My machine isn't drawing in water, lights are on, tap is on but there's no water going into the machine. Can anybody help please? Thank you
  • Liz Barnes Apr 18, 2015
    I'm not sure how to check inlet valve as it's all connected under the tub and needs tools to disconnect it. If I can get it undone am I looking for blockages ? Thank you.
    Genius:
  • Washing Mach... Master
  • 1,585 Answers
Check inlet valve
Posted on Apr 18, 2015
Check inlet light flashing and machine will not start
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Sep 24, 2011 | Miele W2240 Front Load Washer
Zanussi Jetsystem IZ16 - When starting the cycle the machine will allow a small amount of water to enter the machine, but then it "freezes". I can pause the machine a skip to the next function,...
Hi from retired Englishman in SW France! You certainly do not want to be buying white goods in France- shocking prices aren't they?!!
When you say filters does that include those in the water inlet hoses? Just in case not (following pre-typed!) :-
John C
Sep 06, 2011 | Washing Machines
Washing machine lights on but machine not washing
I'm sorry but you have given us very limited information! I am having to guess first at a problem with water inlet. If it's not that please post again but next time with as much other info as possible- such as any noises, can you hear water entering, any fault indications- flashing lights??
John C
Aug 16, 2011 | Washing Machines
Green light on saying wash, cant get start button to light up red, but machine sounds like it going to start but nothing happens
It's a possibility that it could be waiting for water to be fed in- difficult for us to judge remotely ;-0(
John C
Main lights come on but the machine will not operate
Might be lack of water?
John C
Aug 01, 2011 | Bosch Washing Machines
Wont start cycle
With not much information to go on (!), I can offer 2 possibilities:-
If there is power on the machine check the water supply first-
If there is no power indication-
Check that the washer supply is OK using another item - a kettle for instance. If it's not check your breakers/fuses. Reset/replace if necessary and if the same thing happens, or if there was nothing wrong with the breakers/fuses in the first place, sorry but with such a fault it is virtually impossible for anybody on this forum to remotely guess what could be wrong with your washer. It could be internal wiring/plugs sockets, control panel switches, control PCB.
I fear that your only real option is a service call as the engineer will have the right equipment to safely diagnose what is wrong.
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jul 24, 2011 | Kenmore Elite HE5t Washer
Hi expert, I go PE error in LG 6.5 intellowash ,top door washing machine ,kindly help me to solve the same ...nagesh
LG's 'PE' stands for 'Pressure Error'- poor water feed.
John C
Jul 19, 2011 | Washing Machines
Hello.. The washer doesn't fill with water. I disconnected the hoses from the two back prongs of the washing machine and the water flowed from my house out the hose. Telling me it's not my...
Hi Rich from retired Englishman in SW France,
No- has nothing to do with the load size. You have already carried out what I normally advise for this sort of problem (below) so it looks like it's down to the last 2 sentences. Sorry ;-0(
John C
Jul 13, 2011 | Kenmore 22422 Top Load Washer
Water coming out of the powder draw when the draw is closed
Hi
The hose from the drawer into the tub is blocked or kinked, not allowing the water down quickly enough
Feb 16, 2009 | Hotpoint Aquarius WD63 Front Load...
Machine not taking in water from tap
more than likely its your solenoids which is were the water pipes attach theres 2wires going to these parts try swopping the wires from 1 solenoid to the other 1 after turning power off now turn the power back on and see if it now draws the water if it does then the other solenoid has become faulty
Nov 04, 2007 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
