Question about Delta 4" Belt 6" Disc Sander 31-460
Need the size and thread pitch for my Delta disc/belt sander wheel set screw
This is the set screw that locks the disc to the wheel. Thanks!
    Problem Solver:
  • 18 Answers
Probably an 8-32 or 10-32 (possibly a 10-24) or even a 1/4-20. You can get small packs of these size screws at most hardware stores so would be cheap to busy one of each and try and once you know the size you can get a set screw of that size. Another crude way is to see what size drill bit will fit into the threaded hole. If a 3/32" goes but a 7/64" doesn't or fits tight, it is a size 6 (likely 32 threads per inch (TPI). If a 1/8" bit goes but a 9/64 doesn't or is really tight then it is a # 8 size. (8-32 is most common). If the 9/64 goes freely but a 5/32 doesn't it would likely be a 10-24 whereas if the 5/32 does go but an 11/64 doesn't then figure it to be a 10-32. Finally, it could be a 1/4-20 if a 3/16" bit goes but a 13/64 doesn't or is fairly tight. If it is really big and a 1/4" bit fits the hole then it is likely a 5/16-18.
Posted on Apr 26, 2015
efs_perpends
  • 1996 Answers
SOURCE: need a wiring diagram for a delta drum sander
Here's a link to the online manual.
As far as that diagram....didn't you label the wires?
Take a look here, it may help you. circuit wiring , especially the paragraph that begins: "Knowing that electrically common points have zero voltage drop between them is a valuable troubleshooting principle." Also read about resistors. That speed control knob is one.
Hope that helps...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread. If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 02, 2009
SOURCE: I have a Canadian tire model 55-3550-2 belt/disc
I went to a bearing/powertransmission supplier. The number on the belt was all they needed. Picked up a new belt for $6.50.
Posted on Nov 28, 2009
  • 122 Answers
SOURCE: My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Posted on Jan 30, 2010
rowdy45176
  • 2176 Answers
SOURCE: I'd like to download a manual for the Delta 1"
you might try going to dewaltservicenet.com and typing in your model number in the middle of the page towards the bottom under need a manual. If not let me know and I will try and locate another source for you.
Posted on Oct 03, 2010
robertjam119
  • 12 Answers
SOURCE: I am looking for an agent in England for the
These folks were able to cross reference a Delta 1346364 Belt replacement for me and I was impressed with their service. Please let me know if this helps.
http://store.beltpalace.com/225l050.html
Regards,
-William
Posted on Feb 20, 2013
What size of belt for delta 1 inch belt sander?
you would have to list the specific model number listed on the side of the factory sticker for me to pull it up on their site..or measure from outside of the front wheel to outside of the other wheel on the rear. should give you an accurate belt length.good luck
May 19, 2017 | Delta Tools & Hardware - Others
How to fix motor delta belt disc sander
What is it doing or not doing, when u turn on the switch, either the switch or motor is probably bad or you have too much tension on the belt.
Aug 22, 2014 | Delta 31 695 6" Belt/9" Disc Sander
I have lost the screw that holds the sanding from spinning on its own. I can't find the part number. Could you assist please?
I do not know if this will help because I do not know which screw you need. If you click on the link below you can look at the delta service manual parts list.
http://www.ereplacementparts.com/images/delta/31-695_TYPE_1.pdf
Otherwise can you be more specific on the location of the screw?
Apr 29, 2011 | Delta 31 695 6" Belt/9" Disc Sander
What size belt does it use
You did not mention a model number, but the is probably the width of the belt and the 6 is probably the diamter of the disc.
The sanding belt size is probably a 4" wide by 36" long, but it may be 4 x 24" long. Put a string around the rollers, and then stretch the string out straight. Measure it and that is the belt length.
You can find either size belt at sites like http://www.2Sand.com and http://www.BuySandpaper.com
Jan 25, 2011 | Delta Machinery 4x6 Belt/Disc Sander
I'd like to download a manual for the Delta 1" Belt/5" Disc Sander I just picked up at a yard sale. I can't seem to find one. Thanks.
Oct 03, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Jul 20, 2009 | Tools & Hardware - Others
31-735 delta belt/disc sander - dust collection nightmare
The belt cover that does down the front of the belt, below the table, should have an opening inside the baes/vacuum unit. Make sure this isn't clogged with buildup.
Jan 27, 2009 | Delta 31 735B 6" Belt, 12' Disc 3 Ph...
Delta 4" Belt 6" Disc Sander 31-460 Logo
73 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
