Question about Adcom GFA555 Amplifier
I want to bridge 2 adcom GFA 555 amps to my sony DA7ES any suggestions
    Scholar:
  • 54 Answers
Obviously you are going to use the Front pre-out's on the Sony to drive the Adcoms. its pretty straightforward, just do not use a speaker that is less than 8 ohms. and make sure that you always have the power switch off on the adcoms, let them sit off for 5 minutes, THEN hit the bridge switch on the back of the adcom's and follow their instructions for bridging. it's pretty easy and tough to go wrong. Good luck...Rob
Posted on May 30, 2015
  • 4234 Answers
SOURCE: how to bridge GPA 555 adcom amp from 8 om to 4 om
First of all, when bridging an anp, the impenence that it can handle usually goes UP not down. I don't believe that the GPA555 can be bridged without circuit modification.
Dan
Posted on Feb 11, 2009
  • 4234 Answers
SOURCE: can you bridge an adcom GFA-5802 power amp?
Running an amp in bridge mode requires a specific circuit design. It is not possible to combine 2 amps in this fashion.
Dan
Posted on Mar 02, 2009
  • 4234 Answers
SOURCE: how do i bridge an adcom gfa 5400
This amp is not designed to be bridged and can not be used in the mode you wish. Sorry, but internal circuit changes would be necesary for the amp to work as a single channel.
Dan
Posted on May 01, 2009
SOURCE: Adcom GFA 555
Lakes Electronics, Inc.
5245 N. University Dr.
Lauderhill, FL 33351
United States
954-749-6100
These guys are listed as one of the 2 Adcom service centers in FL and should be your best bet.
Also Jason Schatten @ Electronic labs might be able to help. Electronic Laboratory, Inc.
1301 West Copans Road, A4
Pompano Beach, Florida 33064
Phone: (954) 969-2855
Fax: (954) 969-2879
Email: Jason@ElectronicLaboratory.com
Hope this helps. Parag
Posted on May 10, 2009
Grubhead
  • 5151 Answers
SOURCE: adcom gfa 555 blows the 10 amp fuse and the 6 amp
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Posted on Oct 19, 2009
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Bridge adcom gfa-5500
not unless it has a Bridge switch OR you design an inverter circuit for one of the inputs. If it has XLR inputs you can try to invert pins 2 & 3 on one of them, that might work...
Aug 12, 2012 | Adcom GFA-5500 2-Channel Amplifier
How do you connect wiring to bridge an adcom gfa 5300?
The manual does not specify a bridging option.
http://www.audioreview.com/cat/amplification/amplifiers/adcom/gfa-5300/prd_116265_1583crx.aspx
"Weaknesses:
Not bridgable."
Generally an amp that IS bridgeable uses the positive speaker terminals and some switching method to tell the unit to run as bridged. This is NOT a recommendation to try it on the 5300.
Aug 02, 2011 | Adcom GFA-5300 2-Channel Amplifier
On the inside back wall of the 1986 Adcom GFA-555 Stereo Power Amplifier there are four fuses,two for each channel. Would you tell me please, what amp fuse they are and if they are the fast or slo-blow...
Sorry to contact you this way but i've spoken to an older colleague of mine and it appears that before 1992 in the Adcom GFA-555 they were using bipolar transistors and the amp was rated fo a minimal impedance of 4 ohms - not like in the newer ones that have MOSFETs and are rated for 1 ohm in bridge mode. So the fast fuses that you need are of 6 amps , not 20 like in the newer models.
Sorry for my mistake.
Jul 11, 2010 | Audio Players & Recorders
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
How do i bridge an adcom gfa 5400
Dan
May 01, 2009 | Adcom GFA-5400 2-Channel Amplifier
Can you bridge an adcom GFA-5802 power amp?
Dan
Mar 02, 2009 | Adcom GFA-5802 2-Channel Amplifier
How to bridge GPA 555 adcom amp from 8 om to 4 om
Dan
Feb 11, 2009 | Adcom GFA-5400 2-Channel Amplifier
Adcom GFA555 Amplifier Logo
260 people viewed this question
Top Adcom Audio Players & Recorders Experts
 Grubhead
Grubhead
Computer Links
Greg Cann
Greg Cann
Are you an Adcom Audio Player and Recorder Expert? Answer questions, earn points and help others
