My daikin vrv is nt working. Red light is blinking continoisly and error code is showing as u4
4 Suggested Answers
  • 47 Answers
SOURCE: i have daikin air con brc1c51/61 showing error code J2.
you cannot fix this mate... you will need a fridge mechanic.. try cleaning your filters id say that's your only chance
Posted on Nov 11, 2009
  • 81 Answers
SOURCE: U4 System transmission between indoor and outdoor units Daikin
Sounds like an interconnecting wiring error. Check wiring connection i.e. wires are connected in right order 1 to1 2 to 2 etc. from indoor terminal board to outdoor terminal board. Also check for slack or loose connections.
Hope this helps I take the time to answer your question so please rate me
Posted on Jun 28, 2010
ar1965
SOURCE: VRV 3 Daikin 2 pipe system. does any one know
no communication between indoor and outdoor units
Posted on Aug 12, 2012
Daikin vrv system error code a3
hi, A3 Indoor Malfunction of drain Level control system.
Air Conditioning Fault Codes
Feb 24, 2014 | Heating & Cooling
ERROR CODE:UO
Insufficient gas. Need a tech to check for leaks, pressure test, evacuate and refill to correct levels.
Aug 26, 2013 | Daikin BRC1E71 Navigation Wired...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin reverse cycle air conditioner error U4
Signal transmission error (between indoor and outdoor units) which means a faulty indoor or (more likely) faulty outdoor controller board. Call a tech.
Sep 19, 2012 | Daikin Heating & Cooling
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
My daikin inverter does not turn on. when i press on on the remote, the flaps open all the way down then close. the green operation light is flashing.
Seek a refrigeration mechanic. With out looking at the unit it is to pin point problem.
More than likely a PC board issue on the indoor or outdoor unit. Does your remote control give you an error code. If possible look at the users manual on how to get the remote to give you the error code.
Nov 26, 2010 | Cfm Daikin R410a Split System Air...
May 28, 2010 | Cfm Daikin R410a Split System Air...
Daikin air con - error code is u4
i need the contrl wiring of a packaged unit
Mar 07, 2010 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
