Question about Garden
I just purchased a new Hasqvarna 130BT. Took it out of the box, I believe I followed all the directions. But it won't start. Checked the plug, fuel (Using the Hasqvarna pre mix. 50:1). I need help
  • 1,169 Answers
We had user @ AnswerArmy that recently purchased a 150 BT that had the choke label put on backwards. Check this as this maybe your problem and you are simply not choking it.
Posted on Apr 18, 2015
pgh_pa_guy
  • 2992 Answers
SOURCE: need a manual in english for a haqyarna 55 chainsaw
Here's a link to the Husqvarna site that should be what you need:
http://weborder.husqvarna.com/order_static/doc/HOUS/HOUS2001/HOUS2001_1019194-95.pdf
Posted on Nov 22, 2008
steve_lima
  • 181 Answers
SOURCE: poulan chain saw P3314
pull the muffler off and check if the piston is scored,if it is you need to replace the piston and cylinder.
Posted on Jan 07, 2009
  • 211 Answers
SOURCE: husqvarna 400 e series- I mixed the fuel 40-1 instead of 50-1
Hi
If you have good compression and spark at the spark plug try priming the engine(put some fuel mixture in the spark plug hole),set the carb adjustment(highh speed H=3/4 turn and lowspeed L=1 1/4 turn,turn the scews clockwise until the end and then set them.Try to start the engine.If it runs only the gas you puted inside the cilinder and then stops you have a fuel delivery problem to find and fix.First disassembly ,check and clean the carb.Then the fuel filter and the hoses.Let me know. best regards savumihai71
Posted on Feb 11, 2009
SOURCE: ms260 chain saw will not start
try replaceing the diaphram.
Posted on Apr 25, 2009
  • 302 Answers
SOURCE: will not start - new fuel 50-1 mixture, checked
Will it start if you pull the plug and spray starting fluid in the chamber? if so then I'll bet you have a blown diaphragm in the carb or a plugged fuel filter or a bad gas line. hope this helps. Jeepfxr
Posted on Oct 08, 2009
I have a hasqvarna 125 b I have put new starting coil on it,new fuel lines, rebuilt carb, new primer pump, new plug. It is getting spark, the plug is wet, but it still won't start.
Check your muffler's spark arrestor screen for clogging. Also test your compression. It needs to be be at least 100 psi for the engine to start.
Apr 24, 2015 | Garden
Won't start
Are you getting spark on plug? Check to make sure wire is connected to plug, if still not starting. Is fuel getting to plug? Remove plug an see if its wet. If its wet it could be flooded. If not fuel lines are common on saws, tank in is a major problem it cracks an need replacing. Have you checked the on off switch? If it still wont start, carb is more than likely the problem. Remove it an get a rebuilt kit, they are cheap, carefully remove all parts clean out all orifices even small ones with a piece of brass or steel bristle from a brush, use carb cleaner to clean the parts, carefully put it all back together an it should start. That is about all there is.
Mar 25, 2014 | Husqvarna 130bt 130 Bt Gas Powered...
Worked last weekend will not start
Need more info. Is it getting gas? You can check this by squirting some fuel into the carb or spark plug hole and cranking it. If it tries to go, then it is getting gas. (Be sure to put the plug back in though). We can work from there. . .
Chain saw will not start
sure sounds like you did it all.
Was the Plug wet with gas when you took it out to fuel it directly? I would take the plug back out, blow out or let the Cylinder totally dry. Then spray a bit of Starter fluid in the carb and see if you get life.
Old gas left in a saw is a Carburetor killer. The paper components in these carbs can not stand the new 10% ethanol gas.
Dec 06, 2012 | Husqvarna , No.455 Rancher, 20" Gas -...
Hello. My 1997 Chevy Tahoe refuses to start. The problems began with a bad fuel pump. I changed. It worked. The fuel pump died again. I changed it again and it has been working. I parked it for two weeks....
Now you have a good battery & a starter that turns over the motor
Have you cycled the key on & off with a fuel pressure gauge on the
fuel rail?
Do you have a fuel filter that isn't over 3 or 4 years old?
Have you checked for spark while cranking ? Use an old plug on the wires,
if you have ignition wires,don't ground the wire without resistance
If you removed the ducting & MAF Sensor it won't start
Tell us what you checked & exactly how that was done.
Jun 09, 2011 | 1997 Chevrolet Tahoe
Bought a hasqvarna 235 won't start brand new out of the box. Any solutions
If you have followed all of the manual instructions for starting the saw, take the saw back to where you got it and ask for a replacement under warranty.
May 15, 2010 | Husqvarna "Chain Saw - 16" Bar, 3 Hp
I have a Hasqvarna 150BT blower that started to make a knocking noise at full power and has lost some power. Seems to start ok. Loss of power / rpm and knock are only ploblem?
I had the same issue with a Husqvarna 150 BT blower. Brand new ran through 2 tanks of gas and need to buy more gas , mixed 50 to 1 ratio 87 octane on new gas which was the same as what i was running and it started pinging and running like **** then stalled and would not start. took the plug out and it was fouled. cleaned the plug got it running again but still not good. This model comes with a NGK CMS7H plug which i replaced with a champion RZ7C and new gas 93 octane and lawnboy oil mixed 50 to 1 ration and now its running like a champ. I've had bad experiences with NGK spark plugs in the past and thought this may resolve the issue and it did. Hope this is helpful to anyone out there having the same issues. Also used some fuel stabilizer in the fuel mix, I hear this helps with the ethanol problem in the fall/winter gas.
May 13, 2010 | Husqvarna Backpack Blower 25cc, 140 Mph,...
Hasqvarna LTH140 lawn tractor. Engine won't start.
remove the carb and disassemble---clean parts in solvent--make sure the float valve moves freely in the bowl
May 08, 2010 | Garden
I have a 130BT and doesnt start i got new plugs for it but that didnt work i took plug out and cranked it but i didnt see any spark so im thinking it must be the magneto ? and where do i find that part ?...
1) Make sure the kill switch is off, or in the position to start
2) It might be a problem with the kill switch, try replacing that first.
3) Use new and clean fuel mixture
Jul 03, 2009 | Husqvarna Forest & Garden 125bt Backpack...
Garden Logo
47 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
