7 chkdsk
http://www.w7forums.com/use-chkdsk-check-disk-t448.html
Click start control panel administrative tools computer management ,disk management right click on your drive select properties click tools click check now click start two boxes
automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now, start should schedule this task when restart
have no input while the chkdsk utility is in progress any input may further damage your computers Operating System and Hard Drive
http://download.cnet.com/jetclean/3000-18512_4-75627788.html
JetClean tidies your registry, gets rid of junk files, deletes broken shortcuts, and attempts to give your computer that like-new feel again.
Optimizers and Diagnostics.
http://download.cnet.com/360Amigo-System-Speedup-Pro/3000-18512_4-75332741.html 5E3422139C19CBED35C14826A44D4605
Improve your PC performance and fix errors.
If you are unable to get a connection with your hatd drive
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen.
Select the option for Safe mode command prompt only
Windows Advanced Options Menu
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive
You should have no input while chkdsk utility is in progress any input might further damage your computer also
Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file.
Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
You might have to use safe mode with Networking to download
Select safe mode with Networking to download
Oct 07, 2013 | HP Computers & Internet
Tip
How to make windows installer work in safe mode
Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer work under safe mode, you need to create a registry entry for every type of safe mode you are logged in to.
1.Safe Mode.
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
and then
net start msiserver
This will start the Windows Installer Service.
2.Safe Mode with Network
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
and followed by
net start msiserver
on Mar 15, 2010 | Computers & Internet
Tip
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
  1. Safe Mode.
and then net start msiserver This will start the Windows Installer Service.
  1. Safe Mode with Network
and followed by net start msiserver This will start the Windows Installer Service.
on Mar 15, 2010 | Microsoft Windows XP Professional
Hdd password error code [00176]
Safe Mode
Enable Boot Logging
Enable VGA mode
Debugging Mode
Reboot
select safe mode with command prompt
Click start run type cmd press Enter
black screen should open DOS mode
this will vary depending on your operating system
type in net user username
For eg. If you want to change administrator password , type net user Administrator
It will prompt you to enter the new password.
Enter the new password and the password is changed
http://wiki.ljackson.us/Control_Userpasswords2
if this fails you will need to
Select safe mode with networking to download
you could download all of these or just one save them to a usb drive for later use if one fails to remove the password
Windows Password Recovery Basic
http://majorgeeks.com/CmosPwd_d239.html
A CMOS BIOS password recovery tool
Editors note: This tool should only be used by experienced computer users.
Please see the enclosed read me if you would like to run it from Windows.
Failure to follow instructions (from Windows) will cause your anti-virus to flag this as a virus.
Jul 15, 2013 | Acer Aspire Computers & Internet
Nls error
Step 1:
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions.
Feb 21, 2013 | Acer Aspire One PC Notebook
My Hp compaq PC showing problem about HDD - Disk Read Error . But This HDD was run very good to another PC ?
Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. b> 1: Download a disk read error repair tool,install this error repair tool.
2: Open disk read error repair tool and scan you computer for free
3: Then click the Repair All Button again and your done! It is very easy to repair disk read error.
Here are the url of disk read error repair tool:http://www.RepairErrorInstantly.com/ttfi... or rather than doing this try the alternative which is windows own repair Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice Select safe mode with networking to download http://www.RepairErrorInstantly.com/ttfi... Then restart again into safe mode with command prompt. Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer Hope this helps. b>
Jan 05, 2013 | HP Compaq dc7700 PC Desktop
Windows Error Reporting Error
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. Select safe mode with command prompt then type in chkdsk/f/r which will scan for and and attempt repair of bad files and bad sectors on hard drive You should have no input while chkdsk utility is in progress any input might further damage your computer also Use the System File Checker tool (SFC.exe) to determine which file is causing the issue and then replace the file. Type the following command and then press ENTER: sfc /scannow The sfc /scannow command scans all protected system files and replaces incorrect versions with correct Microsoft versions. Hope this helps.
Dec 30, 2012 | Computers & Internet
How do I get into safe mode on HP mini 1000? XP OS
To get into safe mode on any computer running Windows you press F8 before or right after the Windows splash screen comes up. You will have three options for safe mode:
Safe Mode: Only the absolutely necessary drivers load.
Safe Mode with Networking: Same as above plus the ability to use the internet/network access
Safe Mode with Command Prompt: Boots into safe mode with a Command Prompt for command line work.
Hope this helps.
Jesse
Jan 08, 2010 | HP Computers & Internet
Start up problem with xp
u have to repair your operating system with winxp recovery disk.
Mar 14, 2009 | Acer Aspire 3680 Laptop
Start up
try starting the computer normally, this usually happens if you computers power was cut while booting up, its just a small harmless glitch.  As for the returning back to the prompt try running it with command prompt. when you get to the command prompt, type (chkdsk) and let it run this might also fix any other problems that you are not seeing.
Jan 09, 2008 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
32 people viewed this question
David Payne
David Payne
