Question about Radio Communications
On my yaesu ft-757gx when I key up then speak the output goes to zero,the dial goes black sometimes relays click and the mode switches to lsb until the key is released.
Radio has a flat match across the dial
  • 21 Answers
Sounds like the power supply is faulty and dying when the transmitter demands current. Perhaps a loose connection or dirty relay contact.
Posted on May 10, 2015
vrc_tech
  • 109 Answers
SOURCE: Yaesu/Vertex FT-51R Repair
You can order the parts from Yaesu or your local Yaesu dealer can do it for you.
Posted on Aug 21, 2008
SOURCE: Yaesu FT 11R
figured out how to solve this, with the radio off, push and hold both up and down scan buttons, while powering the radio on. This will fix the problem.
Posted on Jan 10, 2009
n9vsj
  • 18 Answers
SOURCE: i want to wire the astatic tug8 microphone to a Yaesu FT 450 HF
open the radio and visually look at microphone wiring on the yaesu you should be able to wire mic accordingly.
Posted on Apr 14, 2009
SOURCE: I have a yaesu ft 890 transeiver
I've had good luck repairing a FT-890 with the same problem. I repair electronics for a living so there's a very good chance I can help you. Feel free to contact me at 941.748.1941 or at andros2112@yahoo.com.
73s - Steve
Posted on Aug 03, 2009
  • 211 Answers
SOURCE: yaesu ft 1500 m
Here you can see the schematics http://www.repeater-builder.com/yaesu-vertex-standard/ft-1500/ft-1500m-sch.pdf
The manual can be found on the Yaesu website, http://www.yaesu.com/indexVS.cfm?cmd=DisplayProducts&ProdCatID=106&encProdID=92FB2363C1E0B9EBC9D3479054E0120B&DivisionID=65&isArchived=1
Good luck,
Gerard
Posted on Jan 30, 2010
After Flash Update (v0227) will not xmit proerly
I would flash it back to the older version. Double check you have the correct firmware. This almost sounds like the incorrect version for your radio.
Apr 12, 2014 | Yaesu FT-450D Transceiver
Cooling fan not opperating
I'm pretty sure it's on a switch. I have one, but it's been a few years since powering on. good luck, K9KUZ
Mar 10, 2014 | Yaesu FT-757GX Service Manual
VHF/UHF RF Power falls to Zero when the Auto ATU tunr logo is on the display. When the tunr logo is off the VHF/UHF RF power is only 10 watts on 2M and 3 watts on 70cms. The Yaesu FT 857 D should have no...
Check for open or shorted Veractor diodes and steering diodes there may be no direct interaction as you say but if a diode is open or shorted the RF circuits might still be selected for the higher bands and the lower output power on your vhf/uhf is an indication of this.
If you do not have a service manual you can get one hear, you will likely kneed one
http://www.tradebit.com/filedetail.php/127575994-vertex-yaesu-ft-857-ft-857d-2005-service-repair
Good Luck Best regarsds Falco
Nov 04, 2013 | Yaesu FT-857D transceiver
Yaesu support
have you tried a diode in the power supply rectifier? Re: Jeff
Sep 26, 2013 | Yaesu FT-990 DC Transceiver
Ft 2900r yaesu all i see on the screen is B0001 i can't see the frequency
Try powering the unit up while holding the Set/MHz button. I did that and it restored the display (and the rest of the radio's operation) back to normal.
The character codes are test-mode displays that correspond to frequencies (in MHz):
A0001-A0640 - 136.000-143.9875 in 12.5 KHz steps B0001-B0400 - 144.000-147.990 in 10.0 KHz steps
C0001-C2081 - 148.000-174.000 in 12.5 KHz steps
I haven't the foggiest idea why this isn't in the manual somewhere, or at least flipped back to normal by a two-key or three-key reset. 73, k2mct
Sep 16, 2012 | Yaesu FT-2900R 75 Watt 2 Meter VHF Mobile...
Yaesu ft 757gx II Repair Manual
Check www.mods.dk for a service manual.
Jan 08, 2012 | Yaesu Radio Communications
FT-920: When the TUNER switch is pressed, the
Have you tired performing a general reset (see page 92 of your Operator's Manual). If you have tried this and still have had no luck, be sure that you have established a good ground to earth and that you are not getting a lot of RF back into your 920.
If you do not have a manual for your rig, one can be downloaded here http://www.download.n7tgb.net/yaesu/FT920/man_ft-920.pdf
You can also call Yaesu Tech Support for free/additional help at 714-827-7600, or join the Yahoo FT-920 User's Group at http://groups.yahoo.com/group/YaesuFT920/
Hope this helps......
Jun 25, 2009 | Yaesu Radio Communications
After factory reset of yaesu vx-5 can not get out of nfm
Check the frequency step setting. If you have it set to 12.5kHz it's possible that's forcing the nfm mode.
Dec 26, 2008 | Vertex FNB-33, YAESU,FT-11R,FT-41R,FT-51R,...
Ref: YAESU FT 102 TRANSCEIVER [1] My bias normally between 75 - 85 ma begins to creep up after a few minutes of operating, using push to talk. On ceasing speaking and listening, it is OK but on the...
Hi John,
You have thermal run away in the PA bottles. Change all three for new ones and you will cure the problem.
With regards to the VOX make sure the DELAY control is not set to high, located above the RF amp button.
Regards,
Paul (G4KWM)
Apr 03, 2008 | Computers & Internet
Radio Communications Logo
177 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
