Question about Xerox Phaser 3100MFP
The key card fails to register in the printer.
I am changing cartridge, but failed to activate the tonner.
    Master:
  • Xerox Master
  • 563 Answers
Once the key fails. You will need to get a new toner box with a new key. The seller should be able to exchange for a new one.
Posted on Dec 22, 2017
Print quality is bad
Change your ink cartridge
Mar 25, 2015 | Retail Supplies
My printer is requiard toner rear end
You meen tonner near end you have to purchase a new tonner cartridge and replace or refill if you refill it you must get with your cartridge a reset card
Apr 15, 2014 | Xerox Phaser 3100MFP/S Laser Printer
Ink light on changed ink still wont print
it sounds like the printer has not accepted the changed cartridge.
Try turning the printer off at the mains for 30 seconds then back on again, it sometimes works, or if that fails take out the cartridge's turn off printer for 30 mins then back on re insert inks and see if that works.
If it fails then there could well be a chip set failure on the cartridge you have replaced or maybe another cartridge within the set.
It's well worth saving the cartridge too as compatibles sometimes fail to be read by your printer but rarely the actual cartridges fail, you can put that same cartridge back in later for it to be accepted by the printer.
Jan 15, 2014 | Epson Stylus Photo R260 InkJet Printer
Problem is that the toshiba 1560 black and white copier is singing service key showing and tonner is empty, but tonner is newly installed the error continue. ?
check maybe you are using different toner cartridge! i mean the same model of cartridge but there is a number of pins(teeth) on the cartridges... that's why it shows empty toner coz the toner are not dropping to the developing unit!
Nov 24, 2011 | Office Equipment & Supplies
I changed my black cartridge, which was low. Now I get color bleeds, mostly yellow, in vertical streaks, on the printed paper.
Install the old black tonner back inside, if the yellow vertical marks disappear then the problem is in the new black tonner
Feb 02, 2011 | HP Color LaserJet 3500 Printer
My laser printer samsung SCX4300 shows tonner exhausted replace tonner.
Buy new cartridge or refill this cartridge and replace the chip on the cartridge
Dec 11, 2010 | Samsung SCX-4300 Monochrome Laser...
Installed new cartridge and comming up machine won't regognise it saying tonner life end install new cartridge
To reset the sensor after installing a new toner cartridge follow these steps. 1. With unit powered On, open the front cover. 2. Press the “Options” key. Display will show “Replace Drum?” 3. Press “Start” key. 4. Press 1,0 . 5. Display will show “Accepted” for approximately 2 seconds. Then display will change to “Cover Open”. 6. Close cover and see if Toner Life End error message has gone.
Try this. We are Brother authorized.
Apr 15, 2010 | Brother MFC-7420 Laser Printer
Hi i have a problem in my hp4700 printer.everyday morning i need to shake the tonner for getting good quality print.Iam using hp genuine tonner catridges
Is this and old cartridge?
Trying changing it. Use a new one.
Good Luck.
ps when I know that I'm running out of tone, that is usually what I do to get a few more pages to print,
until the new cartridge comes in. LOLl
Nov 05, 2009 | HP LaserJet 4700 Printer
Won't Print in Black. Have changed ink cart but still fails to print.
have you aligned the print heads? and cleaned the cartridge using the on unit functions? this often is required to register new ink in unit. good luck.
Oct 01, 2009 | Brother MFC 420CN All-In-One InkJet...
Black Lines and Very Harsh noise on a new Tonner. No printing with New tonner
Those printer tonners are very tricky to refill and a bad refill induse on bad printing so you can clean the drum (the round green thing) with isopropilic alchool. If it continues it indicates that the blade ( inside tonner plastic blade that cleans the excess tonner powder) is durty and you can clean it too with the same alchool. If it continues replace the tonner cartridge.
Feb 12, 2008 | Samsung ML 1710 Laser Printer
Computers & Internet Logo
137 people viewed this question
Top Xerox Computers & Internet Experts
Jack McCann
Jack McCann
matt
matt
k24674
Are you a Xerox Computer and Internet Expert? Answer questions, earn points and help others
