Need schematic for 89C Fellewes schredder to repair
Can my paper shredder be repaired if the gears are locked?
I didn't dissemble my shredder when it seized after a jam. I tried to clean it, but failed. I found it easier to replace the whole unit as was about $35. Maybe you might find a cheaper replacement on ebay, I don't know how an MX808 costs or what a replacement for it is
So I'd like know a good answer to this problem too !
7.March.2015
Mar 07, 2015 | Office Equipment & Supplies
The schredder runs backward, but forward does not.
Take care, because this thing can also shred your fingers.
Remove the plug from the outlet and try to remove the paper under the rolls. Us a tool, not your fingers. It even would be better, if you could put the top upside down, so you could see where the bulk of paper is clothing the wheels and the sensor.
I think you already emptied the bag under the shredder, because the paper full sensor also prevents the shredder from running forwards.
Jun 16, 2014 | Intimus 421 SE Shredder
My shredder wont turn on
If you have been using continuously the thermal overloat ha possibly operated. If this is not the case then it is possible the motor has a fault, or. the little LED sensor in the schredder has failed and not allowing sensing of paper. If either of these two faults are cause then a repair shop will be able to confirm if it worth repairing
Apr 20, 2012 | Office Equipment & Supplies
Plastic gear is wore out. the motor shaft wore it
My friend, if the gear is worn out, your machine is worn out. By the time you get and in stall this part, you can purchase a new machine.
There is a possibility that Royal will sell you the part ... you could check with them. I have never had luck repairing any but LARGE COMMERCIAL shredders. Home and small office shredders are not worth the effort to repair.
Feb 13, 2010 | Office Equipment & Supplies
My schredder is jammed. I may haveput too many paged in it.
The industry trick is to soak the jammed paper with hot soapy water for 2 days.
Nov 29, 2009 | Office Equipment & Supplies
I have an eddie bauer HB3C 22-89c-BGL please send
hi i wash he coution of my eddie bauer highback 22-89c-bgl and now im having problem putting the belt togeter in their original place
Sep 28, 2009 | Eddie Bauer Baby Gear
Royal AG15X schredder stopped working after I tried schredding some stupid charity solicitation that apparently had a coin inside the envelope!! I'm think a fuse might have popped or something; I've taken...
I am wondering if you have something that is jammed. Is there any way you can get into the unit to turn the cutters manually? If so try to turn them backwards first and see what happens. Good luck. Unplug it to do this.
Aug 22, 2017 | Royal AG15X Shredder
682 people viewed this question
k24674
jasbo
jasbo
