Question about Light Garden
After 30 min of light mowing engine starts to cut out and dies.
I changed spark plugs and cranked it back up, no problem until I engage blade. Then it dies again. Disengage blade and it will start back up.
    Sergeant:
  • Light Expert
  • 187 Answers
Your engine is dying when warm and when under a load.
If your engines runs 20-30 min before it dies, this post is for that specific situation only. If it runs only a few minutes then dies, that's a horse of a different color and you need a different solution. The possibilities, in order of easiest to fix, are:
  1. Fuel problems
  2. Spark problems. You have changed the plugs but you could still have a problem with a weak spark.
  3. Compression problems.
Tracking Down Fuel Problems
The normal list of procedures for tracking down fuel problems related to starting the engine, are different from fuel problems which develop when the engine has been running awhile (more than 10 minutes). This problem can be related to a gas cap vent being plugged. If your mower quits, take the gas cap off and crank it. If it starts right up, there's your answer. The gas tank is drawing a vacuum. Clean the vent or replace the cap. Some folks have drilled a 3/16 in hole in the cap and stuffed it with foam. But what if that doesn't solve the problem?
Consider my own experience when my engine to quit in the middle of a mowing job: I was mowing along on my LA145 (200 hours on it) when it slowed down and died. Before it died, it acted like it was losing power. I thought it was only firing on one cylinder. I waited about 20 minutes and it restarted after a lot of cranking and some priming. I made a couple more mowing passes; the same thing happened again.
I have mowed commercially for many years and knew this mower was in top running condition. There were no engine misses, no backfires. It was not abnormally hard to start. The carburetor was clean, the coils were good, the plugs and fuel filter were recently changed. Lifting the hood, I noticed the fuel filter was nearly empty. It should be ½ full, or more. I pulled the hose off the tank side of the fuel pump and saw there was no fuel flow. Gas should have been pouring out of the hose onto the ground. There was nothing.
If you have a good supply of fuel, gas should gravity flow from the tank to the fuel pump. I wiped the hose off and blew air back into the fuel tank. It helps to take the gas tank lid off first. After I got a good flow of air going back into the tank (you can hear the bubbles) the fuel began to gravity flow back through the hose at a decent clip. This fixed the problem. There is likely silt build up in the tank and it settles at the output port blocking the flow of fuel.
Back at the shop, I used compressed air (turned down to 20 psi) to blow the line clear. The problem reoccurred several times last year and again this spring. After blowing air from the air filter back to the tank, you may have to reverse the process and pressurize the tank to get the fuel started. I place my hand over the open tank and hold the air hose between the joint of my thumb and forefinger to seal the tank, and then squeeze the trigger blowing air into the tank from the fill opening.
What if the fuel system checks out and doesn't solve the problem? Check the ignition/spark system.
Spark Problems.
Start with the spark plug. You CANNOT test a spark plug (without expensive equipment in your lab). Did you know that it takes more juice to create a spark under compression than it does at normal atmospheric pressure? So just because you have a visible spark from the plug outside the cylinder does not mean you have a usable spark under compression.
The ONLY answer to this end of the problem is to get a new plug; even if the current one is not very old. It's recommended they be changed every year, but a spark plug can fail even with very few hours of run time. The spark plug is subjected to compression, high heat, explosive forces, constant vibration, and of course electric shock in the 15,000 volt range. Make sure the gap is set correctly on the new one, typically 0.76 mm (0.030 in)., but check your specs.
Why you should just throw in the towel and start with a fresh spark plug? Read this wonderful essay on spark and spark plugs. Village Science Magneto Spark Plugs
  1. Install new spark plug(s).
  2. Run your engine under load till it quits.
  3. Insert a spark tester between the plug wire and the spark plug.
  4. In a darkened shop or garage crank the engine and check the spark.
  5. Compare the spark to the results described in the Spark essay above.
  6. If the spark is weak or non-existent, you possibly* have a coil, or plug wire from the coil, that is going bad when heated.
Note: Coils may not fail completely at first. They can be complicit in a situation where a mower starts and runs for a while before dying. As it heats up the coil parts expand and cause the engine to shut down. It will not re-start until the machine has cooled enough to allow the coil to cool. This can be 30 minute to several hours; perhaps it starts again the next day only to repeat the failure.
*Why did I say possibly? Slim chance, but it could be an element in the electrical system that is grounding the Coil/Magneto kill wire when it heats up or vibrates loose.
If you have not already done so, pull the shroud, or fan cover, from the top of your engine and look for a heavy metal wheel with fan blades. This is the Flywheel. It has permanent magnets embedded in the side. As the magnets fly passed the coil, current is generated. Seldom do the magnets go bad, but you should feel a strong attractive force from the magnets while you hold a screwdriver about an inch from the magnets. If they do not seem to be very strong you might have to replace the flywheel. This is a very rare happenstance.
Follow your spark plug wire back to the small plastic/metal thingy, mounted next to the flywheel, now you are at the Ignition Coil; or just Coil for short. TWIN cylinder engines have two Coils; one for each plug. A coil generates the 15,000 volts required by the spark plug. The Coil must be a precise distance from the flywheel. This is the Ignition Coil Gap. This gap usually .20 mm to .30 mm (.008-.012 in) from the flywheel. To set this gap properly, the magnets on the flywheel must be right in front of the coil when you set the gap. Check your specs. If the gap ain't right the spark ain't bright.
With the exception of the kill wire designed to stop the Coil from working, the Coil functions entirely independent of the rest of the wiring systems on the machine. If you disconnect the kill wire and the coil/plug wire are good you will get spark to your engine. The Coil works all by itself; it does not need the battery or the key switched on or even connected.
Inside the Coil are two windings of wire and no moving parts. With shorted (melted together inside) windings you can still get a spark, but it will be weak. With open (burnt/broken) windings, you may get spark intermittently or not at all. There are also electronic components like diodes which may be failing. Coils are subjected to heat and vibration and do fail on occasion. Another coil consideration is the spark plug wire. Back in the day, we would replace all our spark plug wires when we gave our car a tune up; because spark plug wires do fail. The only way to replace the spark plug wire on a mower is to replace the Ignition Coil.
Understanding the above info, let's proceed. Disconnect the kill wire from the Coil and crank the engine.
  1. If the engine still does not start, and the coil is gapped correctly, you may have to replace the coil.
  2. If the engine starts and runs, your problem is likely somewhere in the safety switches and wiring that grounds the coil kill wire.
  3. Note: with a disconnected kill wire the engine may start, but when you turn the key off, or otherwise try to shut the machine off, the engine will keep on running. Just slip the kill wire terminal back on with the key switch off, otherwise ground the coil kill terminal, or wait till it runs out of fuel.
What if it's not Fuel or Spark? Compression is next up. If your engine has a lot of hours on it your problem may be simple wear. This problem is the most complex. There are only two simple possibilities
  1. Start with a clean air filter
  2. It's time to adjust the valves.
If a new air filter and a valve adjustment do not solve the problem, and the problem is not Fuel or Spark, then you will need more complex tests and solutions. A shop will do things like a compression test, a cylinder leak down test, a crankcase vacuum test. All things beyond the scope of this small space.
A simpler test that you can do is the cylinder balance test. This test is easier and takes less specialized equipment.
If an engine is hard starting, runs rough, misses or lacks power, run a cylinder balance test to determine if both cylinders are operating to their full potential. You will need an engine tachometer, a spark tester, and an insulated screwdriver.
  1. Using the spark tester, with the plugs in, start engine and verify spark is equally good on both cylinders.
  2. Remove spark tester.
  3. Connect engine tachometer.
  4. Run engine at top no load speed. Note rpm.
  5. Ground one cylinder spark plug with screwdriver. Note rpm.
  6. Ground other cylinder with screwdriver. Note rpm.
The difference in RPM between the cylinders should be less than 75 rpm. If the difference between the two cylinders is greater than 75 rpm, the cylinder with the least rpm loss is the weakest and is a potential problem.
Cross your fingers, maybe it will be one of the simple things. Village Science Magneto Spark Plugs
Posted on Apr 19, 2015
I have a craftsman mower model no 917.28922 that blows blue smoke after engaging blade and is using oil..maintained and kept very clean after every use...what should I check, has new spark plug.
If your maintenance did not include changing oil each season that made the engine wear out sooner. Clean on the outside does not help the inside. You can get a price on rebuilding the engine but I have a feeling that you can replace the mower for not much more. Use it till it dies if you plan to replace it.
Feb 14, 2015 | Craftsman Garden
Have a cub cadet 50 inch cut zero turn, after cutting grass for 30 min or so it acts like wants to die but if I shut the PTO off it catches up but will start to die if I reengage the blades. starts a
When it starts cutting out and you turn off the PTO, how long do you have to wait until it can be turned on again? It sounds as if your PTO is overheating and loading down the engine. Run the mower for about 10 minutes, shut it off, and carefully feel the PTO housing. Resume cutting and repeat after it starts cutting out.
Replacing it is not as simple as changing the spark plug, but does not require an advanced degree.
Jun 24, 2014 | Cub Cadet Street Sign- tractor lawn riding...
My parents have a self propelled...front drive...walk behind 22in cut mower purchased at Home Depot 3 seasons ago.....I do the maintance on the mower....sharpen blade....change the oic/plug &...
Does the mower die right away (cuts out) or does it sputter to a halt. Sputtering out would indicate a fuel problem. If it just cuts out when hot, then more likely an ignition problem. Your coil may need replacing. Take a close look at the coil wire (spark plug wire) and its routing. Make sure it's not touching part of the engine where it's heating up and has caused a "leak" to ground it out when it gets hot. If all is well then check your spark when the engine is hot and cuts out. Make sure you have a very good blue spark and not a weak one (check it cold first and then compare!). Again, indicating a possible ignition coil problem. Hope this helps and best of luck to you.
James
Sep 14, 2011 | Toro Power Lawn Mower
Mower mows graet for 30 mins then starts to load
Yes you need to replace the needle and set in the carb.
Aug 23, 2009 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Once engaged and start mowing, you can mow for about 20 feet or more and then it just slows down and the engine wants to die, but stop pulling immediately and the engine catches up and goes back to full...
This actually happened to a friend of mine! I saw it! Mow about 20 feet, and had to stop, then 20 feet...well, you get the picture. It was his air filter! Stopped up pretty good. We blew it out and it worked fine.
I really hope this helps. --W/D--
Aug 15, 2009 | Swisher 60" 13 Hp Trailmower #T1360h
Last weekend I sharpened the blades, changed the oil filter, the oil, and the spark plug, put in fresh gas and started the mower up and mowed the lawn no problem. This weekend, it started right up but when...
There is an operator presence switch under the seat...if the mower shuts off when you release the brake, this switch is faulty and must be replaced
May 02, 2009 | Garden
Engine cranks, runs for approximately 30 seconds
you nee too take the carb apart and clean it!!!!!!!!!!!!!!
Apr 01, 2009 | Craftsman Garden
1990 Buick LeSabre cutting off, getting no spark, 30 mins starts
Replace crank sensor. Next time it cuts off pour or spray water on it, to cool it down and if car starts that is what it is. I did this to get my car home to fix it. Next thing I would look at is the coil module if crank sensor does not fix it.
Dec 21, 2008 | 1990 Buick LeSabre
Garden Logo
127 people viewed this question
Top Light Garden Experts
Richard Schanie ...
Arnie Burke
Arnie Burke
Ted Maxwell
Are you a Light Garden Expert? Answer questions, earn points and help others
