Question about Emerson Televison & Video
My emerson 32 inch tv just shUT off in the middle of a movie. Now has no indicator lights. I tried to unplug it,checked breaker,changed outlet. ..nothing
  • Emerson Master
  • 3,320 Answers
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Posted on Apr 24, 2015
  • 3422 Answers
SOURCE: Plasma TV-power light does not come on
There are a couple of possibilities here. If the set is indead dead, the most likely culprit is the "standby" transformer. If you are getting a click followed shortly thereafter by another click, then the TV is detecting a problem and shutting down to prevent further damage.
And if you get no clicks or anything at all, I would suggest you to look at the fuse and the standby transformer. The standby transformer is a small transformer that supplies 5V to the system even when off to allow remote control. You need to see if the primary side of this transformer is open or not. You should have 5V.
Goodluck,
Please don't forget to rate me as fixya..
Posted on Feb 01, 2008
  • 2336 Answers
SOURCE: AKAI 32" LCD HDTV WILL NOT TURN ON
The only solution at this point would be to get the power supply repair since new boards are not longer being manufactured. In about 95% of the time if the LCD doesn't power up or turns OFF by itself or need to be unplug for some time to make work again; those are the symptoms of a dying or defective power supply.
I service these power supplies, for more info write to jah2mil@hotmail.com
Posted on Nov 27, 2008
  • 2336 Answers
SOURCE: totally dead. Vizio GV42L
If the circuit breaker was tripped, more likely the fuse inside the TV power supply might also be blown. If that is the case there might be a short circuit in the power supply components, more likely on a diode or transistor/mosfet.
Contact these website to see if they have the parts for your plasma.
Good Luck.
Posted on Dec 03, 2008
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
  • 73 Answers
SOURCE: 32'' sharp aquos tv will not power up.
Look for the fault in power supply board. First check the fuse and replace it if burned. Then it could be a Voltage Regulator chip(s) burned (they look like transistor with 3 pins). You can test it with multimeter, they could have different pin outs, but generally it should read around 5 MOhms in 2 sets of 2 pins. Or it could be bad capacitors, look for swallen or domed capacitors; measure them with capacitance meter, sometimes they dry out with time. Or it could be other parts in power supply.
Posted on Oct 29, 2009
Testimonial: "The tests suggested may lead to something."
Change the resolution on my emerson flat panel television
You need the remote.
You can buy replacement remotes.
Mar 26, 2014 | Emerson Televison & Video
Emerson 32 inch won't come out of standby mode
It clearly has a problem not allowing it to come on---the set has a warranty---take it back and either get an exchange---Most major stores will exchange in first 30 days for any reason---if they give you the "it has to go for repair," demand a refund on the spot.
Frankly Emerson is not a very good quality brand and parts and support are nearly zero.
Dec 04, 2012 | Televison & Video
No power
Chances are that the power from the pole surged or cycled on and off, try unplugging it from the wall outlet for 5 min. Some of the newer TV's have a surge lockout protection feature that won't reset till all power is off for 5 min. But the key is unplugging it from the wall outlet, not unplugging it from the back of the TV. It took me a while to figure it out.
Sep 06, 2012 | Emerson LC320EM2 32" LCD HD Television
No power to tv red light is out and it's plugged in it just shut off
If the TV is plugged into an active outlet, and the power indicator isn't working, most likely you are dealing with a power supply failure. There is a chance you could have a main board failure as well. I would recommend getting a proper diagnoses before buying parts !!!
Sep 06, 2012 | Emerson LC320EM8 32 in. LCD TV
My Emerson LC320EMX tv wont power on. Can you please tell me if there is a way to fix this?
Check ur power out source?If tv have no power LED light indication on the tv bazel frame at all.Tv power LED light indication on the tv bazel are flashing.Tries tv unplug,replug it back like about an hour later for tv to do a resetting itself back to the factory setting.Tv should be working again.If still have the same result.The tv power supply board is the causes and the problems.That the board where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Apr 21, 2011 | Emerson LC320EM9 32 in. LCD HDTV
I have an emerson model LD195EM8 that will not power on
Ur tv front screen panel power LED light indicator flashes?Check ur power source like the plug in outlet yet?Yes,Than.The power supply board it dead.That the board where the a/c power cord plug into it.Take the tv aparts,replaced the power supply board.Ur tv will have power again and work.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
May 29, 2010 | Emerson LC320EM9 32 in. LCD HDTV
My emerson TV will not even turn on. Took a nap with it on, woke up it was off. Everything else on the surge protector still works, tried plugging it into another outlet, but still nothing...
sounds like you blew the lcd or plasma, I did the same with my Vizio, hopefully you do not have the same problem.,, does the power light stay on and no picture, and if so try and turn the power button off, if it does not shut off, and you unplug it and it shuts off and the red light goes out, and then when turn it back on the red light is out until you turn it on and the same thing happens all over again
Jun 13, 2009 | Emerson LC320EM9 32 in. LCD HDTV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
Televison & Video Logo
97 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
