Question about Amana Refrigerators
Normal running amp draw for a compressor on a ARB2259CS ?
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 310 Answers
This info should be listed on the model-serial number tag. It should be listed as "RLA" which stands for Running Load Amperage.
Posted on Apr 25, 2015
2 Suggested Answers
imufo2
  • 3773 Answers
SOURCE: compressor has a 11.4 amp draw but compressor not
Hi!
A relay starts the compressor with a higher voltage and then quickly kicks out
It does a lot of clicking (trying to start over and over again)
If thats what is happening with yours
Its best for a tech to replace The relay but you can do it
Take your model number to your Local Appliance parts store they will have a diagram
showing you how to install the relay. Its called a hard start relay
I use part no ERP410 POWER START RELAY, CAPACITOR AND OVERLOAD all in one. (110 v)
If you still have trouble Go Here:
http://www.applianceaid.com/procedures.html
Thank you for using fixya
Leo Ponder
PLEASE VOTE FOR ME IF THIS WAS HELPFUL
Posted on Sep 16, 2011
Kenmore coldspot compressor draws 1.4 AMPS when running but when it does not start it draws 8 AMPS
When you turn the compressor off you have high pressure on the output side - If you do not wait for the unit to equalize pressures before restarting, often, a compressor will not start - when this happens it draws a lot of power as your measurements indicate.
The technical reason why unit draws so much power when it is stalled is that the motor acts as a generator in the reverse direction of current flow. The reverse current or back EMF serves as a brake to the incoming current. So if you have 8 amps rushing in and the motor generates a back emf of 6.6 while running the resultant draw is 1.4. Capiche?
If motor does not turn on after a cycle it is because the thermostat is not closing properly. I would change it. U might also want to check out the condition of the start relay or hard start cap. If that is not working properly the compressor will not start.
Feb 04, 2017 | Kenmore Refrigerators
The rla on my weather king ac specs says 26 amps but a serviceman measured the current at 40 amps. he said the compressor was on its way out and recommended i install a new unit. is he correct? what would...
Hi, if a compressor draws that many amps above its running load amps, it is not normal at all. It would be tripping the breaker at 25 to 27 amps!! If the compressor is overloading that much, it wouldn't run at all.It could be that your outdoor coil is very dirty causing this reading. Take a water hose and wash it out good. Careful not to bend the aluminum fins when doing this.If the specs say 26 R.L.A., it wouldn't run at all at 40, no way at all. This tech must be green, or very fresh out of school.Wash the coil to bring the head pressure down, and see if it starts cooling. Any compressor that draws max amps will shut off on internal overload. If the compressor is on its way out, and he said its drawing 40 amps, it would be locked up, L.R.A, locked rotor amps. Wash that coil very well, as this is what causes high amps, and see what happens. He is wrong.Have them send a different tech out free of charge, and tell him what I have told you. If the compressor is 30 years old, it still could not draw that many amps, as the breaker, or fuse would blow in a second, or it would lock up! Please keep me posted,
Shastalaker7
A/C, Contractor
Jul 12, 2011 | Weather King Heating & Cooling
For the past two days I have had to reset the main circuit breaker for the outside unit. It appears to be running fine now. I'm just wondering is this an indication of the compressor about to go bad,...
Bill, first thing, make sure the outdoor coil isn't stopped up with dirt. This will cause the compressor to overheat and possibly trip the breaker. If you you can check the amp draw that would be good. Look on the data tag on the outside unit and look for RLA or "running load amps". Running amp draw should never exceed this number, it should actually normally run 10% under RLA. If its real hot where you are like it is here (109) it will be running close to RLA.
If you coil is stopped up with dirt, etc., turn off the breakers, use you water hose and sprayer and carefully wash out the coil.
If all this fails, and your amp draw is good, change your breakers. Hope this helps , stay cool.. Mark
Jul 10, 2011 | GE Heating & Cooling
Ice cubes & frozen food thawed out, food in refrig not cold. Compressor runs for 20-25 second and clicks off, after 1-2 min comes back on. The a/c amps reads 8.5 wht wire and 9.5 on red wire to the...
You are cycling on the compressor overload, meaning the compressor is drawing excessive amperage, the overload takes it out then it cools down and tries again. the normal amp draw for those compressors is 3-4 amps. Have you checked the condenser fan and made sure the coil is clean?
unfortunately those compressors cannot be serviced
Jun 27, 2011 | Kenmore Side by Side Refrigerator
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
Air compressor starts fine,but trips the thermal reset ,motor seems hot. It does it in every receptacal I've tried.
With no air in the tank and amp meter connected to one leg of line, start compressor and note amp draw thru cycle. It should draw low amps at first then reach rated amp draw close to end of cycle(most likely 12-15 amps). If amp draw is normal then replace thermal breaker. Older compressors have thermal breaker incorporated within winding and may not be easily replaced (but not impossible). If amp draw is higher than rated, check capacitor for proper rating and make sure that the in-tank check valve is not leaking pressure back to pump. Good holidays
Dec 29, 2010 | Hitachi EC12 Portable Electric 2hp Air...
My amana model arb2259cs is not cold but the motor runs
Not enough information. What motor runs, the compressor or the fan motor in the freezer compartment ?
Oct 16, 2010 | Refrigerators
Hi my botton frezer no working the compressor its hot
Compressors are normally 100-120 degrees when being cooled by a condenser fan motor. If there is no fan motor near the compressor then it can run up to 180 degrees, so the compressor temp by itself doesnt mean much. You can take an ampmeter and clamp it around one of the wires to the compressor to see if it is running, drawing anywhere from 1-2.5 amps or trying to start, in which case it may draw up to 20 amps every 3-5 minutes.
Oct 05, 2010 | Amana ARB8057CSL Bottom Freezer...
AC runs for 5 minutes and then circuit breaker
What else do you have running on hydro while AC is running? Such as coffee maker, microwave, water heater, fridge. That 30 amp breaker is your main breaker I assume, or breaker on pole your plugged in to. Keep in mind your AC will normally draw approx. 15-17+ amps momentarily when compressor kicks in to cool, then drop back to 12-15 amps when running normal. If your AC is drawing too much current, then you would only normally trip 20 amp breaker for AC in your panel. Try switching other appliances to gas operation while running AC, such as water heater, and fridge. Make sure incoming voltage is up to specs as well . (115-120 volts)
If water heater takes 5-8 amps, and fridge takes same when they are calling for power, you'll be close or over the 20amp mark when you consider your on board converter etc. as well. That only leaves approx 10 amps for AC that requires approx 15 amps to run, and up to 20amps when compressor kicks in. If you switch all those other items over to propane, and it still happens, then a current draw test should be done on AC unit to see if perhaps a capacitor is faulty, or possible compressor faulty.
Jul 22, 2010 | Dometic Rooftop RV Air Conditioner
During low voltage period window AC compressor shudders and kicks off, but fan runs, when voltage returns normal compressor runs.
low voltage issues causes higher amp draw and equipment to run a lot harder. whats causing the low voltage problem to the equipment? high amp draw of the compressor could be causing it to overheat and trip until the compressor physically cools down.
May 27, 2009 | Dometic Rooftop RV Air Conditioner
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
