Question about Garden
The cutting deck keeps running when I pull the stop lever
    Sergeant:
  • 462 Answers
Needs adjustment
Posted on Apr 23, 2015
Hi, H650, working fine, then erratically just stop, seems electrical problem, side stand switch were suspicious, took it off and bridged the wires, the same problem, Thx
Hi, Tamas the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Runs stops starts backfires
Engine turns off all of sudden when riding
Kawasaki Ninja 650 Service Manual
OEM Parts for Kawasaki
Kawasaki Ninja Owners Manuals
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 01, 2017 | 2008 kawasaki Ninja 650R
I have a John Deere LX178 lawn tractor and the mower deck will not raise/lower. It is all the way down and pushing in the button is how i've ALWAYS adjusted the height. It will not budge
1) NEVER adjust to where the deck wheels touch the ground. The wheels are to ride 1/4" off the ground. 2) The long lever to your left which raises & lowers the deck has 3 settings. 1- Fully back toward you which has the deck raised (called transport mode). 2- Halfway down which is the normal mowing mode (called float mode) 3- Fully away from you which sets the deck fully on the ground. This mode is ONLY used for VERY rough terrain where the deck risks getting pushed into "transport" or "full up" mode & getting stuck there. 3) On front-to-back tilt, the front should be 1/2inch lower than the back for least damage to the grass. Ok-now to adjust "cutting" height. 1) Park on a level, flat surface. 2) Pull the deck lever fully back toward you to put the deck into "transport" mode. 3) twist the "cutting" height knob (just below your seat) to the height you want the grass cut. Has choices by 1/2" increments from 1" to 3.5". The deck in "transport" mode is 4". 4) Lower the deck lever to the midway/"floating" mode point. 5) Adjust each deck wheel with its own peg & pin to have at least 1/4" clearance from ground. Thats it for "cutting height" adjustments
call your deere dealer,
Troubleshooting
Service Mower
cant find info for you,call dealer
Jun 03, 2015 | Garden
Pto suddenly stopped working on my late 90's 25 hp dlt lawn tractor
Sounds like your cable might of broken. watch the deck end of the cable when you pull the lever up. If it is not moving the pully, it is broken. If you are trying to start with lever still up, even though the deck is not running, the safety switch is usually up on the lever. Try disengaging the deck lever, sit in seat, apply brake or parking brake and turn key to start. Let me know if that doesnt work and we can go from there.
Aug 06, 2014 | Craftsman Garden
Craftsman lawn tractor
I have had this before. Most likely it is a broken or missing return spring which is pulling the pulley to stop position (this is part of what pulls against the engage lever when you pull it up to engage the deck). Also there might either be debris under the lever on the deck that the moving pulley is attached to or it could be bent. Remove the deck and check for the spring (if you have owners manual that will show exactly where it would be located. If you dont and cant find one, give me the model number from under the seat and I will see if I can find one). If the spring is there, try forcing that lever on the deck by hand to see if you can get it to release (keep yours and others fingers away as when it breaks free, the spring provides some good force.
Aug 05, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Need to know how to operate the adjustment knob for the cutting heighth on the deck lift component on a Craftsman MV18S - 58560 riding mower
that model # is for the engine
the knob should screw in or out
pull deck lever up screw knob either in or out release deck lever
Apr 29, 2013 | Craftsman Garden
I have an atco commadore B20 that cuts out when I
it could be tight cutter bearings in the deck next time it cuts out switch off the motor and try to turn the deck by hand if its realy tight its seizing up on you
May 02, 2010 | Garden
John Deere ride on mower L100 17 hp.
my ride on runs well for 5 miutes then just stops wait a few minutes starts right up but does this over and over some help please
Aug 22, 2009 | John Deere Garden
How to adjust height on tractor mower model no. 917.270812? I turn the adjustment knob and it will lock in only on the highest and lowest heights and nowhere in between.
You need to turn that knob to its highest point with the deck height lever to its highest setting. Now turn that knob counter clockwise a few turns and let the deck lever all the way down. That knob will stop the lever part way down. If it mowes to high rase that deck lever again and turn that knob counter clockwise some more and let that deck lever down again. Repete till you have the correct cutting height. If you were cutting to low turn the knob clockwise insted of counter clockwise in the instruction above. The knob only set the stop of the deck lever. Once set the deck lever lifts the deck up and holds it but when you let that lever down it returns to its mowing set height.
Aug 12, 2009 | Craftsman Garden
Won't engage blades to cut lawn
Is the belt on the pulleys ? If so your cable is broke its what engages deck belt
May 09, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
