Interterm nordyne 703911B model number M1MC 056W BW tenet before us unhook some.e wires now every thing works but the ac won't kick on. The fan blows but no cold air. How do I reattach and fix this.
  • 56 Answers
SOURCE: Ruud heating/ac unit blowing only cold air in heating mode
Do you have gas or electric heat. If you have gas then you do not have a heat pump. You should in most cases have a red,yellow, white, and green wires coming to the thermostat. R should go to rc/rh G should go to green Y should go to Y and w should go to W. Also the switches on back should be switched to non heat pump and gas rather than electric. Hope this helps.
Posted on Feb 16, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
luker711
  • 91 Answers
SOURCE: My AC unit wont blow the cold air.
No, you probably have a bad evaporative fan motor, capacitor or switching. It usually takes a Pro 1/2 hour to track down such a problem with good training.
Posted on Jul 09, 2009
  • 587 Answers
SOURCE: fan works but not blowing cold air
Is the compressor running? If it is then you are probably low on refrigerant and needs to be leak checked and recharged.
Posted on Jul 28, 2009
  • 358 Answers
SOURCE: AC unit outside blowing out cold air, vents
If you have a heat pump probably there's a wrong connectionin the thermostat, but if is not a heat pump ,the compresor is not working or the unit leaked all the refrigerant.
Posted on Aug 30, 2009
Testimonial: "thank you, we have had a problem in the past with refrigerant leaking, was supposed to be fixed"
Nordyne M1MC 070A BW- LED light constant blink. Says "false flame" or "internal control fault". What could this be? Bad limit swtich?
Sounds like a bad board. If this is electric heat you can check continuity across the limit switches with a multi meter. Turn power of to unit and remove wires on each side of limit to test. Really could be a number of things. Good Luck.
Mar 27, 2017 | Heating & Cooling
Nordyne furnace FEH017HA-04 the fan runs full force when the ac is on but half speed when the furnace kicks in
That is probably normal if it is electric heat to slow the air over the heating elements. Even some gas units do this. Check to see if the unit blower motor has wires for multiple speeds.
Oct 24, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Model m1mc 090a bw furnace pressure switch open. inducer motor is pulling .45 w.c . the intake pipe above inducer is only pulling .1 w.c. . checked for venting and intake blockages found non. removed...
did you check the hose from the inducer to the pressure switch? HAVE you unplugged the unit from the wall outlet to reset the board? DO you have a voltmeter? If you do you can run voltage across the switch and if you get 24 volts you are open.
Oct 23, 2013 | Coleman Intertherm Nordyne Miller Furnace...
Coolant fans not working can overheats when driving slow
did you get any obd codes ?? well there is a possible the power relay or ac relay is not working.
Sep 24, 2012 | 1999 Pontiac Grand Am GT
Golf 2000 is my car Recently I changed my Waterpump, TB and FCM. I find my AC sometimes works good, but other time just blow warm (compressor doesn;t comes on). Yesterday after adding two cans of...
firstly i think you have overcharged the Ac system as the most it should hold is 650 grms for this system on this model ,if too much gas it will click in and out and slow the engine down ,as for the gauge readings then renew the sensor its on the housing at the front in the plastic housing ,depending on year and model this is where most are ,but some later models have a sensor at the back of the head left side from front
Jul 19, 2011 | 2000 Volkswagen Golf
I have a new Salem travel trailer with Dometic products. Everything appears to work fine, but when I run my furnace and it turns on, my fan blows from my AC unit. I have owned 2 other RV's but...
Yes it sure does sound like something may be wired wrong, Could you please reply with model number of your AC unit as well as thermostat model? To find your AC unit model number if you don't already have it, remove your ceiling air filter assembly, and it should be on the base of the roof unit, facing you.
The base of the roof (upper) unit will have a model and serial number, and if you see a control box where all the wiring attaches as well, get model number from that too if you will. Those numbers should make it easier to determine exactly where the problem is. Thanks.
May 28, 2011 | Dometic Rooftop RV Air Conditioner
The AC fan does't want to begin to spin on its own. if I give it a little help, it will begin to work. Why wont it start on its own the fan will spin very easily and is not restricted at all it...
Hello, sounds like you have a bad capacitor, the capacitor gives the motor a boost and improves the running effeciency of the motor. Replace the capacitor it should fix the problem.
Mar 18, 2011 | Frigidaire Heating & Cooling
Heating & Cooling Logo
44 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
